Question about Edimax 4 Port Wireless AP Broadband Router (br-6104wb)
Edimax 6215 - Printserver doesn't work
All my printers don't work on Edimax-USB-Port1 - I did the setup according to the manual.
Also no USB-LED!
    Problem Solver:
  • 21 Answers
If your usb light is not lit-there's a chance that your usb led is busted, usb cable is defective or printserver is defective itself.
if your going to connect your printer directly to your pc using the same usb cable and if it works that way. then it could be that your printserver is not working fine.
Posted on Dec 08, 2008
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
Print server for vista, D-link DI-704p
I can recomend to your network setup is WPS54GU2
Wireless-G PrintServer for USB 2.0
******************************** Before configuring the wireless settings of the printserver, make sure to know the following settings on your D-link router: SSID, and wireless security.
Configuring the Wireless Settings on the Printserver
The wireless settings of the printserver can be configured using its web-based utility. Make sure the printserver is set to a static IP on the network.
NOTE: Make sure the printserver is already working when hardwired to the Dlink router before attempting to use it wirelessly on your network.
Step 1:
Access the printserver’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the printserver's web-based setup page.
Step 2:
Step 3:
When the printserver setup page appears, click Wireless.
Aug 01, 2009 | D-Link DI-704P Router
How to setup print server model 1205Mf for xp and vista
Whatever the model is, or brand, I always prefer to ignore the printserver software and just ADD a TCP/IP Port.
Open Control Panel
Open Printers
Right-click: Server Proprieties
Add TCP/IP Port
put the IP address and select option "Print Server"
That's it.
now, just add the printer, manually select the port you've just created.
Jul 12, 2009 | Edimax Computers & Internet
Communication between PrintServer DP-301U and HP LaserJet 1020
Trying turning your printer off and then back on. It happens sometimes that the print server looses the printer.
Alex
www.CAS411.com
Feb 13, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
Upgrade failure
The software that came with the WPS54G model is not (yet)compatible with Vista systems. This model is not listed on the Vista-ready devices from Linksys' website (www.linksys.com/vista). The behavior more likely a result of a software incompatibility.
For PrintServer network setup, you may still use the CD on a non-Vista system (XP, Win2000 or lower). Or, by installing it manually by accessing it's web interface.
To make your Vista working with the printserver WITHOUT the use of the PrintServer CD, do the ff:
1. Make sure PrintServer is configured on the network with the same wireless settings of your router and with a manually assigned IP address which is in range of the router's IP segment.
2. Make sure that computer can print locally to the printer (e.g. via USB connection to the printer).
3. When computer can surf the net and connected to the router's network (wired or wireless), follow the steps from this article and make sure Printer is showing up as Online.
Jul 07, 2008 | Linksys Wireless-G WPS54G Print Server
PS3207U problem with HP 1060
Same problem with a Hp 3300 and a Hp960c, both of them plugged and recongnized by the unit, there was no way to print.
Then I upgraded the unit firmware to version 1.3 and now both printers are working!
Jun 27, 2008 | Edimax (PS-3205U) Print Server
HP LaserJet 1018 & DP-G310
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
OR
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Jun 10, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Installation wizard does not locate the WPSM54G
hello!
what is the model number of your printer? if your setup cd is not detecting your printserver, try the ff:
-- while pc and printserver connected to the router and your printserver connected to your printer. try to reset the printserver for 30sec. Is it printing? If yes, do you see any IP address on the print out
-- If no, unplug the power for 5 seconds and plug the power back in of the printserver then try again to run the setup cd. you may also check your routers dhcp server table if its detecting the printserver
-- if printserver still not detected ty to connect printserver directly to your computer
-- search if you have bi admin utility on your setup cd and install it on your pc
-- manually assign static ip address on the printserver using the bi admin utility and on the pc
-- if successful, connect printserver and pc back to the router and check if you can ping the ip address of your printserver
May 01, 2008 | Linksys WPSM54G Print Server
Print server problem
I sorry but I am the similary problem whit my edimax equimed , what i can do , im dont print whit it.
Dec 29, 2007 | Edimax BR-6104KP Router (BR6104KP)
PSUS4 problem "talking" to Canon S330
Hi dreaddymck
I need a little more information on the setup. Is there a router in your network? If there is, is your PrintServer connected to the router and your computer is attempting to connect to the printserver through the router? If there is no router and your PrintServer is connected to your printer via the USB port and your computer is connected to one of the ports on the PrintServer via a cat5 cable, I would check to see whether you are actually communicating with the PrinterServer by pinging its IP address from the computer. If the ping is successful, then I would look at the printer properties in your computer's printer control panel and check the port configuration. Usually it is shows the IP address, port 9100 and port protocol is usually set to RAW. Otherwise I would attempt to reinstall the PrintServer using the CD originally provided. It appears to me that the server may not be publishing its IP address on your network.
--RoadHawk
Nov 27, 2007 | Linksys PrintServer for USB with 4 port...
Edimax 4 Port Wireless AP Broadband Router (br-6104wb) Logo
157 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
