Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Fitting internal bin catch on dco7
Couldnt open bin to empty it husband forced open broke catch that keeps bin closed have got new parts but can't get the bottom catch out. could force but dont want to damage housing any idea's? do i need a special tool? help i love my dyson!!
  • shazirving Dec 05, 2008
    thanks for the help i actually got parts from ebay(only £4.20 cheaper than replacing the whole thing) so contacted the sellerwho told me how to remove it. it was the bottom catch that holds the bin shut that had broken when it was forced open but intially it was the rod right at the top that had broken. for anyone else who has the same problem as i had just slide a screwdriver down the side of it and gently lever out.
  • 107 Answers
Yea I can definitely help you. On the tope of the cyclone there are three screws that will allow you to take off the top off the cyclone. You should see a long black rod going down the middle of the cylcone. It is difficult and you may have to detach it from the top i cant remember as usually i just replace the whole thing and only done that 3 times. You take a flash light and you can see where the rod goes in and just push it down and it should pop open. ill check back on monday to see if you replied or need more help.
Posted on Dec 05, 2008
When I tried to open the clear bin to empty it, the bottom did not drop open and now I can't push the cyclone down. What do I need to do to fix this?
I can't be specific without knowing your model but the crud and gunk that collects inside the dirt bin can restrict the door from opening and closing properly. If the door isnt closed properly the dirt bin may not fit back into the vacuum.
Jan 20, 2017 | Vacuums
I CAN'T REMOVE THE BIN TO EMPTY THE DIRT. iT SEEMS TO BE STUCK hOW CAN I GET IT OFF THE VACUUM?
Hi Ethel, it's Jack at Dyson.
Removing DC07's clear bin and cyclone to empty the machine after use should be quick and easy. If it currently seems jammed, it's likely that either the cyclone and clear bin were not correctly positioned the last time they were replaced, or that the release catch has been damaged in some way.
It would be best if you can give us a call to speak directly with our experts - they should be able to talk you through freeing the bin with some simple troubleshooting checks.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you and providing further assistance.
Jan 30, 2015 | Dyson DCO7 Animal Bagless Upright Cyclonic...
The closing mechanism on my dyson dc59 comes open when I touch it. It only has one red closure tab is it suppose to have two
Hi there, it's Jack at Dyson.
DC59's bin base is engineered to open when you press down on the red release catch, as shown in our Getting started guide:
The bin base should shut securely after you've emptied the bin. If you're concerned it's not staying closed, we'd appreciate the opportunity to help you check everything is correct with your machine. If a replacement part is needed, we can also confirm if this is covered under our 2-year cordless guarantee.
When you have your machine easily to hand, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can help.
Oct 05, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
How do I line up centre rod on dco7 when flap is closed
Hi.
I assume you have unscrewed the handle from tje cyclone whilst the bin is still attached. Its a common mistake to make. There is no wY that you can open that flap without the rod.
Next time ensure you take the bin off first.
Right, the only way you can get the flap open is to use the rod.
Unscrew thevrod from the handle and then hold the rod above the cyclone and insert the rod into the cyclone lining it up with the catch at the bottom. once its in pree the button and flap will open. Whilst pressing the button use your other hand to lift the cyclone off the ground so the flap will have space to open.
Jun 08, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson canister won't fit snugly
I am sorry to hear your canister is not fitting properly. You may want to separate your cyclone assembly (the top purple portion of your canister) from the clear bin and reattach the components to ensure they are fitted together properly.
To do this, open the bottom of the clear bin, as if you were emptying it. Please be sure the bin is positioned over a trash receptacle in the event there is debris in the bin. Once the bottom of the bin is open please look at the back of your canister. Below the purple top of the canister and to the left of the debris inlet is a clear plastic loop that you can slip your index finger through. Just above this loop is a gray release catch . Using your thumb, press down on the gray release mechanism. At this point you should be able to gently pull the clear bin away from the cyclone assembly. After separating the pieces, briefly inspect them to confirm they are not damaged. If there is no obvious damage, close the base of the clear bin and place the bin on a hard flat surface. Next, carefully lower the cyclone assembly onto the clear bin. It may be helpful to use the red plastic piece on the back of your cyclone assembly and clear bin to line the pieces up correctly. You will hear a slight click once the pieces have been successfully reattached.
Please attempt to return the canister to the machine. If you are still not able to attach the canister successfully, please call us so we can provide further assistance. We can be reached at 1-866-693-9766 (US), 0800 298 0298 (UK), and 01-475-7109 (IE).
Best wishes,
Jessica
Jun 22, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
Where can i find an internal bin catch for a dyson dco7 animal
Hi Dave,
You can purchase genuine Dyson spares for your DC07 Animal directly from us by visiting www.dyson.com and clicking on 'Spares' (UK) or 'Parts' (US).
If you'd like to consult with one of our advisors in person before making a purchase, or to order over the phone, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Jan 15, 2012 | Dyson Vacuums
Dyson DC07 Clear Bin Flap will not release
I just received my replacement root cyclone in the mail today after waiting in the back-ordered status for three months. I positioned a butter knife in between the rubber gasket on the bottom flap lid and the bottom rim of the clear bin at the farthest point from the hinge and slowly and gently wiggled the knife between until the bottom flap just fell open. I examined the rubber gasket and it survived without injury and the bottom flap seals without any gaps...good luck
Jun 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The base of the clear bin won't open.
Just had the same problem. Finally realised what to do. Pull the long rod away from the top against its spring (by the rubber gaiter) and whilst holding it, undo the screw holding the long rod to the top trigger mechanism. Now you can wiggle the rod part free (careful of the plastic lug on the side opposite the screw). Now, you can look down through the cyclone whilst inserting the rod properly into the releaser at the bottom and open the base. Reassemble the rod into the top. NOW reinsert it into the cyclone with the base door OPEN and using two fingers locate the rod into the releaser lever. Now you can close the door. Phew. Hope this is clear enough as a guide.
Jan 28, 2009 | Dyson DCO7 Animal Bagless Upright Cyclonic...
Bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Oct 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How to replace dust bin lid
With the lid you need to force it on a little bit its tough plastic but dont force too much.
Removing with out breaking is harder. why do you need it off?
Jun 28, 2008 | Dyson DC14 All floors Bagless Upright...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
304 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
