Question about Philips 27PT543S 27" TV
Tv will not power up
My tv will not power up now, it used to take several attemps to get the picture to come on, would have sound no picture. Now it will not power up at all
    Sergeant:
  • 308 Answers
Sounds like a fuse or fuseable resistor may be open due to a short in the high voltage circuits. I would first check the Horizontal output transistor Q7460 and if that was shorted, I would replace C2455 (47uf/50v) as well to prevent a reoccurance of the problem. Of course with the prices of 27" TV's falling, it may be un-economical to repair.
Posted on Feb 11, 2007
Standbye light goes out after several attemps
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 04, 2015 | Televison & Video
Problems starting!After several attemps it starts for a second then ded again after several more attemps it starts and then runs OK! Whats the problem?
Hi Conny:
I'd start by looking at the fuel delivery system.
Injectors or carb?
Sounds like it's not getting gas.
Make sure the carb is clean, automatic choke working.
Fuel pump doing its job?
Jul 15, 2015 | Cars & Trucks
LCD Samsung tv no picture no sound
Try to unplug set and a box if used from power for several minutes and then power back to see if a reboot will help or not.
Dec 10, 2012 | Televison & Video
"Still no power". After replacing cp114, cp120, cp130 and cp 135 on my RCA D52W20B, when powered on the green comes on along with a high pitch sound making several attemps to power on before completel
The whine is a short somewhere---+ and - are marked on the board for each cap if it is polarized---usually the - will have a shaded white mark on top of board--if you got one in backwards it can explode......
Apr 13, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
My tv seems to be dead...
Ur power board ic converter is dead.
Need a new one.
Aug 18, 2009 | LG 42LC2D 42 in. LCD HDTV
No picture or sound
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Sony KP-57WV600 57" Rear Projection...
TV is not coming on
If I understand your problem correctly, it sounds like the unit is not coming on... If this is correct, then replace the 3 capacitors on the output side of the power supply. There are 2@1000uF @25V and 1 smaller one which is 220uF@25V.
I think the part number on the board is marked as WX-15/19/20Power-01...
This worked on a 19 curtis LCDVD191
Hope this helps...
Feb 11, 2009 | Curtis LCDVD151A 15 in. HDTV LCD TV TV/DVD...
Picture and sound disappeared
your red crt bulb is starting to go bad. somtimes you can tap lightly on the neck of the red and the prob. usually short term will go away. if not tube replacement is necessary. this is sometime a pricey repair. but worth it! john
Sep 08, 2007 | Akai PT4298HD Rear Projection Television
Philips 27PT543S 27" TV Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
