Question about Fujitsu ScanPartner fi-5120C Pass-Through Scanner
Fujitsu fi 5120c e2 error
Scanner flashes up e2 on display and won't do anything else. Also if you try to use it it gives you the following codes.....
Code: DS42001
Sense Key = 0x4
ASC=0x480
DDes=0x0
  • sharkattacks Dec 16, 2008
    Did anyone solve this? I have the same problem today?
  • 14 Answers
See page 25 of:
http://193.128.183.41/support/scanner/manuals/fi-5120c_gs_p3pc-1312-01en.pdf
"E2" is "Trouble with the optical system (front)."
That doesn't solve your problem, but at least it narrow downs the focus of your problem.
Posted on Apr 11, 2009
  • 490 Answers
Normally any error starting with 'E' is to be attended by Engineer/Tech person. any error starting with 'P' is paper related (eg. Jam). I think you should ask for tech support.
S. Mohan
Posted on Dec 10, 2008
Code EF 5120c
"EF error" in Fujitsu fi-5120c scanner refers to Background changeover unit failure. This error is detected in initial checking at power on.
Probable causes:
- Defective Control PCA
- Insulation material damage of BW motor cable or the damage of the wire in the motor.
Check the followings:
1.Does the same symptom occur after turning OFF and ON the scanner?
2.Are the cables between the Control PCA and the BW motor damaged? Or are the connectors connected correctly? Confirm the position of the BW motor and check the cables.
3.Is the CCD cable F or B damaged? Or are the connectors connected correctly?
If the above information doesn't help, then you are recommended to visit the nearest Fujitsu service center for assistance.
Thanks & regards,
ScanCare
Mar 03, 2014 | Fujitsu fi-5750C Flatbed Scanner
Does fi 5120 driver works on Window 7?
Fujitsu fi-5120C is compatible with Windows 7. However, you have to download and install the scanner drivers for Windows 7. Click HERE to download the required drivers and toolkit (Installation & User Guides are also available).
Run the downloaded file and follow the on-screen instructions to install the scanner drivers/ toolkit.
Hope it helps! Good Luck!
CreativeTECH
Mar 16, 2011 | Fujitsu fi-5120C
When I switch on the scanner it dispalys a E2 Message
Open the front door and look for a small switch actuator that has been knocked out of position
Aug 26, 2009 | Fujitsu ScanPartner fi-5120C Pass-Through...
I opened the fujitsu software operation panel and recieved the following error: This Scanner has not been supported. The model number is fi-5120C
Sounds like driver related problem to me. Download this: Driver Update Software and follow the instructions to update. Best of luck
Simon
Jul 30, 2009 | Fujitsu fi-5120C
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fi 5120c will not scan sheets that have different color entries
Check the software settings in the scanning software. Try running scandisk in the OS. Check if the scanner is working with any other comp. If it works, may be your OS is corrupted.
S. Mohan, Chennai
May 29, 2008 | Fujitsu fi-5120C
Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
Can't setup ScandAll 21 on fi-5120C
why do you want to use the older version, the new version has much better driver support and actually works with the event buttons on the scanner.
May 23, 2008 | Fujitsu fi-5120C
Fujitsu Error
try a new paralel or usb cable you might have gotten a defective cable
May 22, 2008 | Fujitsu fi-5120C
Fujitsu ScanPartner fi-5120C Pass-Through Scanner Logo
3,897 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
