Question about HP LaserJet 4 plus Printer
2 IN. GRAY AREA DOWN SIDE PAPER
I rescued an old Laserjet 4 Plus from the basement of where I work. Turned on like a charm, sounds great, prints good( but needs new toner cartridge) I'm s however on every piece of paper coming out there's about a 2" wide light grey streak running down the right hand margin of each page.
  • 3 Answers
I too began to have vertical grey streaks on output from my trusty LaserJet 4 Plus. If I printed a page from text pad with just a single period on it the streaks were there, varying shades of gray in varying widths from 1/4 inch to 2 inches. I noticed the transfer roller was soiled in a way that matched the streaks and so was the green colored drum in the toner cartridge. I cleaned the toner cartridge and transfer roller and that completely solved the problem. 1. Cleaned transfer roller with old clean white dry t-shirt. Kept gently wiping toner off until it seemed pretty clean. Find info on web about how to remove the transfer roller in the service manual.
Get service manual by searching for LaserJet 4 on this web site:
http://www.eserviceinfo.com/
(you have to download it in several parts as .rar files, put all the rar files in one folder and then open the first .rar file with a program like Power Archiver and it will add all the files together into one big PDF file of the service manual) 2. Cleaned the half of the toner cartridge that houses the green drum roller. I followed the steps in Part 1 on this web page:
http://www.oddparts.com/ink/hp-4.htm 2A. I removed the green drum and wiped that off with old cotton t-shirt then set it aside out of the light. 2B. I cleaned the little roller (PCR roller) mounted behind the green drum, inside the toner cartridge with a slightly damp piece of cotton t-shirt, rubbed gently for quite a while to get to the white underneath the old toner. Did not get all of the toner off. Did not submerse this roller, just used slightly damp cloth. 2C. Detached the piece of metal that keeps old toner trapped in a compartment and also gently wiped toner off the plastic blade on it that is called the wiper blade. 2D. I scooped out old toner and then vacuumed out the rest from behind the metal piece described in 2C. Reassembled and no more streaks, totally clean page output.
Posted on Mar 01, 2009
    Problem Solver:
  • 12 Answers
There are several things that can cause this. A worn toner cartridge and/or transfer roller can cause vertical smears, but it may also be a worn fuser assembly. The teflon coating on the fixing (heat) roller wears off, and leaves vertical streaks of varying widths on the pages. Sometimes you may see "ghost" images on the pages for the same reason. Open the back door of the printer, and hold down the exit guide on the fuser (carefull, it may be very hot). There are two long rollers, the lower one is black, the upper roller is either grey or shiny brown. That's the teflon coating. See if it's peeled or damaged. If so, replace the fuser assembly.
Posted on Feb 17, 2007
How do you manually feed legal paper into a HP laserjet 4 plus (model 2037A)? It only has a letter paper tray. I inherited it without a service manual
The LaserJet 4 plus I have worked with had a paper tray that was adjustable for letter or legal. If yours is not, there should be a door on the front of the printer that will pull down at the top, and is hinged on the bottom. Open the door, you will be able to extend the "paper tray" and put a small amount of legal sheets on it. Go to the menu and tell it to print to this paper tray, I believe it is paper tray one.
Aug 02, 2013 | HP LaserJet 4 plus Printer
HP4+ print quality was perfect, but printer was jamming, so I replaced all the roller parts in the Maintenance Kit, which corrected all jamming! All the paper rollers and the transfer roller is now...
Run the 1/2 test.
Load paper in the manual feed tray.
Print anything that requires more than 2 sheets.
As the paper enters the printer open the top cover.
Remove the toner cartridge.
Look down at the paper.
If it looks like the problems you described, change the toner.
If it looks good, reinstall the old transfer roller and rerun the test.
If transfer roller doesn't fix it, you have a bad fuser. Put the old one in and repeat.
Jan 09, 2011 | HP LaserJet 4 plus Printer
Full of paper, not overloaded, no paper jam, sounds like tpulling paper but doesn't. While looking for on line troubleshooting, started printing my 2 pages that I needed. I tried to print again the two...
Remove the paper from the printer. Open the printer and remove the toner cartridge. Towards the back lower part of the machine is the paper feed tire. It is a gray rubber "wheel" and is on a metal bar that runs from side to side. Take a small cloth and dampen it with some glass cleaner. Clean the tire as best you can. May have to try and rotate it a bit to get to all of it. Then re-install the toner and reload the paper. If this works then great. If not it sounds like you may have a mechanical problem and will need service.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | HP LASERJET P1006 Printer
Hi, the printed pages come out with a gray film over most of the page
Do a "half test". Print a few pages, as the printer prints open the top cover. Pull out the toner and look down at the paper. If it has the gray cast, you have a bad toner cartridge or a bad transfer roller.
It could also be a dirty ground. Try vacuuming out the inside of the printer especially around the transfer roller.
Jan 29, 2010 | HP LaserJet 4 plus Printer
HP Laserjet 4plus chewing us paper
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Sep 30, 2009 | HP LaserJet 4 plus Printer
Lasejet 4 plus- try to print. lower paper cassete full. printer screen says pc load letter and have to manualy load paper. print icon on computer says out of paper
There is a paper empty flag sensor, looks like a plastic paddle, in the tray area. Pull out the paper tray and flick it; make sure that it is not jammed.
Also on the right hand side there is a paper pick- up roller, clean it with a cloth with some alcohol. See page 4-13 for the location of paper feed pick-up roller. page 5-27 shows the paper empty sensor flag
Here is the service manual:
http://home.comcast.net/~wannabeyote/hp-lj-4-5-m-n-plus.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 06, 2009 | HP LaserJet 4 plus Printer
Black marks on left side of paper
how far apart are the spacings? inches or cm would be fine
Apr 02, 2008 | HP LaserJet 4 plus Printer
HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
Dec 31, 2007 | HP LaserJet 1320 Printer
HP LaserJet 4 plus Printer Logo
1,129 people viewed this question
Clive
Clive
