Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
"the card is locked"
Pictures are downloading fine but camera says "The card is locked" on the LCD screen when i try to take further pictures or delete the exsisting ones....help! thnx :)
  • 4 more comments
  • hilary hansell Feb 12, 2007
    thanks so much that worked. had no idea it was there - i can finally use my camera again.
    thanks again
  • Anonymous Feb 07, 2008
    the card is locked
  • yankee2345 May 17, 2008
    card is blocked cant delete or take pictures help?
  • needsu2help Jun 08, 2008
    It totally worked to slide the thing on the side of the card. I never knew that was there.
  • stefanireed1 Jul 21, 2008
    when i turn my camera on it says "the card is locked" and it will let me look at pictures but i cant delete them or take them
  • margretnjess Jul 23, 2008
    when I try to take a picture, it says the card is locked, what does that mean?
Try seeing if there is a button on the side of the card that moves up and down... sometimes it gets switched and locks the card...
Posted on Feb 11, 2007
When you take a picture with the dcs-t1 camera it is black and grainy...i changed the memory card and the screen shows the pictures on the other card just fine...so the screen works fine..
It si problem of ccd imager chip that is defective in your camera and need to be replaced by camera technician because camera will take apart.
Hope this will help.
Sep 11, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
My screen is black,whats wrong
Try to take a picture and then download to PC. If your picture is fine, then most probably, your LCD screen is bad. You need to replace it. Repair cost through retailers may be expensive. You can do it yourself by buying a used camera (one sold for parts, with good LCD),through ebay. (EBAY.com). Open the camera by removing 5-6 screws. You can get a small screwdriver set for $1 from dollar store. Onc ethe case is open LCD is directly accessible. Remove the LCD by first removing the LCD connecting cable from the connector. There is a small pressure plate (locking mechanism) in the connnector. Slowly lift the pressure plate and pull out the connector lead. Replace the LCD. The following sites give good instructions on replacing LCD. Look at those sites before you do it.
http://www.myfixtips.com/blog/digital-camera/how-to-replace-lcd-screen-on-canon-sd870is-215.htm
Jan 13, 2011 | Olympus FE-370 Digital Camera
I have recently been on vacation. I checked photos on the LCD screen after a days shooting. All was well. I have now downloaded the pictures to my computer. Photos from the first several days are missing...
Is your means that: you can't see some of your picture from your camera screen? I have met this problem before, this is because you have do some a action for your image when your see it on your PC, such as flip... The camera can't read the pictures edited by the other software...So your picture haven't miss...they are on your card,,and you can moved them to your PC and you can see them all.
Wish helpful!
Jan 04, 2011 | Canon PowerShot G9 Digital Camera
The LCD screen on my Fuji broke while I was on vacation. I have some pictures saved to internal memory. I cannot find a cord that will connect the camera to my computer. Is there anyway I can retrieve...
Hello
Download THIS.
Download this free tool and run it on you card and it should be able to recover all pictures provided that you have not used the card since formatting. I recommend using a card reader for this.
After downloading and running (no installation required) , simply select deep scan and your memory card and it will start scanning, To recover a found file , right click it and select save.
Please note that the file names will probably not be available and also that some of the properties of the photo like date taken could be lost.
Please let me know when you have recovered your pictures safely or contact me if you need further assistance.
Regards
Andrea
Aug 29, 2010 | Fuji FinePix Z10fd Digital Camera
Continous formatt popping up on my camera
Download any pictures to your computer using a card reader if necessary. With no card in the camera, go into the menu and find "reset"...follow the on-screen instructions. Then, making sure the slide switch on the side of the card is in the unlocked position, insert the card and this time, find "format" in the menu and follow the on-screen instructions.
Dec 28, 2009 | Kodak Easyshare C190 12MP Digital Camera...
Memory Card Locked The card works fine in my other Canon Camera, but not in my A620. I've switched out the cards and nothing works in my A620, but they all work in my other Canon. Memory Card Locked is...
I'm assuming the slide switch on the side of the card is in the correct position. In order for a card to work in a particular camera, it must first be formatted in that camera. This completely erases it so download any pictures still on it to your computer first.
Oct 25, 2009 | Cameras
New camera ,not working.
lol, ok...The memory card will only go in one way. But check the little white switch on the side of the memory card and make sure it is NOT in the locked position. Once this is taken care of reinstall the memory card. Now in you options/menu screen you can select on there where you want your pictures to be stored...Device / Memory / Auto. You can either put it on Memory or Auto (if you have this). In addition, you may need to format your new memory card. This is also in your menu screen to Format Memory Card. Go ahead and do this. But be forwarned...if you do this when you have pictures on your card, it will erase all of your pictures completely. If you do those things, everything should work fine. You don't need a full charge for your camera to work, but if you have rechargable batteries, it is recommended to fully charge your camera before use. If you are using standard AA batteries this isn't necessary. Oh, and when your memory card is in the camera you should see a little icon on your LCD screen that looks like a mini memory card. This is an indicator that the camera recognizes you have the memory card in the camera and along with that will be a counter...ie 4/1200. The first number is the amount of pictures taken on the card currently and the second number is the total possible pictures you can take on the card before it is full.
Any further questions
extreme7528@yahoo.com
Oct 13, 2009 | Cameras
Camera and computer won't connect
Use a separate card reader to download your pictures.
Aug 29, 2009 | Kodak EASYSHARE Z1285 Digital Camera
My camera wont take pictures says card locked
There is a lock on the SD card
Check this is good.
Regards
Richard.
Feb 02, 2009 | Vivitar ViviCam 3935 Digital Camera
Nikon S6- LCD screen black
I have The same problem with my S6, and was wondering if you found a solution? Ive done everything but contact Nikon or a camera shop.
Apr 16, 2007 | Nikon COOLPIX S6 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
204 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
