Question about Neff B1641 Single circotherm super Electric Oven
B1641 Fan Element Renewal.
Is it possible/advisable to renew the element from inside the oven by removing the back plate, or do I have to remove the entire oven in order to access the element ?
Is the door easily removeable ?
I have no Operating/Servicing instructions to refer to.
Ours is a 2004 model.
Any advice would be appreciated.
  • Neff Master
  • 3,463 Answers
If you can see the element once you have removed the inside rear panel, then remove any screws that you can see, and ease the element forward, pull the wires off, but do not let them slip behind the rear wall of the oven, or it means removing the whole oven, to fit the wires back on.
If you cannot see the screws, or they are fastened from the rear, then it will have to come out of the housing.
Hope this helps.
Please leave feeedback.
Posted on Dec 06, 2008
How do i replace the heating element in a diplomat aca3200 oven?
make sure the oven is switched off.remove all trays etc from oven,remove 2 posidrive screws from bottom of fan plate,remove fan plate,the element is around the fan,remove 2 posi screws from where the element goes through the side of oven and the one screw that holds the top of the element to the back of the oven.slowly pull the element out and remove the 2 poz and neg spade connectors.refit as removed.
Dec 30, 2010 | Ovens
Tip
Common heating faults with Neff B1641 Single electric oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1641 Single circotherm super...
Neff circotherm doudle oven main oven fan working
It is more than likely that the oven element has failed.
You will it located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 09, 2010 | Neff B1641 Single circotherm super...
How do I change the oven element on a belling format 800 oven
1, If your Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jan 03, 2010 | Belling XOU492 Electric Double Oven
NEFF B1320 OVEN DOES NOT HEAT UP. POWER ON FAN WORKING
For all Free appliance repair videos visit our VIDEOTUTORIALS neff video
1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 25, 2009 | Neff B1641 Single circotherm super...
Oven not heating up! Fan works. Grill works OK. Don't know what model it is? It's stainless with black hideaway buttons. It's a built-in Neff single oven. We had just roasted a duck, everything was...
Hi, The main problem I find with this fault is the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven. Thanks.
Jun 15, 2009 | Neff B1641 Single circotherm super...
Problems with the fan on neff b1641 oven
Hi, from what you describing it can only be either the oven element (located behind the back plate inside the oven, hold by 6 screws, 2 at the top, 2 at the bottom and 2 on the sides). Switch off the cooker, remove this panel and have a look at the element, looking for unsual bends, corrosion, or burn marks. The other possibility is the safety stat located near the element connections at the back of the oven. Pull the oven out, remove the back chassis panel and inspect the stat.
Cheers
Feb 19, 2009 | Neff B1641 Single circotherm super...
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Hotpoint built in oven top grill element renewal
yes they are - two nuts on posts that stick out from the base plate plus one screw inside oven opposite the base plate
Sep 09, 2008 | Hotpoint Ovens
Oven no heat
check fan element hasnt blown remove back plate in oven after switching off from mains of course and remove the retaining screws and you will see a fan and around that the element it will be obvious to see if its blown as there will be a hole on the casing if so replace and viola.
Jan 16, 2008 | Neff B1641 Single circotherm super...
Neff B1641 Single circotherm super Electric Oven Logo
254 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
