Question about Epson LX-300 Matrix Printer
Custom page length
I am using an accounting package MYOB. I however have invoice paper that is of custom size being 8,5 x 8,5 Inches. There is no custom size paper selection for the Epson LX-300+ that appears on the dropdown paper selection e.g Letter, Legal etc.
3 Suggested Answers
  • 26 Answers
SOURCE: PRINTING ON CUSTOM SIZE PAPER
you need to change the page lenght on the printer. to do so...
  1. turn off printer
  2. press and hold the tear off button while turning on the printer
  3. a menu of the setting will be printed
  4. just follow the instruction
  5. you need to set the page lenght for tractor feeding to 8inchs
turn off the printer it willsave the setting
Posted on Jan 11, 2008
  • 36 Answers
SOURCE: do i can customize my paper size in MS Excel 2003
When you are in Excel, go to Print Preview, then Printer Properties. There should be a box that says "Custom Size." There you can input your paper size and name it so you can recall it anytime you want.
Posted on Jan 05, 2009
SOURCE: How can i copy a legal size document on the Epson Stylus CX9400?
Take a photo with digital camera. I am doing this on newspaper articles from books at local Historical Society then cropping and other editing in my Serif Photo Plus 11 program.
good luck,
LindaC in OK
Posted on Jan 28, 2009
Change page lenght
**Got file, page lay out>paper>paper size>scroll to custom,type desire pape length & width** After print command, in printer dial box go to properties,select paper/quality,paper size,select custom, type desire length & width
Feb 01, 2012 | HP LaserJet Office Equipment & Supplies
I have created a custom paper size 14' * 4' but i am unable to select the same paper size to set the page setup.
The maximum paper width the 6306 can print on is 13.6 inches, you will not be able to select a custom size form larger than the printer is capable of handling.Simply set the for size to 13.6 inches or the maximum width you will be printing.
Aug 11, 2011 | TallyGenicom 6306 Matrix Printer
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
Hello, I have an invitation that is 4in wide x 9 inches in height. I want to print something on it, but not sure how to get my printer to recognize that I am using custom size paper. It keeps printing on...
In addition to the wide variety of standard paper sizes available for this printer, you can use custom size paper in the Tray 1 (MPT).
The size range for custom size media is as follows:
    Minimum allowable page size:
    89 x 140 mm (3.5 x 5.5 in.)
    Maximum allowable page size:
    216 x 356 mm (8.5 x 14 in.)
  1. Open Tray 1 (MPT).
  2. Insert the custom size paper and adjust the guides to match the size of the paper. Place the side to be printed facedown with the top of the page entering the printer first.
  3. When the front panel prompts you to confirm the type and size of paper:
    1. Scroll to Change by pressing the Down Arrow key and press the OK key.
    2. Scroll to the correct paper type and press the OK key to save your selection.
    3. For the paper size, scroll to Custom and press the OK key.
    4. Select Set Custom Width (W) by pressing the OK key.
    5. Press the Down Arrow or Up Arrow key to scroll to the desired value for X and then press the OK key.
    6. Scroll to Set Custom Height (H) and press the OK key.
    7. Press the Down Arrow or Up Arrow key to scroll to the desired value for Y and then press the OK key.
  4. Select the custom size in the printer driver.
  5. Windows 95 / Windows 98 / Windows Me PostScript driver: On the Setup tab:
    • After you select the Multi-Purpose Tray and the tray displays Custom to indicate that it has custom size paper, enter the dimensions of the custom size paper in the Width and Height boxes.
    • If you select Automatic for the paper source and select Custom Size for the paper size, enter the width and height values of the desired custom size paper in the Width and Height boxes. The values for width and height are initially 0. If you previously entered information in the boxes, the values are automatically entered.
    Windows NT / Windows 2000 / Windows XP PostScript driver: On the Paper/Quality tab:
    • If you select Choose Specific Tray, select the Multi-Purpose Tray.
    • If you select Automatic, you can select your custom size from the Paper Size drop-down list.
    • Click My Custom Sizes and highlight the custom size in the Current Selection list. The Name, Width, and Height boxes display the details about the highlighted custom size and the sample image changes to represent a scaled version of the custom size.
    • To create a new custom size:
      1. Click New.
      2. Enter the new name in the Name box.
      3. Enter the dimensions in the Width and Height boxes. The sample image changes to represent a scaled version of the new custom size.
      4. Click Save to add the new size to the list. Click Cancel to exit without saving the new custom size.
      5. To exit, click Close.
    • The My Custom Sizes box lists existing custom sizes that are supported by the current printer. Since these custom sizes are saved in your computer's operating system, they are available for you to select in your applications.
    • If you create a custom size in certain applications, the driver lists the custom size automatically.
    MacOS 8 / MacOS 9 driver:
    • In the Page Setup dialog box, click on Page Attributes, and select Custom Page Sizes. Then press New to enter a new custom page size. A dialog box appears where you can enter the width and height, margins, and name of the custom page size.
Jan 19, 2010 | Xerox Phaser 6250 Laser Printer
TallyGenicom 2265+ not printing with custom paper size
There may be a number of causes for the problem you are seeing. There are a number of places which may hold the origin to the page length problem you are seeing, in order of precedence these are;
  1. The page size set in the software package printing the 6 x 4.25 cards
  2. The page size set the printer driver printing to the printer
  3. The page size set on the printer
I would recommend the follwoing;
  1. Set the form length on the printer to 6 inches (i am assuming this is the length of the card)
    The form length can be set through the menu and is normally set in lines (normaly the print size is set to 6 LPI) so the form length should be set to 33 lines
  2. Create a custom form size in SERVER PROPERTIES on the Windows XP machine to match the form size you are using.
    Ensure you select this form size in both PRINTER PROPERTIES and PRINTING PREFERENCES
  3. Try printing some Windows Test pages to see if these respect the page size selected withing the printer driver properties.
If the Windows Test Pages do not print correctly I would recommend checking how you are creating the CUSTOM SIZE form, perhaps create a new form and double check the form properties one it has been saved to confirm these are correct.
Check you are using the correct printer driver for the printer, you should be using the 2265+ printer driver. As a test you may wish to install the GENERIC TEXT printer driver or the EPSON LQ2250 driver, these will be included in the Windows Add Printers Wizard and should print OK to the 2265+.
If the Windows Test Page prints OK I think you would need to look at the software package printing to the printer. Ensure the correct page size is selected here also, perhaps try printing from another software package selecting your custom size form to see if these print correctly.
It is passable your software package is sending escape commands to the printer to call up the page size, I note you say Genicom printers printed ok from Win 98. The 2265+ may not have the same emulations as the Genicom printers.
You can print a menu print on both Genicom (if these are available) and 2265+ and compare the settings on these.
I do not believe the 2265+ has a Genicom emulation as standard, but you may be able to load an alternative version of firmware into the 2265+ which provides the Genicom emulation. If the data going to the printer contains Genicom Escape command to set form length this may resolve the issue.
You may need to contact your TallyGenicom support department for the firmware (I think it may be called 7265+ firmware)
If you are able to provide Hex Dumps of the data to the TallyGenicom support people they should be able to say what is going wrong with the form length setting.
May 07, 2009 | TallyGenicom 2265+ Matrix Printer
Thank you for taking my question: HP laserjet print using Vista
go to printer propeties and check paper size ther'l be a custom size click on that n feed what u wnt
Dec 11, 2008 | HP DeskJet 880c InkJet Printer
Custom print size help Kodak 5500
if you are running windows vista there is a built in roadblock to being able to add any custom size pages. You have to turn off user account control by going into control panel, users, user accounts and then turn on/off user account control. After you do this you can add any size you want then if you want the added safety go back and turn on the user account control. Hope this helps and happy printing!
Dec 06, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Epson FX-2190
What operating system are you using? In Windows, you can set it through server properties in the Printers area of the control panel, you can do this by creating a custom paper size. If you are running in DOS, you can set the page length through the printer itself by going to its default setting. In the printers default setting, make sure you are setting the length on the correct paper path (FRONT FEED, BACK FEED).
Jun 03, 2008 | Epson FX-2190 9 PIN Matrix Printer
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Apr 22, 2008 | Office Equipment & Supplies
  1. turn off printer
Jan 01, 2008 | Epson LX-300+ II Matrix Printer
Epson LX-300 Matrix Printer Logo
20 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
