A US 110v XENYX 802 plugged in a 220v power
Just brought it from USA, I've plugged my brand new Behringer XENYX 802 into a 220v power.. It has worked for about 5 seconds and now it doesn't work at all...
There was no smoke
There was no explosion
No customer support for this model by the dealer in my area
For more information:
. Product page
http://www.behringer.com/802/index.cfm
. Product manual
http://www.behringer.com/02_products/proddetail.cfm?lang=ENG&id=802&type=310
. Product info
http://www.behringerdownload.de/XENYX_GRP1/802_VIEW_Rev_A.pdf
. Spec Sheet
http://www.behringerdownload.de/XENYX_GRP1/IMPL_Tech_GLOB_P0575_S_Web_EN_2007-11-29_Rev.1.pdf
. Important info
http://www.behringerdownload.de/important-instructions.pdf
Please help
  • ABRsvcs May 11, 2010
    Just like anything else designed for 110V, using 220 instead smoked the unit. It could be as simple as the power supply or more drastic like the internal ICs that are blown. In any case, this unit will require repair at the least. It is quite possible that this will not be recoverable without extensive work and expense. This will not be covered under any warranty and would be considered customer damage. Sorry to be the bearer of bad news.
    In general, unless equipment is marked for use on both 110 and 220V power, you MUST only connect to the proper lines.
    Dan
    Problem Solver:
  • 7 Answers
Please check the glass fuse sir. for sure it was blown out. if it is japan made and not been replaced since the 1st use im sure that only fuse has the weakest point so this will break out
Posted on Dec 06, 2008
I got behringer 802 audio mixer and a mic..what else do i need to start singing..
Please verify if your computer has a sound card. You will need a provision on your computer for audio input. Let me know.
Dec 26, 2014 | Behringer XENYX 802 Mixer
HOW TO USE CUSINEART GRIDDLER WITH 110v TO 220v
Get a step down transformer/converter. Grill consumes 1500watts of energy. Converts cost 200 dollars here at sim lim tower/square. Make sure get the correct watts, it is very important.
Apr 06, 2014 | Cuisinart Microwave Ovens
My behringer xenyx 802 premium 8-input mixer worked fine for 1 day but now it sounds watery and behringer support was no help at all
Sounds like it may have failed. Yes, it is likely that it needs to be returned. Another option is to unplug all inputs and outputs. Plug in ONE device into the board, and use the headphone jack on the board. Does it sound the same? Just basic troubleshooting may help.
Oct 02, 2012 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
How can i connect a Behringer xenyx 802 mixer to a Fisher TAD 9315
What you've done should have worked on the video input. The phono will not sound like you'd want. Have you made sure the mixer is working correctly by trying it plugged into a different amp using the same outputs and cable?
Mar 14, 2017 | Music
I'm looking to run 5 live instruments through the behringer xenyx 802, is this possible? Would the split channels force the instruments to pan? Any help would be much appreciated?
You could use the Left inout of one of the stereo channels. You can pan it with the balance control as needed... HOWEVER remember these are LINE LEVEL signal levels into the stereo jacks... so if you are using instruments with low output you MIGHT have to use a preamp to go into these jacks. Try it... nothing ventured, nothing gained. Using a keyboard into these jacks would NOT be a problem.
Sep 01, 2011 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
Hi all i own a behringer XENYX 802 audio mixer. this device is powered by a power supply that as input to the mixer gives 18,5 x2 Ac, 150ma. i would like to know in which point of the circuit i can...
You would need TWO DC supplies as they use AC so they can create both a plus and minus 15 volt power source to run the internal op amps.
Here is a schematic for the 1202 which has same power supply configuration as the 802.
http://elektrotanya.com/behringer_xenyx_1202.pdf/download.html
Scroll down to the little link "Get Manual" and download the service manual and schematic. You will find the power input in the upper left corner of page 5.
Mar 29, 2011 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
SE2200a, No input signal
If my comment helped you find this problem, could you respond to the fixya questionnaire accordingly?
thanks...
Charlie
Apr 20, 2009 | SE Electronics SE2200A Professional...
675 people viewed this question
 Grubhead
Grubhead
