Question about Radio Shack Pro-95 Handheld Scanner
Scanner wont scan
Display says what appears to say ''luired'' and it wont do anything i even tried resetting it and nothing
  • Anonymous Jan 10, 2009
    Pro 94 write LUirEd on the display
    what is it ?
    Thanks forward
    ronenp At hotmail dot com
  • 514 Answers
If it won't allow you to use the buttons then go to page 17 of the manual (at "http://support.radioshack.com/manuals/ome20-525.pdf" if you don't have it) about half-way down the page. good luck!
Posted on Mar 09, 2009
My hp psc 1410v all in one printer wont scan to my computer
THIS MIGHT HELP I LOVE OLD SCANNERS AND ALL IN ONE PRINTERS. MOST OF THE TIME YOU HAVE TO GOTO MY COMPUTER AND SCAN IT A DIFFERENT WAY. LET ME KNOW IF I CAN HELP FURTHER.
Mar 18, 2014 | HP PSC 1410v All-in-One Printer
Scan says all channels locked out
Please try this,
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box.To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
Hope that helps!!
Happy Scanning
Nov 22, 2012 | Radio Shack Pro-97 Handheld Scanner
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
Reset scanner
Please try this:
Hope that helps.
Happy Scanning!!
Oct 24, 2012 | Radio Shack Pro-97 Handheld Scanner
I have a radio shack pro96 i can not reboot it to restall the v scannfolder what can i do i have tryed everything to wipe it clean
Sounds like the motherboard is corrupted. Please try these steps again. Thanks!! Happy Scanning!!
I need to ask you this. Normally one bank can't be closed.
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Apr 11, 2011 | Radio Shack Pro-2096 Base Scanner
My pro 94 scanner shows the code luired when turned on. How do I fix this?
I'm guessing that the display shows "wired" and not "luired." This mode, along with the code, is supposed to clear when the computer programming cable is disconnected. If you don't have a cable connected, your only option is to RESET the scanner to its original factory settings. Just a caution: resetting the scanner will erase/delete all programmed information -- you will have to reprogram all of the data that you've previously entered. To RESET the PRO-94:
1. Turn the scanner OFF.
2. While holding down the 2 and 9 keys, power the scanner ON. The message "CLEAR" will flash for about 5 seconds while the scanner resets.
NOTE: Do not turn the scanner OFF until "CLEAR" stops flashing.
Bill B.
Listening in since the 60's
Oct 27, 2010 | Radio Shack Pro-94 Scanner
I have A radio shack PRO-2096 and have not been able to use it in over A year. it reads all channels locked out. I can't unlock it.can someone please help me?
Please try this!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
HELP
If the weather band is working, the scanner should be working. To verify operation:
- Move the MODE switch to "Scanner" and power the unit ON.
- Press the SVC button (chrome button below display).
- Press POL (chrome button below display).
- Turn the SQUELCH knob towards the left until scanning stops and you hear a hissing noise.
- Turn the SQUELCH knob towards the right slowly until scanning resumes.
If the scanner stops on anything - even noise, it's working.
To Program:
- Slide the MODE key to "Scanner."
- Power the unit ON
- Turn the SQUELCH knob to the left until you hear a hissing noise, then turn it the right - slowly - until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 156.055).
- Press the E (PGM) key.
- Press the UP arrow (above the SCAN key). Scanner will move to channel 02.
- Enter your second frequency, including the decimal point.
You should now have two frequencies programmed. Press the SCAN key . . .
If it still will not accept programming, let me know.
BillB
Nov 07, 2009 | Uniden BC340CRS Base Scanner
Radio Shack Pro-95 Handheld Scanner Logo
214 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
