Question about JVC Cybercam GR-D72 Mini DV Digital Camcorder
Split screen and blurred vertical lines in view finder and LCD
My GR-D72 does not render the scene properly on the LCD monitor or the Viewfinder. All I see is a horizontally split screen with vertical colored lines that will change if I pan. You just can't make out the picture. The picture that is recorded on the tape is just like that seen on the LCD. When I play back a good tape, the picture and sound are normal. This sissue happened suddunly upon powering on after a couple week since the last time used. What could be the issue and how could it be fixed? Thanks for any good information. Elakkis
    Sniper:
  • 80 Answers
Elakkis, I am sorry you are having a problem with your JVC camcorder. Your camera more than likely has a defective CCD imager which is being replaced by JVC factory service at no charge because of a problem with the Sony CCD chip being used. Call JVC and arrange to send the camera to them. Hope this helps you! Joe Weibel Custom Electronics (customelectronics.org)
Posted on Feb 15, 2007
Fujifilm FinePix S1600 The monitor display is not working. Can it be replaced and if so how easy is it?
It could be that you have it set for EVF which means that you are using the tiny view finder instead of the LCD screen? It should have a button close to the view finder labeled EVF/LCD, you can alternate between the LCD screen or the tiny viewfinder? This function if mainly to conserve battery power or if you are out in the sun and cannot frame a shot and so you use the view finder like the old cameras, hope this might help you?
Dec 09, 2014 | FUJIFILM Cameras
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
Why is my viewfinder black when the camera is on and able to take pictures using the LCD screen?
some camera will inactive the electronic view finder if you shot through the lcd monitor, try to find out in the manual book about shooting trough view finder.
May 04, 2013 | Canon PowerShot SX40 HS--Black
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
Gr-d72 jvc camcorder
The ccd image sensor is on its way out,very soon there will be no picture.Get the ccd base assy. replaced.
Aug 30, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Black LCD and Viewfinder
I have the similar problem as above...Canon 5D
When camera is turned on the viewfinder is black. All other functions appear to be working correctly. I can view pictures on the card. I take a picture and it views on the screen and the spec's come up on the botton of the view finder but the viewfinder is 90 black with a bit of blur. Is this the censor or a mirror...?
Is this fixable and at what approximate cost? Would it be cheaper to replace?
Jul 31, 2008 | Canon PowerShot S2 IS Digital Camera
No playback on JVC GR-D72
It souunds like the problem is in the Vid-PC connection. I suggest you start by downloading the latest version of whatever software you have used to capture and view.
Also - uninstall any hardware in the PC that is used to capture (just remove from system device list) and then restart the PC and let it detect and re-install.
If you don't know how to do these steps, then you'll need geek help.
Oct 28, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Only vertical Lines Appearing
You are one of the lucky ones with a defective ccd, the electronic chip in the lens assembly that makes the image. Actually if you ship this to JVC before October they are repairing this problem at no charge because of a batch failure with this part. Go to jvcservice.com to get info. Good luck, magic seadog
Jul 23, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Multi-coloured vertical lines on LCD screen and view finder
Hello, there is a chance for the Sony recall. Please contact your nearest Authorized Sony Service. If you need more info please advice.
Mar 09, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Image being displayed is all colored vertical lines
I had this problem a lot on Labtops. The problem is that it has been unliquifed in the screen. This means that the screen has been damaged or has got really hot. Also its has been on for along time. LCDs go bad real quick and can be a hassle when you need the infomation in the thing and have no display. When I had this problem on my labtop, I used the external bay to use another monitor so I can work on it. So I say that nothing can be done to fix it. The only way to see your stuff on there is to use the video out on the recorder and try to check your stuff. That multicolor lines you saw is becoming major right now in LCD displays. I hope this solves your problem.
Nov 13, 2006 | JVC GR-D22U Camcorder
JVC Cybercam GR-D72 Mini DV Digital Camcorder Logo
246 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
