Question about Printronix LaserLine L1524 Printer
25 Encoder fail
I have Printronix L1524 showing "25 Encoder fail"
Would you please kindly advise the location of encoder? thanks
    Scholar:
  • 34 Answers
1. The tractor encoder signal is faulty.
a. Clean any toner or paper dust out of the encoder sensor.
b. Inspect the tractor encoder wheel for damage. Replace it if necessary.
c. The encoder sensor is faulty. Replace the tractor encoder board or the entire tractor
unit.
d. The fuser drive clutch is slipping; replace it.
e. Replace the Engine Controller Board.
f. Replace the encoder cable.
�� Tractor Encoder. The Tractor Encoder Board has two optical sensors that sense the
1/8 inch and 1/16 inch slots in the Encoder Wheels. These pulses are sent to the Engine
Controller Board and are used to monitor and control print location and paper movement.
Location
Remove the Tractor Encoder Cover by removing 1 Screw.
NOTE: Upon installation, the groove on the bottom of the Encoder Cover should
straddle the top of the left end of the Tractor Frame.
Left side of printer, just left of the tractor assy.
Posted on Jul 07, 2009
My printer shows "Hardware Error
  1. Remove the power cord from the unit.
  2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
Figure 1: Out-of-position encoder strip
  1. Gently move the top part of the printer belt to the right.
  2. Using your index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
new_note.jpg Note: There is a small slot that the encoder strip fits into, which is located on the back of the ink cartridge carrier.
While working with the encoder strip, check it for dust or any unclean spots. If any detected, try to clean the strip by wiping it gently with clean cloth.
  1. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
  2. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
Figure 2: Correctly seated encoder strip
new_note.jpg Note: If the encoder strip moves at all, it has NOT been repositioned correctly.
  1. Once the encoder strip has been re-seated, close the lid to the unit.
  2. Re-connect the power supply to the All-In-One.
  3. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
Feb 18, 2011 | Dell A940 All-In-One InkJet Printer
Printronix L1524 is printing very faded labels. OPC Drum is brand new. Everything looks good, in my opinion. I believe it it is the wire below the OPC Drum and the label that is the culprit. any help?
This can be caused by a worn corona transfer wire. It can also be caused by the follow;
Developer starter toner is weak, change developer.
Laser Sight Glass is dirty, Clean, it is located under the top of the printer.
Transfer unit, bad, or poor grounding.
for more info, call BNL 562-688-2373
Dec 24, 2009 | Printronix LaserLine L1524 Printer
Our L1524 passes the diagnostics tests when we turn it on but gets stuck "Loading Fonts" with a 8344 Failed error. Ideas/Solutions?
Remove the controller boad in the back. You will see 4 SIMM'S, remove, and reset them. if this does not solve your problem, call BNL 562-688-2373 for free tech support. Ben
Nov 13, 2009 | Printronix LaserLine L1524 Printer
My printer is not printing and it's saying hardware error 0502and i need it for my school work could someone help please
This one's a bit tricky, but fixable. Here's what I found:
Re-position the Encoder Strip on your all in one Printer
To re-position the encoder strip, perform the following steps:
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
NOTE
NOTE: There is a small slot that the encoder strip fits into, which is going to be located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the lid to the unit.
9. Re-connect the power supply to the All-In-One.
10. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
Other faults that can bring up this error is a carriage rail that needs cleaning and oiling (so you might want to do that while your inside the thing), and also obstructions to the paper ways. Try removing paper jams, and put the printer upside down to shake loose anything that might jam the mechanism. Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 01, 2009 | Dell A940 All-In-One InkJet Printer
Pc error 0x8007274d
Do you get this when you go to youtube?
If so it is a numbers don't match error.
To work around this problem, make sure that the Windows Media Encoder is running.
Check the port number that the encoder is using for the stream. This port number is listed at the bottom of the encoder in the stream reference section. Also check the port number in the Windows Media Administrator for the multicast station’s stream source. The port number for the stream source on the server and on the encoder should be the same.
Hope this helps, good fortune, please leave rating, thank you kindly
Apr 26, 2009 | Computers & Internet
Where is the 4x4 encoder motor sensor located on my 03 sierra
the encoder motor sensor is inside the encoder motor. the encoder is located at the transfer case. Remove the encoder and by part number 88962315 this is the sensor. you will have to retime the motor after
hope this helps
Feb 16, 2009 | 2003 GMC Sierra
I have problem with Printronix showing error 25 Encoder fail
Call a technician. This is the resolution in my manual for the problem: "Defective or dirty encoder needs to be replaced. Call a technician."
Sorry! This thing has some sensors that do go bad on occasion.
Dec 05, 2008 | Printronix LaserLine L1524 Printer
A THIN plastic strip about 1/4 X 16 INCHES LONG HAS BECOME SEPRATED FROM MY X4270 PLEASE ADVISE HOW TO FIX
This clear plastic strip is responsible for telling the print head where it is horizontally. Pls note that it has black stripes almost like bar codes. Both ends of this encoder strip normally would have holes for hooking up to lock tabs on both ends. What is important is that this strip is embedded in a slot at the back of the print head that reads the bar codes/locations.
This page may shed additional insights.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 21, 2008 | Lexmark Office Equipment & Supplies
Hardware error:0502
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Apr 05, 2008 | Dell A940 All-In-One InkJet Printer
Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
May 30, 2007 | Printronix LaserLine L1524 Printer
Printronix LaserLine L1524 Printer Logo
186 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
