Dear I m nader shams fro egypt. I work in oce wide format plotter. I m need the licensi for SDS for oce TDS 320 and 450 can u help me in that. I cand work in another machin exipt oce . i havent a work now plz help me soon nadershams@hotmail.com
5 Suggested Answers
SOURCE: Oce TDS 400 Printer. Erore Prob.
erore
Posted on Aug 25, 2008
toac990
  • 838 Answers
SOURCE: Where can I get a work shop manual or service
which model do you need... cs2124 or canon ipf600
please tell me
Thanks
Posted on Dec 12, 2009
SOURCE: where ci get a work shop or service manual for a
where do I get a service and repair manual for a OCE CS2124 wide format printer
Posted on Dec 13, 2009
micromatikal
  • 2777 Answers
SOURCE: I have a OCE CS2124
I am so sorry, there is no continuous ink supply system that works with an OCE OS2124. You will need some type of custom solution, I have found one person that was also looking for one, maybe they found one, but it isn't likely, they are able to be contacted through this link:
http://www.alibaba.com/buyofferdetail/103022771/CISS.html
I would suggest a different printer / plotter that is made for use with a CISS, it is probably not worth the trouble to get this one working. I am so sorry about that,
Tim
Posted on Sep 10, 2010
  • 149 Answers
SOURCE: OCE TDS 600 error code 22017. Do you Know what it
There is a problem in the power supply section. Call for service, this is not user fixable.
Posted on Oct 05, 2010
Oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
Moving Oce tds400 plotter
there is in fact a way to remove the cartridge. her is a link download the users hand book that has that information and more.
http://downloads.oce.com/ProductDownloads/Index/278
Oc TDS400 downloads drivers manuals software firmware and safety data...
Mar 11, 2014 | Office Equipment & Supplies
Remove toner from oce 450 plotter
it shouldn't spill if left upright. you better be VERY careful with that unit, if the drum gets damaged it will cost ALOT of money to repair it. There may be a lever to disengage the drum blade so it doesn't abrade the drum. If you are unsure of what you are doing you may want to hire someone with experience.
Oce tds 600 error code 08005
you can see you'r answer here:
http://www.copytechnet.com/forums/other-copier-brands/90112-oce-tds-600-08005-error-code.html
Sep 01, 2013 | Office Equipment & Supplies
Oce tds 400 random black lines on demo print
Check the developer and clean the charge corona and the transfer /separator corona assy.Clean the PH unit lens.
Jan 29, 2013 | OCE Office Equipment & Supplies
Where ci get a work shop or service manual for a OCE CS 2124 wide format printer
Dec 12, 2009 | Office Equipment & Supplies
Oce tds 800 how do you reset the counter for maintenance and part
hi
you have to go into service first
you have to log on in SDS
WITH user :oceservice
pASSWORD:675756
And there on consumbeles you have to reset by
pressing 0 / enter and than egnoladge with the green V on top
good luck
Yaacov
Mar 11, 2009 | OCE Office Equipment & Supplies
Request for designjet plotter info
my hp 450c plotter works properly in vista. First I' ve tried unsuccesfully to add new printer through windows menu. Then through Autocad menu (plotter manager) I added the specific plotter.
Jul 09, 2008 | HP DesignJet 450c InkJet Printer
k24674
