How do I programme it to save my trips that I will do again
  • tnmatt May 11, 2010
    Tell me more about your problem. Not about your pc, only what you want it to do.
  • 59 Answers
Im sorry What are you on about what are you trying to program ?
Posted on Dec 07, 2008
Occasionally during programme main circuit breaker trips
If it was working fine in the past and just started to trip, then try replacing the breaker with a new one. Breakers get weak over time and trip occasionally.
Feb 08, 2016 | Washing Machines
Tip
Air Conditioning Programmable Thermostats - Great for Heating and Cooling
Programmable thermostats contribute to overall system performance, maximizing energy savings while providing complete comfort control. They also allow flexibility to homeowners because they can be programmed to match their lifestyle. Programmable thermostats save energy by turning down the cooling and heating system at night or at times when your home is typically unoccupied.
Did you know that properly using a programmable thermostat in your home is one of the easiest ways you can save energy, money. Homeowners can save about $180 a year by properly setting their programmable thermostats and maintaining those settings. They can achieve significant energy and money savings that are possible through the proper use of your programmable thermostat. Programmable thermostats do two things:
(1) Compare the thermometer reading of a room's temperature to the "ideal" thermostat temperature you select.
(2) Give start-and-stop commands to the heating or cooling system in order to achieve an indoor temperature that is as close to your "ideal" thermostat setting as possible.
Your savings will largely depend on the length of your energy saving program periods and the temperatures set. For example, an energy saving period of 10 hours with the temperature set back 10° will save more than a 5 hour energy saving period with the temperature set back 5°. By maintaining the highest or lowest required temperatures for four or five hours a day instead of 24 hours, a programmable thermostat can pay for itself in energy saved within four years.
A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home. The precise temperature control of a programmable, energy-saving thermostat saves wear and tear on high-efficiency heating and cooling equipment by properly cycling the equipment. A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home.
Controlling your heating more effectively could save you up to 17% on your heating costs. In fact, during the winter you can save about 3 percent of your heating costs for every degree you lower your thermostat. Begin lowering your heating bill immediately with the pre-programmed 7-day schedule, or modify the programming to suit your lifestyle. By delivering the heating or cooling when you need it, and optimizing temperature for activity, sleep and times you are away you can maximize your comfort level and save energy.
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3916016-honeywell_th8320u_thermostat
http://www.fixya.com/support/r3913560-honeywell_th8110u1003
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
http://www.fixya.com/support/r3898732-lux_thermostat_500
http://www.fixya.com/support/r3869033-replacing_thermostat
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3584298-air_conditioning_programmable_thermostat
on Dec 06, 2009 | Heating & Cooling
I need help programming my baofeng 997s
To programme a repeater. VFO mode & curson on top line of display. Enter freq eg 147.250. Go menu button change settings like offset, tone. In menu delete channel required eg 000. In menu below that, choose mem channel now 000 & it saves receive freq.
Exit. press *SCN button so R appears on display. Save as 000 again but this time it stores TX freq. In other words, you save RX first, then exit.Add * so R appears in display second time round and save again TX freq. Go to channel mode and see it is in 000.
I might do a video to help people. Its the same process with UV5r and other Baofeng. Simplex you just save in one operation because TX is RX.
Aug 08, 2014 | Radio Communications
No readout from the digital programme selector when I open the door
RUN the Test MODE diagnostic, and see what is the problem, see your instruction manual. If you do not have download free www.fitness.manualsonline.com or www.retrevo.com
God bless you
Jun 18, 2012 | Dishwashers
ERROR MESSAGE RECEIVED FOR HARD DRIVE SAVED PROGRAM
your program getting virus infected so you install a one antivirus full verion update it and scan and try
May 30, 2012 | Panasonic Televison & Video
My smeg dishwasher stopped during a cycle and warning lights E2 come on. suggesting that it has drawn too much water and to contact customer technical services, any idea what i need to do
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
Jan 10, 2010 | Smeg Dishwashers
The washer hasnt run through its full spin the electric tripped so i dont how 2 start the programm again 2 finish the cyle
turn it on and select the spin cycle again if it trips again the moter has a fault and u will need to get this checked
Jul 29, 2009 | Washing Machines
My Bosch Classixx 1200 washer causes the household RCD to trip
The first thing I would recommend u do is to remove the motor and check the carbons for wear, Their should be at least 3mm of carbon showing, any less then u shud replace.
The other possibility is a faulty heater element, u cud try it with the element disconnected, if it does not trip then the element is faulty.
Plz rate my solution.
thanks.
Dec 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
- won;t email pictures
it may be that the software isn't correctly intergrated with your email programme, you may have to look in settings to see if there are any options for mail programmes. Failing that uninstal the software and reinstall again and see if that cures it, or the other option is to copy the pic that it takes assumably saving it in my pics after it has done so and pasting it into your email programme. If you only send and receive mail through your providers web site, that is why it wont work as you have to use outlook express outlook or another email programme.
Jun 20, 2007 | Logitech QuickCam Pro 5000 Webcam
Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Aug 21, 2006 | Hotpoint 23 in. BF50 Built-in Dishwasher
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
