Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
nina Posted on Jun 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a konica minolta 1690mf. paper feed problem error 094
I have a konica minolta 1690mf. Something has got misaligned in the paper feed and ~I cant work out what. When I turn it on it goes through self checks, I hear a grind and it says machine trouble error 094. Help!
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on May 07, 2017
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1912807
Points
11959
Transfer roller issue. the sponge looking roller across from the transfer belt.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
4 Related Answers
Anonymous
  • Posted on Jul 29, 2009
SOURCE: PAPER FEED DOESNT WORK KONICA MINOLTA COLOR PRINTER
This happened to me one time after I pulled out a jammed paper the wrong way. I pulled it from the paper tray. Heard the sounds, it tried to grab the paper, but couldn't. It happened a long time ago, so I'm fuzzy on which part I tinkered with...but I recall that because I pulled the paper (backwards) from the tray, it flipped a lever/feeder/roller/thing and that 's why it wasn't grabbing the paper. If you look in the paper tray as the rollers go down to grab the paper, you'll see what's not working......sorry, lame solution.
Anonymous
  • Posted on May 11, 2010
SOURCE: how do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
Ty Schmidt
  • 118 Answers
  • Posted on Nov 29, 2011
SOURCE: Konica Minolta Magicolor 1690MF error code 0310
why did you post this 4 times
Xanda Frederica
  • 183 Answers
  • Posted on Sep 21, 2013
SOURCE: how can I correct this: process error-belt clear
I think this is mechanical problem and you need to check and remove belt-related assembly part.
Thanks
Ow do i fix the error message MACHINE TROUBLE SERVICE CALL (0310) on my konica...
replace the print head. That's the part that houses the LASER. try this site for the part
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
if not try local Konica Minolta dealer
Why does my Konica Minolta 1690MF have a fuser jam error whenever I print in color?
Everything you checked sound good. Might be printer software problem, and needs to be re-flashed. Software only available from secure web site that a technician would have, see what it cost if to much buy a new one with extra bells and whistles !
How can I correct this: process error-belt clear by cover,i need help????? on my Konica/Minolta 1690mf
Thanks
1helpful
After changing toners (all 4) my Konica Minolta 1690MF screen says Machine trouble Service call (3C10). Anyone knows what is that mean. On the computer says everything is working fine - your device is...
I have 1690mf and changed cartridges, the 3c10 call engineer appears after printing, paper jammed. Had call out from service engineer, afraid he's at a loss too, says it is a security issue but no instructions on how to repair, waiting now to hear from Konica theselves as to what is the answer, I can still print, just have to take the paper out and switch on an off when it stops, annoying though
1helpful
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR:
process error - belt (clear by cover)
SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended.
KONICA MINOLTA SUPPORT PAGE:
https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
