Question about Viking 24 in. Professional Series DFUD140 (Premium) Built-in Dishwasher
Cycle control lights flashing all at same time
All of the control lights are on and blinking on my Viking Professional dishwasher. I have tried turning the unit off and on several times via the main on/off button and the lights still all flash. I have tried turning the dishwasher off via the circuit breaker for 1+ hours hoping it would reset but no success. The unit makes a motor-like noise when it is on (and the lights flash) and I can see that the sprayer on the bottom of the machine moves a bit. I have cleaned all of the drain parts and checked the hoses -- all seems okay. If I simply close the unit it does not cycle. Yesterday, when I noticed the problem, the water did go into the machine initially but it then seemed to stop going in. There was some leakage under the dishwasher when I turned it off and standing water on the bottom of the machine. When I turned the unit on this morning the machine did drain the standing water. Is seems to be stuck in some kind of cycle limbo and I am hoping there is a simple reboot for the buttons. Any ideas?
  • sipindental Oct 16, 2008
    i have a viking professional dw . both pots and heavy lights are blinking.
    cycle starts but never completes. water pools . aerator not clogged.
2 Suggested Answers
  • 4102 Answers
SOURCE: cycle control lights flashing all at same time
are you sure you have cleaned all the water outlets as when these get blocked and the water builds up the dishwash will go into a standby mode as a sefety precaution to stop your kitchen getting flooded if it was me i would take off all water outlet pipes and use boiling water and a good cleaning fluid it only takes a little blockage and then it will cut off so clean all pipes through properly and then try again is the water going into the dish washer before it cuts off or is their no water going into it either if you post back ill have a nother look for you hope this is some help i had same prob with mine but it was different brand of washer but after cleaning all pipes inlet and outlet it worked fine and is still working now use good limescale remover cause if you live in hard water area then this is probably you problem .......................................................
Posted on Nov 12, 2007
My viking vdb325ss dishwasher runs for a few minutes and then stops with control pad lights blinking. The "normal cycle" and "pots and pans" lights blink together. I have reset and restarted the dis
Hello Peter!
Your owners manual or a call to Viking should help you decode the blinking panel lights. They are not random and are a desperate cry for help from the machine.
It has been my experience (YMMV) that a common dishwasher problem in older machines is accumulated grunge (the technical term) in the water level sensor. In many cases the sensor lives in a plastic container on the side of the DW and although the designers try hard to avoid contamination, the container eventually loads up and intermittently jams the float.
Before I pulled the unit however, I'd check the bottom of the wash cabinet for contaminants. There may be an screen (under a cover plate) that has clogged.
Your situation sounds a bit different, since my Samsung did not pump out water, it just stopped and flashed a code, but who knows? Go for the low-hanging, common issues first.
All the best.
Nov 23, 2014 | Viking VDB325SS Dishwasher
Blinking lights on frigidaire dishwasher
Hello - Try resetting the dishwasher by disconnecting the power to the unit. This will clear most flashing lights. You can disconnect power by flipping the circuit house breaker off and back on for approximately two minutes. If this does not prove to be successful, contact a professional to move forward accurately. Dishwasher could possibly have a faulty control board or wiring failure.
Oct 10, 2012 | Frigidaire 24 in. PLD2850 Built-in...
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
May 21, 2011 | Viking 24 in. Professional Series VUD040...
I have a viking dishwasher that is not a year old yet. I start it and within 5 min the lights start blinking on it, so it stops?
can you please confirm which light is blinking.
Does it take in water before it stops?
Refer page 34 and 35 in this manual once you check which light is flashing.
Hope this helps.
May 15, 2011 | Viking VDB450 Dishwasher
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Viking dish washer won't drain
1) is the hose clear/ not kinked or pinched
2) is it hooked up to a garbage disposal..( was the plug removed)
3) can you hear something in the drain pump?
if all is good the let me know there may be more I can help with..
Aug 30, 2008 | Viking 24 in. Professional Series VUD040...
Nov 10, 2007 | Viking 24 in. Professional Series DFUD140...
Viking 24 in. Professional Series DFUD140 (Premium) Built-in Dishwasher Logo
47 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
