Question about Samsung SC-D103 Mini DV Digital Camcorder
When I turn on the Samsung videocamera, the screen remains white
With very faint vertical lines.
  • luvs2tap5678 Dec 06, 2008
    Thank you for your reply. The white screen is on the camcorder itself. I haven't tried to connect it to the TV yet.
  • luvs2tap5678 Dec 08, 2008
    Thank you.
Please go to the following website for information on Samsung's settlement agreement in a Consumer Class Action Lawsuit. You may very well be able to get your camera repaired/replaced free of charge!
http://www.samsungclassaction.com/
Posted on Dec 07, 2008
    Scholar:
  • 107 Answers
Did you see it throuh to your TV or on the LCD of this CAM? when you are on CAM mode
If you see this lines through your TV then your problem is in the CCD image sensor inside the lens assembly it require a qualifier Tech and equipement to replace this CCD it cost about $160.00 Aus to repair it
If you see this line only on LCD on the CAM when you are on CAM mode then the problem is in LCD screen it might not worth to replace it
I hope that give you some ideas
Posted on Dec 05, 2008
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
May 03, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung monitor has white background with vertical color lines
if you have got access to another monitor try that it may be the computer or try another computer on the monitor hope this helps regards Jim
Apr 20, 2009 | Samsung Cell Phones
Black vertical lines on lcd screen
Has Bad LCD Panel hope its under warranty.
Apr 15, 2009 | Televison & Video
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Width increases a bit on lowering and incresing resolution
Hence my earlier suggestion of lowering the resolution, it was actually a test.
Now we are getting somewhere. Yoke is definitely out, opposing diode pair is also out. The remote chance of the horizontal sync/oscillator is also out. That leaves us only with a possible resistor that has gone up in value (or is open) (least likely) and/or a capacitor (most likely) that has leaked, bulged or whose capacitance has gone down.
Perhaps a service manual would be of more help.
Good luck.
Jul 20, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
JVC AV-K21TR
The faint white lines at the top of the screen is the warning that the pump-up capacitor in the vertical output circuit is going bad and the output itself is about to short out. When the TV stops working, the vertical output IC has finally shorted out. Replacing the vertical output IC, the pump-up capacitor and possibly a small value resistor next to the flyback (B+ for the v-out) should bring the set back to life.
Jan 26, 2008 | JVC AV-27230 27" TV
White screen. Faint vertical lines
Check capacitors that filter the signal from de character generator ic. Unsolder it or them if there are more than one (usually are of 220 micro and test it with an analog tester. If ok, look for the datasheet fo the IC and check if the vcc pin keeps energized when the monitor is on save mode.
Dec 16, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Samsung SC-D103 Mini DV Digital Camcorder Logo
150 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
