Question about Microsoft Windows XP Professional
Ctrl+Alt+Del doesn't display task manager
When I press Ctrl+Alt+Del instead of task manager appearing it displays an error "Task manager disabled by the administrator" and the computer restarts automatically. I've done going to gpedit.msc and changing the settings but all seems to be fine. I cannot run my regedit so there is no point in messing with the registries and my cmd disappears when I try to run it. I think this problem is getting worse so any helps will be greatly appreaciated.
    Scholar:
  • 81 Answers
Hi!
welcome to Fixya,
you have a virus that name brontox if I'm not mistaken.
update or upgrade your anti virus. and free upgraded anti virus can help, like AVG 8.0
but your have big problem because when the anti virus trigger the dos mode it will automatically shut down your PC. like when you open your task manager or run the command prompt. so try this thing out and what happen.
Posted on Dec 05, 2008
The task bar disapeared
run you antivirus program
If CTRL+ESC didn't make it come back, then the program that displays the task bar most likely isn't running.
That program is often called the "Windows Shell", but it's really "explorer.exe". It's the program that not only displays the Taskbar, but also responds to the CTRL+ESC sequence.
The workaround: press CTRL+ALT+DEL to fire up the Task Manager. Now on the File menu, select New Task (Run...). Type in "explorer" and press OK. That should restart explorer and re-display your Taskbar.
hope this helps
Jul 01, 2012 | HP Computers & Internet
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
Had a virus got rid off it but now screen is white and cannot do anything with it
My emachine w3115 comes on but,will not display anything on the desktop. can not do a reboot on it and it wont run any disk . all i have is a background picture,
Press CTRL + ALT + DEL - the Task Manager should appear. If it does then click File, New Task (Run) and type explorer then hit enter, it should return to normal.
If the Task Manager doesn't appears or Explorer doesn't starts then the system is severely corrupted, you will have to reinstall Windows using the recovery cd.
Jul 26, 2011 | eMachines W3115 PC Desktop
No display in my desktop, pls help me
Hello
1. Open the run box. If you can't get to it by using the windows key or alt S, then hit ctrl alt del and open the task manager, file, new task.
2.Type explorer and press enter. The desktop should appear.
3.Is it happening on the administrator account only?
4.You might need a system restore.
5. Before you try a system restore, see if there are any conflicts, hardware and software. Look at the device manager for hardware conflicts and disable everything under the startup tab in msconfig to test for software conflicts.
6. If that doesn't work, backup all data and try the system restore.
THANK YOU
Jan 28, 2011 | Computers & Internet
My friends laptop starts up and only loads the wallpaper on the desktop homepage, no icons or start menu appear.
Don't worry when your friends laptop starts and if nothing is displayed then Press Ctrl Alt Del keys on your key board.Just see that you have pressed all the keys at same time or first press Ctrl then keep it pressed and with another finger press Alt and also keep it pressed and at last press Del key.
You will find task manager opened on the screen .There you will find File option ,click on it and select New task from the drop down.
Another dialog box will open type there explorer.exe and click OK.
Your problem will be fixed then.
Thanks,
Have a great day
Sep 17, 2010 | Computers & Internet
How to disable windows task manager?
Press Ctrl Alt & Del at the same time to pop up the Task manager. From right top corner press the computer sign and close - or then just ALT + F4...
May 28, 2010 | Computers & Internet
Left alt key not functioning in pagemaker
If you cannot access your Task Manager when Pressing the Ctrl+Alt+Del, this means you have a virus on your system which has disabled the task manager. If you have a good antivirus like Norton, Kaspersky or McAfee try scanning to detect the virus.
OR
Format your system, but before doing that makesure you backup your data before doing that.
Regards
Sep 16, 2009 | ASUS Eee PC 1000H Laptop
PRESS
CTRL+ALT AND BY HOLDING THESE KEYS PRESS DEL
Dec 13, 2008 | Microsoft Windows Vista Ultimate Edition
Ctrl+ALT+Del does not launch Task Manager on my MobilePro 900, why?
The Ctrl-alt-del short cut to the Task Manager is not on the MobilePro 900. To bring up Task Manager on the MobilePro 900, hold the "Alt" key and then tap the task bar with the stylus simultaneously. A menu with "Task Manager" and "Properties" will be displayed, select Task Manager.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Microsoft Windows XP Professional Logo
186 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
