Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Replaced failed lamp but tv still thinks lamp is bad. Tried reset already.
I can't get it to work after replacing the bad lamp with a brand new one. I followed all the instructions in the manual exactly and it was a simple procedure. No picture/no sound/then red light comes on as tv shuts itself off. Reset did not help.
  • grantjw May 11, 2010
    The bulb connecting is fine, I saw a thread on that and mine was unseated, but I fixed it. Also the error code is 34
    Novelist:
  • 192 Answers
Turn on the set and let it shut down. push in the Menu and Device (or input, I don't have a schematic in front of me) buttons on the front of the set at the same time and hold until the green light starts flashing. Then release. There will be two different sets of flashes, such as, 3 and 6. The code 12 means the set is opperating fine. The other codes will tell you what part of the set needs repaired. Also, remove the bulb and check the ballast connection to the bulb. I find the connection for the bulb bent over when a customer replaces the lamp sometimes. Let me know what you find and we can go from there.
Posted on Feb 11, 2007
SOURCE:
New member here. I have a 62" DLP Mitsubishi model #WD6252. I've already replaced my lamp AND ballast and continue to have the solid red lamp status indicator. I've made sure the connection from th
Your color wheel is failing or has failed. the red light ONLY means the lamp cannot light or was forced to shut down. it means nothing about the lamp or ballast specifically.
If your color wheel isnt spinning up correctly or you have a stuck fan somewhere, the lamp will be shut down immediately upon startup.
Id check to see if the color wheel is stuck or if its getting stuck.
Dec 17, 2014 | Mitsubishi WD-62525 62" Rear Projection...
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Dec 08, 2012 | Televison & Video
I've tried to reset the lamp timer and my tv still wont work. What else can i try?
Have you tried replacing the lamp? If not, I would start there. Also, after replacing the lamp, make sure that the lamp door gets put back on or it will not come on. There is a safety switch that won't allow the tv to come on when that door is off. If you have already replaced the lamp w/ a new one and you are getting the same problem, then the problem could either be on the lamp ballast, or power supply board. Some tests would have to be made by a tech to determine exactly where the problem is. It sure does sound like a bad lamp though.
Sep 04, 2010 | Panasonic PT-50DL54 50" Rear Projection...
I had the bulb blow out in my Sony 60" projection TV. I replaced the bulb and with in 2 weeks I had the on screen notice appear that the bulb was failing. I returned that bulb for another one but the on...
Have you reseted the lamp timer of your tv? if not, you should do it, because it's just adding more and more hours to it to the ones it already had and it's indicating the tv that the lamp is going out, reset the lamp timer and you should be fine, if not, it's probable you might have a defective ballast which are not expensive, they're way cheaper than a lamp, they're running around 70 dlls
Jun 29, 2009 | Televison & Video
Replaced bad lamp on t.v. and was told there is a reset button
the reset lamp time in in your users manual, and or should come with the new lamp..
Jan 09, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
I have a mitsubishi WD-52525 DLP Tv; I replaced the lamp, powered on the system, I hear the fan go on, the green wait light goes solid after a few seconds and a few minutes later the lamp light goes solid...
Chances are the lamp is not bad. Is the lamp door reseated properly? The is an interlock on that door that must be activated in order for the set to turn on. If the unit was woking before the lamp went out this may be the problem
Nov 26, 2008 | Televison & Video
I have a Samsung 61 inch DLP tv. Was very happy with it for the past 3 years. Lamp went out in Feb. Got a new one and replaced. A few weeks ago, it started making a screeching noise. Fans were ok,...
It is b.s. but it's not only samsung that have poor reliability. At least they have some customer service. Some new brands are a nightmare. I would suggest changing the ballast first, and if that doesn't do it, you're probably looking at a dmd board which is very expensive. Only other thing I can say is to try removing and reseating the lamp switch again. Also listen for the color wheel to start up a few seconds after you push power on. Color wheel is started by dmd board, lamp is driven by ballast.
Jun 12, 2008 | Samsung Televison & Video
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
138 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
