I have Hp DeskjetF4280, everything is intact, I'm not sure about the wires but i know i put them in good last night,i can scan, i can do everything on this printer except print from the computer itself. I have a paper due tomorrow, and it wont print, i click print, it prepares, goes to 1000%, and does nothing.
    New Friend:
  • 3 Answers
Check the connection the USB cable if it is okey check the status of the printer OFFLINE or READY ,it should be on ready, go to control panel view installed printer , and set as default printer.
Posted on Dec 29, 2012
  • 903 Answers
Check that your printer settings are set correctly, and not set to print to file. Also make sure that you have the software up to date including HP solutions, as his can help you when you have problems such as this.
Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3390949&lc=en&cc=us&dlc=en&submit.y=5&submit.x=12&lang=en&cc=us
you will see a picture of your printer with some options below it, such as troubleshooting, updating drivers and software etc...
I hope this helps
Posted on Dec 05, 2008
2012 Harley Road King won't start. Tried jumping the bike with a portable jumper. The bike started twice but as soon as the jumper was disconnected the bike died. On the third attempt some smoke came from...
Go to your battery find out where that smoke is coming from. It sounds like summer your wires melted together. That was cause everything the short out, make sure your battery is charged, take it out of the bike and charge it and make sure you got about 12.67 V coming out of it. When you tested smoke coming from anywhere as bad. You could have some wires melted together file your wire harness, make sure that's not so
Feb 23, 2015 | Road Motorcycles
How do I stop my 2004 Honda Odyssey from honking the horns. (Honda Factory Alarm). I need to know for sure that if I remove the positive battery cable, will the horns stop immediately? How long do I l
As a short term solution you can disconnect the horn. This will stop the noise and leave your other systems intact. Locate the horn under the hood and find the attached wire and disconnect it. If you have trouble locating the horn have someone beep it for you a follow the sound to it's source.
Nov 28, 2014 | 2004 Honda Odyssey
After XP re-install, hp5610 scanner function fails
Reinstall the drivers ... making sure you have the latest driver from HP for your XP operating system.
Mar 03, 2010 | HP Officejet 5610 All-In-One InkJet...
I want more horse power without having to due an engine swap whats the best way to start everythings stock
start with intake manifold cold air intake not a short ram intake performance spark plugs wires and distributor cap, headers exhaust system not a tip.
make sure you have an LSD transmission then pull apart the motor mainly the head change out valves, spring retainers, and springs. new camshafts make sure you buy the springs and spring retainers before you put in the new cams. if you have the money to bore out the block it be better to take your block clean it up and put darton sleeves then buy a new crankshaft new psitons and rods with new rings all of this will cost a good deal but will increase performance a turbo should be the last thing you do increase the motor HP and max it out then put in a turbo but ensure your car is sleeved darton sleeves are the best never had a problem. i used to own a 2000 honda civic si i pushed 239 HP staright motor B16A2 motor. good luck any other questions let me know
Nov 03, 2009 | 1994 Honda Civic Del Sol
Two different size ultraviolet ballast. The .71AMP ballast feeds two 40W ultraviolet ''UV'' bulbs. The .37AMP ballast feeds one 40W ultraviloet bulb. The two light to larger bal;last want come on. The...
I usually test the ballast simply by excluding everything else.
1) Put in bulb that you know works
2) Replace starter (if you have one)
3) check that wiring is intact (sounds like it is for you but I had one light that the wiring barely made contact so sometimes it came on and sometimes it blinked)
4) If all that is good, then it's probably the ballast.
Sep 29, 2009 | Garden
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
I have a vr-255 receiver and the power light flashes
Hi Willie,
If the standby indicator is blinking that just means that the speaker wires are short circuited some where. Make sure all of the wires are intact, unplug everything starting with the power. Then you will want to make sure all wires going to the receiver are not kinked / twisted / or exposed. If all wires look good, plug everything back in and power on the unit. you should be good to go.
Oct 23, 2008 | Kenwood Audio Players & Recorders
HP C7180 photosmart Scan problem
first: the C7180 will only work in ONE mode: wireless or wired. End of story there.
second: I spent almost 4 hours, yesterday, fixing this problem - "would not scan to computer because printer did not recognize computer for scanning yet would print & copy ok". I did solve the problem! Here is what I did: 1) removed all software related to C7180 ( make sure it is all gone ). 2) turned off all firewalls & security measures to ensure a clean, uninterrupted reinstall ( be sure internet connection is off for this to be safe ). 3) reloaded software ( hopefully you have the cd for this ). 4) followed all prompts for reload of software & then rebooted computer & tested copy mode, fax and finally scan. 5) went to HP site & made sure I had all updates & everything was ok with drivers. It was. I now have a clean install & all works as it should. The whole process ( after I figured out that it was a software problem ) took about 1 hour. Don't forget to reset your computer security! Be sure your firewall knows all HP software is good & firewall will let it thru.
This should do it.
Oct 03, 2008 | HP Photosmart C7180 All-In-One InkJet...
48 people viewed this question
k24674
jasbo
jasbo
