Question about Printronix LaserLine L1524 Printer
I have problem with Printronix showing error 25 Encoder fail
  • 31 Answers
Call a technician. This is the resolution in my manual for the problem: "Defective or dirty encoder needs to be replaced. Call a technician."
Sorry! This thing has some sensors that do go bad on occasion.
Posted on May 29, 2009
Hardware twsting msg ??
Your Main Board (called a CMX) has failed. You can google
"PRINTRONIX 157450-991 PWB,CMX,V 5.5 40MHZ,EXCHANGE,P5000 "
For the part, but the part will require software either pre-loaded or you will have to get the file to load, ask about that before you purchase this or it will not work when you get it.
Apr 16, 2015 | Printronix P5000 Printer
Printronix error b22 decompressed size
flash ic having problem logic crad have to change
Feb 04, 2014 | Printronix P7005/p7010/7205 Ultra Capacity...
WELD NOT FOUND ERROR
Sounds like a failing weld sensor. Clean it first its on the left side, you can see it when the ribbon is out. If that doesn't help replace it.
May 08, 2013 | Printronix LineJet® P7010 Matrix Printer
When i was replace the trailing cable my plotter writing the system error:86:01 how to solve
86:01 fatal error code resetable with power cycle- error is down to encoder not reading/ blockage on media path - encoder strip missing
1. clean and clear accuride rails ( long silver bar )
2. Clean or replace encoder strip
3. clean or replace encoder sensor
if all else fails contact Belmonte.co.uk for fast response
Jan 02, 2013 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
25 Encoder fail
1. The tractor encoder signal is faulty.
a. Clean any toner or paper dust out of the encoder sensor.
b. Inspect the tractor encoder wheel for damage. Replace it if necessary.
c. The encoder sensor is faulty. Replace the tractor encoder board or the entire tractor
unit.
d. The fuser drive clutch is slipping; replace it.
e. Replace the Engine Controller Board.
f. Replace the encoder cable.
�� Tractor Encoder. The Tractor Encoder Board has two optical sensors that sense the
1/8 inch and 1/16 inch slots in the Encoder Wheels. These pulses are sent to the Engine
Controller Board and are used to monitor and control print location and paper movement.
Location
Remove the Tractor Encoder Cover by removing 1 Screw.
NOTE: Upon installation, the groove on the bottom of the Encoder Cover should
straddle the top of the left end of the Tractor Frame.
Left side of printer, just left of the tractor assy.
Dec 05, 2008 | Printronix LaserLine L1524 Printer
"Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
Jul 06, 2008 | Printronix Line Matrix P5005B Printer
Printronix LaserLine L1524 Printer Logo
107 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
