Question about HP Pavilion dv9000z Notebook
Hp pavilion wont switch on
It was working one night then one day it wasnt working. i push the power button and it flashes indicating it needs charging but i put the adapter in and it still doesnt switch on even the light saying it is charging is on then after 3o seconds it stops charging.
  • Anonymous Dec 09, 2008
    the laptop said it is charging but the ac doesnt have a light and i tried to use it without the bettery before and it still wont work
  • Joe May 11, 2010
    Does the power adapter have an indicator light on it and is it on?
  • 460 Answers
Dear musmoh19
1st unplug your battery if is conected to the wall,
2nd then take the battery out
3rd plug in to the laptop then to the wall
I use it that way but not for to long because it gets hot but I also put a small fun under it but still can be fry.
these the only solution I have am sorry. vicky
any subgestion or help will be apreciated
vicky4home@hotmail.com
Posted on Dec 06, 2008
Hp pavilion a430 desktop. Nothing happens when I push the power button. It is dead. Is there a reset button? Had bad T-storms last night.
no there is no reset button the only thing u can do is take out the battery and unplug ur power supply ...if that dont work call hp if u under warranty they will fix it.
Sep 15, 2011 | HP Pavilion dv6000z Notebook
Hello, My hp pavilion dv2610us will not power up
your motherboard in the laptop has failed... sorry :(
Mar 13, 2011 | HP Pavilion dv2610us Notebook
Hp pavilion entertainment pc wont charge or turn on
Check the charger is throwing out the correct voltage at the DC jack
Do you get any lights flashing at the charger? If you do it indicates that power is not completing the circuit and is being "spat back". This would indicate a damaged charging circuit or possibly a loose power jack socket, if it feels loose as you plug it in, you may need to change the DC socket
Jan 03, 2011 | HP Computers & Internet
Hi my HP G6000 laptop wont turn on, when i press the power button on the lights flicker for a second and then nothing
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD is faulty and need to replace.
Aug 23, 2010 | HP Pavilion dv6000z Notebook
HP dv7 simply stopped turning on. worked great
What you would want to try is to remove the battery and see if pluging in the power cord will power the laptop alone. All laptops have this capability and this shouldnt be an issue.
But by testing this and seeing if it DOESN'T work then that means there could be one of two things. Your AC power adapter is defective and should be replaced with one that is compatible with your system or that your connection jack is either loose on the inside or broken completely.
However I would stick with trying the cord first before trying to resoder the joint inside the system. I'd leave that to a pro, going back to the battery if you leave it out for a day that should give it plenty of time to discharge any energy it may have in it and you can plug it back into the laptop to try and charge it again either with the same AC power adapter or a new one. If the battery wont hold a charge and you know it isn't because the jack is loose or the AC power adapter isnt defective then you now know you need to replace the battery. You can google compatible batteries and power adapters online or search specific places like Newegg.com or Amazon.
Hope this gives you a better understanding of what may need to be done to fix this!!
check me out at http://ctrlr4repair.webs.com
May 06, 2010 | HP Pavilion dv7-1020us Notebook
My hp pavilion was fine but it discharged
ok it sounds like your battery was damaged when it discharged. try removing the battery and plug in to wall socket. boot computer ,.. if it boots up completely then you will need to replace your battery
Sep 22, 2009 | HP Pavilion ze2000 Notebook
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
HP Pavilion dv9000z Notebook Logo
111 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
