Question about Microwave Ovens
I need help on identifying a panasonic microwave part
  • 833 Answers
Try partstore.com They have exploded diagrams and can sell you what you need.  If the item is safety related, use care to install a comparable part.
Posted on Dec 07, 2008
Manual for Panasonic sensor 1250w
Do you mean a Panasonic 1250W microwave with 'Genius Sensor' technology? If so, you should check the model number on your microwave to find the correct manual.
Panasonic has several models with sensor modes. The manual will usually be on the product page. Search for the model from http://shop.panasonic.com and scroll down to the manuals section. Alternately, go to http://shop.panasonic.com/support , then do the model search. This will automatically go the the Owner's Manual section on the product page.
A manual for the NN-SN933 (and several other models) is here: ftp://ftp.panasonic.com/microwaveoven/om/nn-sn943_nn-sn933_nn-sn743_nn-sn733_en_om.pdf . This is a 2.2 cu. ft. model that was advertised on target.com as a Genius Sensor microwave.
I hope this helps. Please add a comment with the model number of your microwave if you need a different manual.
Aug 23, 2017 | Panasonic Microwave Ovens
Need manual
For every microwave oven ever made or just yours?
Feb 07, 2016 | Microwave Ovens
I have a NNSD297 Panasonic over the range microwave oven. First the unit had power, clock , timer, fan was working; except after hit the start button, maybe 2 secs looked like working then stops operating....
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Feb 11, 2013 | Panasonic Microwave Ovens
I belong to thiruvalla and need to service my panasonic microwave oven(NN-C784MF)-28L.I need to know the best person to call.
Due to the type and design of your microwave oven, consult an Panasonic authorised service centre.
www.panasonic.com for a list of dealers in your area.
Jan 07, 2011 | Panasonic NN-S541 Microwave Oven
Need to replace Panasonic NE8070 model, 15in dia,microwave plate
hi my name is mark, i found panasonics part website follow link http://www.pstc.panasonic.com/Epartr/PartsListChoice.asp?validate=1 if this helps please rate how i did. thanks for you question.
Mar 18, 2009 | Microwave Ovens
Panasonic Oven repair
The oven is Normaly service by board and parts swapping. The processor board would be difficult to service without proper diagnostics. If you take in consideration of the time and the extent of the diagnostics to analyse the fault, it would not be cost effective.
The most common causes of failure is the power supplies, and safety switches. Follow the information in the service manual to take voltage reading and test the switches.
If you have to work in the high voltage section, take great precaution. This is very dangerous to work on. You will need the proper high voltage test meter probe to check for proper high voltage operation. The service people swap out parts to test. This is the fastest, safest, and easiest way to service these.
Normally, outside of warranty we found these not worth to service unless the fault was very simple.
Jerry G.
Apr 09, 2008 | Panasonic NN-S753 Microwave Oven
NEED HELP WITH MICROWAVE
door not making connection??? remove the cabinet, and check all switches at least 3 switches in there that need to be making contact, any one being bad, will prevent unit from heating. check also the switch holder(s), that might be broken preventing proper connection
Mar 04, 2008 | Panasonic NN-T993SF Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
