Question about Sony Handycam CCD-TRV87 Camcorder
Tape ejects every 60 to 90 seconds regardless of the mode the camera is in
As long as there is power, the camera ejects the tape (even if there is no tape). This happens while recording, playing back, or powered off or powered on with no action taking place. Of course removal of the battery solves that. This makes taping or reviewing tape impossible. Travel with the camera in the carring case can only be performed without a battery because the tape holder attempts to eject & locks up the camera. The camera gives no error code, just the polite bell to inform you that the tape will eject & then it does so. Please advise?
    Sniper:
  • 80 Answers
The flip up cover over the cassette housing has the "eject" button built into it. Sony has had problems with the flexible harness that connects this door to the camera body. The harness rubs against the metal frame of the camera and causes various malfunctions such as the constant eject symptom you are having. Sony service in Laredo, TX can repair this for you, it is no big deal. Good luck, this is a nice camera! Joe Weibel customelectronics.org
Posted on Feb 16, 2007
SOURCE:
Unit will not stay on. Turn power on unit with no tape. After several seconds cycles off. I am using the aux. to monitor a cctv camera.
VCR's with faulty mechanisms will power down to prevent tape damage. Checking inside might reveal damage to the tape mechanism. Even if the mechanism isn't damaged the VCR has a device called the mode switch. These tell the electronics what position the mechanism is in. If that goes faulty the electronics can think that mechanism is in say playback mode, even when it's in eject mode. So when it detects no tape tries to stop and eject the tape. Since it can't carry out this it shuts the entire video down to be on the safe side and prevent further damage.
Mar 15, 2015 | Emerson EWV404 VCR
Safe mode when ejecting tape
hi,
its a moisture problem, if you are tecenition then open your camera and clean the power cable properly and fix it properly , you got magic,and its 110% working
Sep 27, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
Manual eject option for trv320? No tape in it. Won't open so I can put one in.
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
Aug 06, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony Handi-Cam TR57. After being stored for a couple of weeks,the tape door, with tape in place has become stuck in the up position, and the tape cannot be either removed or pushed back down. The tape...
NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required .
Jul 31, 2009 | Sony Video Cameras
Tape stuck in unit
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined and I don't recommend using the tape in the camera again even if you manually wind it forward past the problem area.
May 10, 2009 | Sony Handycam CCD-TRV318 Camcorder
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Feb 23, 2009 | JVC GR-DV800U Camcorder
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Jan 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Open Questions:
See all Sony Handycam CCD-TRV87 Camcorder Questions
Sony Handycam CCD-TRV87 Camcorder Logo
214 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
