Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Dead no pic no sound
Being a retired service tech I decided to repair this beast. I found a storted H.O.T 2SC5681 but I couldn't find any B+ fuse.I don't have a schemtic so i'm guessing it may be a fuseable resistor.Do you think I may have other defective componets?Or maybe just purchase a "D" module.Thanks for the help.Tom
    Sergeant:
    Champion:
  • 346 Answers
Check the flyback
Posted on Oct 28, 2007
    Genius:
  • 1,139 Answers
This looks like a problem with the H Voltage or switching power supply section of the TV set. What you need to do is to measure the voltage from the HV transformer to the Anodes of the CRTs with a high voltage probe, and check the voltage output of the switching power supply. What may have happened is a component may have shorted out causing an over-current condition with is triggering the shutdown circuit (These are the relays you are hearing). I would check the Horizontal Output transistor or a driver transistor, and the components in that section of the TV.
In addition check the voltage test points on the HV / Horizontal and switching power supply board. This will determine if the section is working or not (most likely not). Make sure you have a schematic, and multimeter and a high voltage probe.   Since you have checked most of the common Items I am leaning towards one of the fuses in the system, I would suggest getting a schematic since switching power supplies can be tricky. Trust me I remember the days when a tech could find a fuse on a board easily, those days are gone some fuses even look like ICs now they are called digital fusible devices.   try www.servicemanuals.net to get a schematic for your set
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 26, 2007
We have a bosch excell 7 1400 which tripped all the electricity. Now if we turn the programmer selector left or right it still trips the electricity. Is it worth getting it looked at/repaired or is it...
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong. You would then be in a position to decide what to do. We couldn't possibly judge as to repair or replace, sorry.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 30, 2011 | Bosch Washing Machines
Camera unable to adjust zoom , blurry pic , showing 32.60 error
The most likely cause for this is a zoom or focus lens out of place or impaired in some way and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Jul 30, 2011 | Sony HDR-SR12 HDD Camcorder
Sony Handycam DCR-HC32, won't turn on, even when plugged into the wall outlet and with a new battery or no battery at all. Last week it worked but I couldn't use the flip viewer, only the eyepiece...
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
May 11, 2011 | Sony Handycam DCR-HC32 Mini DV Digital...
During playback the pic gets distorted . . . What could be the cause ?
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Feb 10, 2011 | JVC Video Cameras
The screen and eye piece does not show pic while recording the microphone does work only shows display
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Jan 28, 2011 | Canon ZR90 Mini DV Digital Camcorder
My ZR500 cmcorder ahs a dead battery. I checked the charger vor voltage and it is OK. (I am an electronics tech). The red charger light does not comeon. Thanks, George
Oct 31, 2010 | Canon ZR500 Mini DV Digital Camcorder
HDRCA 52" model R52WH77, the pic looks like a big U in the middle of the screen and it turns its self on after turning it off. Sound is fine.
A capacitor is building up power and then when there is too much power it discharges turning the tv back on without you hitting the power button. The tv will need to be repaired by a service tech however get a quote and then decide whether it is better to just buy a new tv. LCD's have dropped in price greatly.
May 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
Brookstone Wafer-thin CD with MP3 player circuit failure...why?
sure, ur power amp section is completely shorted. meaning it is totally fried. get it repaired. it was a stupid idea to jump the fuse. u cud fry the whole thing!!! i sincerely hope it is only the power amp. if it is more than that u have only urself to blame. remember looks can be deceptive.
Apr 13, 2010 | Brookstone Wafer-Thin CD System with MP3...
RCA R52WH74 Convergence Problem
No my brother and I have been doing television repair since the mid seventies, and when we retired we decided that we would start a business as a way to help the avererage person repair their own sets without having to pay alot of hard earned money for something they could easially do theirselves, that why we give free tech support, 99.9% have easially repaired their sets for less than most shops charge for the estimate.
Sep 11, 2008 | RCA R52WH73 Projection Television
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
