Question about Toshiba 50H82 50" Rear Projection Television
Crazed Picture whern the set is first turned on.
When turning on the set, the picture is crazed and if left on three to five minutes the picture settles down. If when the set is first turned on, when picture in picture is selected, the main channel remains crazed but the other screen is normal. Move the other screen to main, the picture remains good as does the sound.
  • 1 more comment
  • garyc349 Jan 03, 2009
    I have the exact same problem and had a repairman out to look at it .He charged me , but said I would have to take it to him for more troubleshooting.My tv is getting worse and I would love to fix it.
  • Meister_19 Jan 07, 2009
    I have the same problem with my 50H82. It is about 7 or 8 years old now. It can take up to 15 minutes before the picture is completely clear. It doesn't matter if I am watching an off-air, cable or DVD feed. I'm not sure what the fix is, but if anyone knows, please post!
  • chrishos Jan 27, 2009
    Same thing happening to mine. Starting taking just a couple of minutes to clear, but is slowly getting worse. Mine is also about 7 yrs. old.
    Problem Solver:
  • 6 Answers
I just did a repair on one of these. We did not replace the hyper board - we repaired it. There are several parts in the module that need replaced, but these are definitely not user replaceable. They are very small surface mount components and even I have lifted a copper or trace or two doing these. It is tedious work but our repair bill was well below $400. It is also something I do not do in the home and taking it to the repair facility is a money saver.
Posted on Feb 23, 2009
It is the hyper module going bad. you need to find a repairman who can fix it on a bench. part hard to find repair is $400-$600
Posted on Jan 09, 2009
An Element Electronics 32? HD LCD Television model FLX-3211B was shiped to me three days ago. It worked for two days. the picture was very good. I connected it to regular cable (not HD). Today the picture...
This is a sign of bad capaciters ( when they heat up the TV will start the cycle you talk about!) when you turn it off they cool down and act normal(good picture!) This is a major problem that a servoce person needs to fix!
I would send that TV right back( Have the company that sent you the faulty set pay for shipping)
I hope I was of bog help to you!
olease rate this response and help keep this site FREE!
THANK YOU!
Jan 18, 2009 | Televison & Video
After a power surge My Jvc Av-56wp74 big screen Tv won't come on.
 Try this: Works with most crazed computer based devices.Remove power (unplug) unit for 1 minute then plug in
Dec 14, 2008 | JVC AV-56WP74 56" Rear Projection...
Panasonic PT-61HX42F turns on, but wont stay on.
you need to change the stk 392-110 (2 ic ) and some resistor around the area ok
Sep 08, 2008 | Panasonic PT-61HX42 61" Rear Projection...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Panasonic PT-61LCX65 61" Television Set Popped, Now Left with a Cicking Sound
Your problem more than likely lies in your lamp. The whirring noise you hear is the ballast trying to fire up the bad lamp. The lamp part # for your set is TY-LA1000 and can be purchased online at vance baldwin. This is something you can easily replace yourself and your owners manual will give you instructions. Hope this helps
Mar 31, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Mitsubishi WT-46807 46 in picture bends and the blue red and white all seperates
intermittent convergence fail. suggest re-soldering the 2 convergence output ICs on the middle power board. they are the 2 large devices located on the largest heat-sink on the middle board(looking at from back) once you re-solder them as long as the aren't faulty internally you should be all set.
Mar 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Initially No Picture when Turned on but sound normal and 5 minutes later Picture is all RED and then Picture becomes NORMAL (all normal colors)
theres a high voltage block that all three of the anode leads attach to and sometimes a small crack happens across this block and will not let some or all of the crt's get the high voltage all at once untill it heats up a bit. now if this is not your problem i would make sure that all three crt sockets are attached to there tubes all the way as maybe justy maybe there loose and will only work after ther expand a bit. Now another problem that could cause this problem to occor origially would be that someone left off a crt ground strap and the crt arched and popped and caused the problem with the High voltage block. And no I cant see a tube being bad then comming on at first UNLESS when you say the red comes on is the picture all red with small retrace lines(small white lines)in the screen with no picture except for red???? No video only a red blank screen is what i mean. If thats what its doing then yes Ive seen heater to cathode shorts on a picture tube that would cause this problem but to be sure your really gonna need to have the set looked at.. Good Luck
May 17, 2006 | Toshiba 40H80 40" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
139 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
