Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor has no power or wont turn on
I got a 2001fp of the internet and it wont turn on. I checked the power cable and the cable works. then monitor dose nothing no green lite or anything. could it be the power supply inside the monitor, and if it is can it be replaced.
  • Anonymous Jan 06, 2008
    I'm having the same problem. I push the power button and nothing.....
  • rjlandscape Oct 17, 2008
    The power light does not come on. The cables are good. Is there a local monitor repair shop or do we need to ship it to you.How much is the rate for a tech to look at the computer? Please let us know at your earliest.
  • 624 Answers
Gumpster, Yes, there are replaceable parts inside, however, the question is can it be fixed economically. If this was supposed to be working I would return it as fast as you can. If not then it could be your logic board ($80 approx) or your external power supply ($25 approx). If you decide to pursue this take proper precautions to protect yourself and the monitor components. Let us know how things go and please don?t forget to rate this post.
Posted on Feb 25, 2007
SOURCE:
Dell UltraSharp 2001FP (Gray) 20.1"
This monitor uses a power supply not just a cord . You can get one on e-bay very cheat . Just type out 2001fp an choose the person you want to get it from .
Feb 09, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell Monitor 2001FP has a circular power supply connection Where can i get one of these??
They are on e-bay for very little . Just type in 2001fp an you will get people who have new power supply .
Feb 08, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
2001fp the screen is black the power light is green. It will flash when first turned on but wont light up. I have it apart and I don't see any obvious bad caps
The problem can be in the inverter board: http://www.lcdrepair.us/2001FP-INVERTER.html
You can try replacing the inverter and hope that the problem is not in the backlight assemblies. You need the test lamps to verify the function of the inverter board. Do you get steady 20vdc feeding the inverter. You can also try heating up the two black electrolytic caps on the inverter board to see if the inverter will fire up using hair dryer, when bad caps with high ESR are heat up the ESR will go down.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 11, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
DELL POWER SUPPLY FOR MONITOR 2001FP
Although this site does not list the 2001fp speciffically it was very helpfull for me to learn about caps on power supply boards. Follow the steps of the "tutor" at the bottom of the page (after the testamonials) and its pretty straight forward.
http://www.lcdalternatives.com/
Jul 04, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
20V AC power adapter for Dell 2001FP 20" LCD monitor
try to contact dell spare parts department. they may give you a good price.
Feb 01, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP always in sleep mode.
I have a dell ultrasharp and at first it would not come on at all. Open it up and found loose connection on plug connectors 3 pin. Soldered and would come up but blinks in and out sometimes take longer than other times. Big Capacitor when open up Power supply was leaky. Check for bad caps
Sep 08, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
116 people viewed this question
Clive
Clive
Alun Cox
