Question about Fujitsu ScanSnap Manager
Scan with scansnap over mapped network drive
I have Fujitsu s510 and have 2 problems with scansnap:
1. I cannot scan over a mapped network drive
2. I need scanning to a folder where I choose without change the setting
scansnap root folder, just like ACDSee that support twain driver.
Do you have a suggest?
3 Suggested Answers
SOURCE: noise when scanning document
Visually check the clutch spring (located on the left side of the pickup roller shaft, just before the gear). If the spring is deformed or broken, replace the entire pickup roller shaft. The part you need to order are shown below. You will also need a small 'C' clip. I do not know if the clip comes ith the shaft or the gear...
PA03360-Y110
Pick shaft
PA03360-Y112
Pick Bearing ‘M’
PA03360-Y107
Clutch
PA03360-Y106
Clutch Spring
PA03360-Y105
Pick Gear
Regards,
Eric F.
Posted on Feb 06, 2009
  • 6 Answers
SOURCE: My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
Posted on Jul 13, 2009
Unable to Scan to print
As from your question it is understood that, you have not correctly uninstalled all the software and drivers related to Fujitsu Scansnap S1500M printer from the computer. So to help you uninstall it correctly and reinstall it again, please follow the step-by-step instructions mention under 'Uninstalling on a Windows OS' on page.no.355. and to reinstall it follow the instructions mention under 'Installing Scansnap Manager on Windows' on page.no.47 from the user manual link given below:
http://www.fujitsu.com/downloads/COMP/fcpa/scanners/s1500_s1500m_ops-guide.pdf
If issue persists, you are advised to contact printer manufacturer from the below link:
http://www.fujitsu.com/global/support/
GuruAid.com
Mar 16, 2016 | Fujitsu ScanSnap S1500M
Everytime i try to scan any document using my Fujitsu ScanSnap S510, the blue light on the front-right side of the device blinks 3 or 4 times and nothing else happens (the document, therefore, is NOT...
I had a similar problem. All I did was unplug the USB cable from the scanner and reattach it. Sometimes I would have to close scansnap (blue "S" icon in the sys tray at the bottom right), and then power on the scanner.
Nov 28, 2011 | Fujitsu ScanSnap S510
My ScanSnap has worked flawlessly for years. I just tried to scan and got the following message: undefined error occurred.(0xffffdcf7) Won't scan. Tried to reboot - no luck. Let me know...
The same thing happened to me. In a nutshell, you have to install new drivers. Have you recently upgraded your system to SnowLeopard or Lion? I did, and that's what went wrong.
To do:
1. Make sure you have the latest ScanSnap manager: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac.html
Install that.
2. Get the Lion update: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac-mg22.html
Install that.
3. Open the new ScanSnap Manager (v 2.2). Delete the old one from your dock, so you don't get confused.
4. Scan away.
Aug 06, 2011 | Fujitsu ScanSnap S510
My scanner keeps flashing and not pulling the paper through, I cannot seem to figure out why it will not scan. It does this quite often, what is the problem that is causing this? Scansnap S1500
Go to msconfig or if you have a registry cleaner, go to the startup menu. Disable and ssmgr (scansnap manager in pfu). Reboot. Open the ScanSnap 1500 and then start the ScanSnap manager. The scanner is now ready to scan.
Jan 26, 2011 | Fujitsu ScanSnap Manager
Scanner will not pull the paper all the way through & scan. Scanner says not valid folder to save image is selected . Set the save folder for the scanned image data. I don't know what to do
Try to scan by using the quick menu as I described below:
Check for the ScanSnap Manager icon on the taskbar.
5d5f1b3.jpg Right click the mouse button over that ScanSnap Manager icon.
Select “Scan Button Settings” from the Right-Click Menu.
2344c41.jpg Select the “Use Quick Menu” check box (it must be checked).
Load the document in the ScanSnap which you want to scan.
Pres the “scan” button on the ScanSnap.
Click the “Scan to folder” icon in the quick menu when scanning is completed.
The “Scan to Folder” dialog box appears.
Check the scanned image in the “Scan to Folder” dialog box.
By clicking save buton, save the scanned data in a specified folder which you select chancing the filename as you want.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 09, 2010 | Fujitsu ScanSnap Manager
I can not scan to folder now, I am using scansnap s510m, please guide how to solve this problem. I am using macbookpro
Click and hold down the mouse button over the ScanSnap Manager Icon in the Dock menu and confirm that Quick Menu is checked.
load the document you want to scan
press the scan button
when scanning is complete the snapscan quick menu appears
place the curser on the scan2 folder
click it in the action list
a preview window appears
You can change the file name and the folder you want to put it in. You can also resize it here by dragging the lower right corner
here is the manual
http://www.fujitsu.ca/pdf/scanners/manual/operator/s510/S510M_Owner_P3PC-1942-01ENZ0.pdf
Dec 31, 2009 | Fujitsu ScanSnap Manager
PFUSSMON HAS STOPPED WORKING ON MY SCANSNAP S1500
Find your specific scansnap product and update it:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
A user had a similar issue and I found this update for the scansnap S1500 manager:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
This occurs with certain Intel dual core processors, so you might be effected accordingly.
--Rob
Jul 08, 2009 | Fujitsu ScanSnap Manager
May 26, 2009 | Fujitsu ScanSnap Manager
PDF file cannot be found
install acrober reader again and try it.
also u can try to scan document in jpg format.
Mar 31, 2008 | Fujitsu ScanSnap Manager
Computers & Internet Logo
1,960 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
