Question about Dryers
My dryer started making load rumbling noise. It still dry's. What is wrong with it?
  • 417 Answers
Probably the drum bearing is worn. You might be able to try oiling it but it will need to be replaced sooner or later. Check if you have any warranty cover still remaining, if not get an estimate and compare the cost of a new drier, there are some good deals around at the moment.
Posted on Dec 05, 2008
Dryer makes squeeky noise when drying
What brand is the dryer and is it front load
or regular?
Apr 20, 2014 | Kenmore 800 7982 Dryer
LG DLE 2514W DRYER MAKES RUMBLING NOISE WHILE RUNNING
Hi Willie Bolden
Sounds like your problem is drum rollers are in need of lubrication or replacement.
Go to the following webpage for a schematic of your dryer and parts.
Please take time to rate me
Bud
http://www.appliancepartspros.com/parts-for-lg-dle2514w-abweeus.html
Oct 11, 2012 | LG DLE2514 Electric Dryer
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
Dryer is making a loud rumbling noise when drying - it is drying okay - but making a rambling noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 04, 2011 | Asko T761 Electric Dryer
Dryer initial had rumbling sound when started and then quieted down to normal. It now makes a rumbling sound through the complete dry time
heatman101
Aug 31, 2010 | Maytag MDE2600 Electric Dryer
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Kenmore elite3 dryer rumbling noise
there are two rollers that hold up the drum...they go bad...and are ez to replace! they are sold in sets of two for about $30.00
Mar 15, 2009 | Kenmore Elite HE4 Electric Dryer
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Rumbling noise
Time to call GHOST BUSTERS!
Here is a good service!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 22, 2008 | Maytag Performa PAV2200
Dryers Logo
Top Dryers Experts
