Looked everywhere but can't find a solution. Maybe you can help. I can't find a way to connect my iphone 2.2 firmware to the Jabra with Bluetooth. Somebody knows something about it? tnx flo
1. Hold the "Answer/End" button on your Jabra Bluetooth
headset down until the LED light on the headset turns solid blue. It is the button that has an image of a
telephone on it.
2. Click on the "Settings" icon from the main screen of your iPhone.
3. Click on "General" in your iPhone's "Settings" menu.
4. Click on "Bluetooth" to access
your iPhone's Bluetooth menu and then click the option to turn on your
iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned
on, it will search for available Bluetooth devices.
5. Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
6. Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
You need to pair your Blackberry with your headset.
Turn on your Blackberry's bluetooth and search for bluetooth devices.
While the Blackberry is searching and the headset is off,
press and hold the call/end button on the headset until it's
light glows steadily. Do not let go until the Blackberry finds it.
Pair the devices and allow the headset to connect automatically.
Default passkey is 0000.
To connect, press and hold call/end button on headset like the one in step 2.
within connections settings on your phone your jabra will always be discivered if you have set your bluetooth within phone to be on all the time, when you switch on head set it will be automatically picked up by your phone.hope this helps
1. Turn the BT150 on. To do this press and hold the answer/end button until the light flashes blue, then release. 2. Press and hold the answer/end button and the volume up (+) button until you receive solid blue light. This may take up to 10 seconds. 3. Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Goodluck
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 modeMake sure that the headset is on.Press the answer/end button andpress the volume up (+) button at the same time,until a solid blue light comes on.2. Set your Bluetooth phone to ediscoverf the Jabra BT150Follow your phonefs instruction guide. This usually involves going to a esetup,feconnectf or eBluetoothf menu on your phone and selecting the option to ediscoverfor eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4)3. Your phone will find the Jabra BT150Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf onthe phone and confirm with the passkey or PIN3 = 0000 (4 zeros).Your phone will confirm when pairing is complete. In case of unsuccessful pairing
