Question about Whirlpool ED2SHAXM Side by Side Refrigerator
Lots of dust/lint etc. under refrigerator
How do I remove the front grill (where the water filter is replaced) to clean/vacuum all of the dirt? I also think this would make the refrigerator more efficient....
I took apart a furnace filter and cut the filter floss into strips. I then laid the strips in front of the coils so the air has to pass throught the filter before passing over the coils. Just remember to change the filter floss every couple of months. Work like a charm!
Posted on Oct 25, 2009
  • 828 Answers
You are right on the efficiency, also will extend the life of the product by keeping this area clean. These grill usually pop out by using and up and out motion from under it. Use your vacuum tool for getting into the narrow places. If your vacuum is reversible plug the hose into the exhaust discharge and blow any remaining dust out.
Posted on Dec 06, 2008
How to replace thermal overload switch pacvac 700
Hey there! The thermal protector sensor can not be replaced. It protects the vacuums motor from overheating and burning out. If the vacuum is overheating, follow these quick trouble-shooting steps.
1. Remove the hose from the vacuum from both ends.
2. Use a broom stick to gently loosen and remove any clogs from the hose.
3. Remove the bottom plate and the brushes. Use a wooden spoon to gently break up and remove any clogs from the lower hose.
4. Clean the pleated filter inside the dirt cup by tapping it against the trash can until the dirt stops falling. This filter should be replaced at least once a year.
5. The pre-filter can be cleaned with a brush and then rinsed with water. Allow 24 hours to air dry outside the dirt cup.
6. Clean the secondary filter located behind the grill in the bottom of cleaner cavity. Remove the screw, and grill to access filter.
7. Rinse the filter in cold water with a mild detergent to clean. Allow 24 hours to air dry outside the vacuum.
Following these steps should stop the cleaner from overheating. Hope this helps!
Jun 16, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Do i need to clean coils?
you dont new unit are sealed, some have a filter in front at the bottom vent.
Sep 23, 2012 | Maytag MSD2651 HE Side by Side...
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
The freezer is running and is set to the coldest setting but still is not cold enough to freeze our food. Ice has melted and food in the freezer is beginning to thaw.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor.
1. Make sure condenser is clean.
2. If you have a "rear mounted" condenser (black coil on back) make sure it has enough room around it for air to circulate. Not against the wall and if under cabinet should have about six inches clearance.
Rear-Mounted CoilsYou should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant.
Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.
Floor Level CoilsYou should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils.
Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Jul 10, 2011 | Amana ARB220RCW Bottom Freezer...
How to clean condenser coils on lfx25960tt
Condenser coils- The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Sep 04, 2010 | LG LBC22520S (224 cu ft) Bottom Freezer...
I use my kenmore single room air conditioner all night, in the morning the coils are all froze up? is that normal? The fan is working & I hear the compressor working. Maybe something is going out? it's...
Please check the filter. The filter is located behind the front grill. If there is a lot of dust & dirt on the filter, it will reduce the airflow over the coil significantly - causing freeze ups. A filter that is missing will require a thorough cleaning of the coils to remove the dust and dirt, then installing a replacement filter. There are products sold at hardware stores, home improvement centers, etc. designed specifically to clean these coils easily. You should be able to get a replacement filter for the AC from Sears.
If the filter is present and clean - there could be a problem with the refrigerant charge, or other problem. Many times, an AC units of this small size, it is cheaper to buy new than invest in repairing a 3 year old unit.
Please rate this reply if helpful - good luck!
Aug 25, 2010 | Kenmore Single Room Air Conditioner
Dirt blowing out of front of vacuum
Replace filter in the front as it gets loaded with dust and needs replacement. Also clean filter under canister.
Apr 29, 2010 | Bissell 6594 PowerForce Bagless Upright...
Not blowing cold in freezer or refrigerator. compressor is hot to touch, fan is blowing
HI. The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the electrical components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Dec 08, 2009 | Kenmore Refrigerators
Compresor is hot and refrigerator it doesn't work
HI. This will occur if the condenser coils are dirty. This will inhibit the coils from dissipating heat.
Nov 25, 2009 | Maytag Refrigerators
How to clean filter
The de-humidifier is a niche product. Its only job is to remove moisture from air to alleviate the problems of mould and mildew. It is very similar in operation to a window air conditioner.
A dehumidifier though will add heat to the room, while an air conditioner will remove heat.
The de-humidifier is an appliance that requires regular maintenance. This may be because it’s icing up, overflowing, not removing enough moisture, or simply time for a good cleaning to maintain its efficiency. If you don’t feel handy enough to attempt this project contact your appliance repairperson.
The following is a step-by-step method used to return your de-humidifiers to its peak efficiency.
Tools required
1 Multi pocket container (old ice cube tray)
2 Long handled brush
3 Oil can
4 Rags
5 De-greaser or spray detergent
6 Selection of screwdrivers
7 New filter
1… Remove water collection bucket and put aside.
2… Remove the filter from rear of machine. Filer is usually within a frame and simply pops out. If no filter proceed to next step. If it is a disposable filter simply replace it with a new one. Other types are made in a plastic frame and can be cleaned and reused. To clean a filter lay it flat in the sink and sprinkle surface with powder laundry detergent. Plug sink drain and turn on hot water. Cover filter with enough water to submerge. Soak for 15 minutes. Remove from water and rinse. Hang up to dry while proceeding to next step.
3… Remove the rear grille from the main body of de-humidifier. If none proceed to next step. If there is resistance then look for hidden screws. If grille locks into cover proceed to next step. Once removed place the grille aside until later.
Tip: Dehumidifier may use different types and sizes of screws. Use ice cube tray to segregate.
4… Remove metal cover of de-humidifier to access inner workings. Cover screws may be difficult to see because are often painted to match body color. Usually two or three screws along each side of base. Once screws are removed lift the cover straight up. Use extreme caution at this point. Front grille may be secured to cover. Some fronts are put together like a puzzle. Parts often interconnect or are screwed to one another. If front grille lifts off with cover try to separate before proceeding. Front grille may lock into groove along front edge of cover. Avoid pulling off any wires from humidistat or indicator light.
5… When cover removed this will expose the heating and cooling coil. They may appear as one but are actually two separate coils in very close proximity. Both will need to be cleaned.
Use a narrow brush to remove surface dust and dirt from the front and rear surfaces of coils. Use an up and down motion to avoid bending fins. Area between two coils must also be cleaned. Use caution, the fins are soft aluminum and can be easily damaged. Once surface dirt is removed, spray with de-greaser or light cleaner. There is a good product on the market called HVAC cleaner. As the name implies it is meant for Heating, Ventilation, and Air Conditioner coil cleaning. If this is not available Fantastic Spray cleaner used in kitchens and bathrooms works quite well. Remove dirt and excess cleaner by slowly pouring warm water into fins. Do not allow the water to enter any electrical connections or components. As an added precaution cover the motor with one of the cloth rags to protect it from the water.
6… With cover, rear grille, and front grilles removed locate fan motor for oil holes. Add a few drops of oil to each end of the motor body. Use a general purpose (3in1) oil or clean motor oil. A #30 oil is sufficient. Three or four drops on both ends of the motor body are sufficient. Add the oil slowly, pausing a few seconds between each drop. If added too quickly over-lubrication will result.
7… Straighten any bent fins. Use a fin comb if available. If no fin comb then use something soft such as a Popsicle stick. Straightening the fins will increase the efficiency of the airflow through the coils. Use caution as these coils are filled with high-pressure refrigerant.
8… Wipe any dirt from fan blade using a soft rag. Do not bend blades. This would cause a vibration that would harm the motor.
9… Vacuum all surfaces including front and back of grille assembly. Vacuum underside of metal cover. Vacuum dirt buildup from base and any other exposed surfaces.
10… Drain any water left in the base and allow it to dry.
11… When completely dry plug in and test operation. On some models testing may require temporary override of bucket overflow switch. Test that cooling coil begins to sweat water within few minutes of operation. If everything appears okay unplug and reassemble. Insert water collection bucket slowly to avoid damaging float switch mechanism.
Jul 17, 2009 | Dehumidifiers
Whirlpool ED2SHAXM Side by Side Refrigerator Logo
125 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
