Bootup Router and then nothing
I have a CISCO 1720 router, when I bootup the router my HyperTerminal Session runs through the system bootstrap and then goes to a rommon command line.
Here's a copy of the session output:
System Bootstrap Version 12.0(3)T, Release Software (fc1)
Copyright (c) 1999 by cisco Systems, Inc
C1700 platform with 32768 Kbytes of main memory
rommon 1 >
Has something happened to the memory on this thing? Maybe a power surge has knocked it out?
Can anyone shed any light on this or provide me with a solution?
All this on the very day that I am to have static IP's installed in my new house and utilise my CISCO Router...
Thanks!
  • Rothers Dec 18, 2008
    Thank you for your assistance with this Carrie,
    The router is now back to normal and I can play around with my new IP's, thank you once again for your helpful advice, much appreciated.
    Chris
    Problem Solver:
  • 10 Answers
Your router is in the wrong mode. You need to change this by changing the conf-register to 0x2102
at the rommon prompt type in
config-reg 0x2102
reboot
If there are any errors you can get the correct syntax by typing ? at the rommon prompt the line number will go up on every line.
The way to get into rommon mode is by pressing the break key from Hyperterminal as the router is rebooting. So make sure you don't do this by accident. If you do just reboot by power cycling.
Your Startup Config should be unchanged, but you need to be very careful what you do in rommon mode it is easy to blat stuff.
Any changes you make once you get into the command (enable) mode should be saved by
copy running-config startup-config
Any problems just let me know.
good feed back would be much appreciated.
Carrie
Posted on Dec 07, 2008
The router starts and finish POST then decompress image file from flash memory then shows this message: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1) Technical Support:...
I don't really know what your asking but i guess you want to know why your startup-config doesn't load. What your router is displaying is normal. You need to change the configuration register.
1.Let the router load then if asked select Yes to abandon autoinstall, then select No to skip initial setup. Press return (enter button) when asked.
2. Now type the following at the prompts. (you type the bold stuff press enter after each command)
router>enable
router#conf t
router(config)#config-register 0x2102
router(config)#exit
router#reload
........save changes blah blah blah.. type NO
continue with reload Yes
providing you have a startup-config, the router will now load it on bootup.
Hope this helps
Pokeabeaver
May 12, 2011 | Cisco (1841) Router (cisco1841)
Tip
877 router factory reset woes
Question:<br> We've recently changed <a href="http://www.3anetwork.com/cisco-c2951-vsec-sre/k9-price_p267.html"><b>C2951-VSEC </b></a>data line providers and now have some Cisco 877 routers we'd like to reconfigure and use at other sites. Although we own these, they were configured by our old data line providers, I'm having a hard time of resetting them to factory defaults and am after some advice.<br> The simple, hold down the reset button until it restarts does not work.<br> If I press the reset button within 5 seconds of power up to load the default rom image, I get the below:<br> System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE<br> Technical Support: http://www.cisco.com/techsupport<br> Copyright (c) 2006 by cisco Systems, Inc.<br> C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory<br> Booting flash:c870-advipservicesk9-mz.124-24.T.bin<br> Error opening: flash:c870-advipservicesk9-mz.124-24.T.bin<br> System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE<br> Technical Support: http://www.cisco.com/techsupport<br> Copyright (c) 2006 by cisco Systems, Inc.<br> C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory<br> Booting flash:/c870-advsecurityk9-mz.124-24.T6.bin<br> Self decompressing the image : ############################################################################## [OK]<br> I assume from this the required bin has either been removed, renamed or overwritten.<br> As soon as the router boots it requires a password and I dont have the password to be able ftp files in and out of it.<br> Hope you guys can help.<br> Answer: <br> this should work indeed.<br> take a look here:http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml <a href="http://www.3anetwork.com/cisco-cisco3925/k9-price_p284.html"><b>Cisco 3925</b></a>
on Aug 28, 2013 | Computers & Internet
I need to connect cisco 2800 router to my pc through hyperlink
I think you mean hyperterminal? you need a cisco serial cable (blue) and a serial port on your PC, maybe a USB to serial adapter if there isn't one. Set hyperterminal to use the COM port you have plugged in to, speed 9600 8 bit no parity. (8N1).
Without the serial cable you need to know the router IP and password.
Oct 31, 2009 | Cisco (UBR904) Router
Cisco router 857
hey you are saying that you want to configure the router,, but rommon mode is for breaking the password....do u forget the password of the router......can you explain why u need to log in through rommon mode
Nov 30, 2008 | Cisco 857W (882658019555) Router
Cisco 857 router
You might need to reset the password. In order to do this, follow these directions:
  1. Console into the router, then power cycle it. As its rebooting hit the "break | pause" button on your keyboard, and you get to the rommon1> prompt.
  2. Then type rommon1>confreg 2142 rommon2>reset
  3. The router comes back on as if it were new---answer no to the first question, and sometimes it asks a second question (do you want to terminate autoinstall, or something...)---answer yes to the secondquestion if it asks. Then hit enter and you get router> in a few seconds.
  4. Then router>en router#copy start run
create a new account:
  1. router#conf t
  2. router(config)#username bob priv 15 password bob
set register back:
  1. router(config)#confreg 0x2102
  2. router(config)#exit
  3. router#wr
  4. router#reboot
and that should let you login with bob/bob
Nov 30, 2008 | Computers & Internet
I have cisco router 857 and dont know how to configure
Hi!
You can access the user manual for your router by going to:  http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/857sg_bk.pdf
But simply put,  - You have to enable the web interface in Hyperterminal/Telnet/Terminal - To connect to your router this way, open your Terminal and type the following commands in order:
1) enable (enter password if necc.) 2.) config term 3.) ip http server (this command might also be set to "no ip http server") 4.) exit
After doing the above: 1.) Press Cntrl+Z 2.) Go to Copy, Run, Start 3.) Open your browser and go to "10.10.10.1"
Good luck! -TJ
Nov 30, 2008 | Cisco 857 Router (CISCO857K9)
Cisco Router Boot Loop
you need to follow the steps to perform a password recovery on the router.
don'y actually perform the password recovery step, but you need to get a uncorrupted copy of the isos installed.
then try again.
I have assumed that when you power on the device you are able to see the boot process in hyperterminal, then just befor you get to type anything the unit reboots.
Oct 28, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Changing default gateway
how are you connecting to the router?
Is it by the serial cable or network cable ?
Sep 23, 2008 | Cisco 2501 Router
Boot Loop
you may have to reload the OS of the router.
i dont suppose you can kick it into romon mode can you? (usually done by hitting the pause break button on boot.)
if you can you should be able to use Xmodem to reload the OS (as long as you have a copy of it located on your computer)
Mar 11, 2008 | Cisco 1603-R Router
Open Questions:
Service**1.877.778.89.69**Norton Antivirus Tech Support Phone Number? Contact1-877-778-89-69Nortan Antivirus Support Phone Number to connect with live our expert team or Our Agent with free of cost just dial 1-877-778-89-69.Get an effective and efficient Nortan Antivirus Support Phone Number 1-877-778-89-69 for various glitches.Call instantly 1-877-778-89-69 N.O.R.T.AN A.N.T.I.V.I.R.U.S Support Phone Number. Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number,Nortan Antivirus Tech Support Number,Nortan Internet Security Customer Number,Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number,Nortan Antivirus Tech Support Number,Nortan Internet Security Customer Number,Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number,Nortan Antivirus Tech Support Number,Nortan Internet Security Customer Number,Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number.
Mar 24, 2017 | Norton Computers & Internet
Computers & Internet Logo
240 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
