I have a beko eco care washing machine. It isn't emptying properly. I have emptied the filter and checked the pipes theres no blockage what could it be?
  • Anonymous May 04, 2009
    my washer is stuck on prewash and wont move from this program.
  • Washing Mach... Master
  • 3,463 Answers
If you are certain the pump is working,hold the drain hose directly into a bucket or something similar and see how fast the water pumps out.
It should come out with a reasonable force, if it does not, then you have partial blockage somewere in the m,c.
Posted on Dec 05, 2008
BEKO eco care WMA W10, replaced brushes still wont wash or spin,pls help
Hi if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Apr 08, 2013 | Beko Washing Machines
Water wont empty from my machine
Hi if your beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Nov 04, 2012 | Beko WME7247W Washing Machine
MY BEKO 765s washing machine, has stopped working mid load, on the display it is flashing iL but its smaller, it has also gone onto pause, and wont go on to start, also on flashing on 1200. This was a...
Hi if your beko 765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Dec 31, 2010 | Televison & Video
Washing machine will not empty out not a year old yet tecnik 9909 no filters to clean in the front of machine. Any answers?
Hi
Before examining the fault, it is usually worth trying to empty the machine manually, this can be done by removing the outlet pipe and lowering it into a bucket, when gravity should allow the water to empty from the machine. This method will not work with certain German made machines where the mounting for the outlet hose is too high to allow a gravity discharge.
Often the reason for non-emptying is a blockage. This usually involves removing the pipe connecting the bottom of the tub to the pump, but be careful because dirty water will gush out. The blockage could be due to a lost item of underwear or a broken-up soap ball. The soap ball is a supposed to make the machine more efficient by keeping the soap in the tub, but it frequently jams and causes machine emptying problems. If there is no obvious blockage then you need to check the pump, which you can do by putting the machine on an empty cycle and listening to see if the pump is turning. However, even if the pump is rotating it is possible that the rotor has come loose or has broken vanes, so you really need to check that it can generate water flow. If the pump is not turning then check for an obstruction directly in the pump, such as a coin or bra-wire. If the pump is working fine, then the trickiest problem of all could be a coin in the outlet pipe. This is a hard one to diagnose because this kind of item is very difficult to find. The best cure for this is to have a pole which is close to the internal diameter of the pipe and shove it from one end to another.
Thanks for contacting fixya.com
Nov 18, 2009 | Tecnik Washing Machines
Drum does a small turn then stops but wont empty -wont wash either beko 1000 rpm
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Aug 23, 2009 | Washing Machines
Beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Jul 01, 2009 | Washing Machines
Washing machinenot emptying
If it has a filter, remove and clean. Check outlet pipe for blockage or restriction, if still no success, remove hoses from pump and check for blockages here, also check inside pump for anything that could be stuck in there.
Hope this helps.
Plz leave feedback.
Thanks.
Dec 12, 2008 | Hoover Washing Machines
Water will not empty
Hello
you either have a blockage in the filter or you pump is not working.
how to check is diconnect the waste pipe and lower it to ground level if the water does not empty then its a blockage. if it empties then its the pump.
other things it can be is a blockage where the waste pipe is connected or a loose wire to the pump..
Dec 13, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
