Question about Parallel 6 Foot DB9 Male - DB9 Female Null Modem Cable (NM96MF)
Meaning of Db and the use of Db9-male Cabl
What 's the meaning of Db and the use of Db9-male/db9-female Cabl
  • 4 Answers
The D is the shape of the connector when looked at it on it's side. The second letter (A,B,C,D,E) defines the amount of pins in the D connector. "DB9" is actually called DE by the standard and the E=9 pins. A=15, B=25, C=37, D=50, E=9. This standard was set in place by ITT Corp (Not the school) in 1952, and DE-9 connectors were used for tons of applications. (Machinery, Cars, etc). If you are only referring to the computer uses, the connector is widely known as RS-232 or a "Serial" port. These ports in computers were/are used for devices like early printers, scanners, networking hardware, or even as a method of connecting to the Internet at one point.
Posted on Dec 12, 2008
Web page + 3102
You can't web to a 3102 phone, only the phone system. If you don't know what the IP address is on the phone system, you will have to get a serial cable (null modem cable) DB9 male to DB9 female and connect to the console 1 of the phone system. You will need a terminal emulator program and connect at 9600, 8, none and 1 for the settings. Type nbxIpConfig (case sensitive) and hit enter. The IP address will then be shown. If this is not what you were asking, please explain.
Feb 19, 2014 | 3Com NBX 3102 IP Phone
My radio remote will turn on but then the buttons will not work to control the unit. I have to unplug the unit to shut it off .Anyone else have this problem?
#1. Disconnect the main power to the JBL box.#2. Check the DB9 cable connections, spray with Contact Cleaner (Techspray T8-162210S) in the male & female terminals.#3 Use a toothpick to press a reset button located top left close to the DB9 socket on the JBL box. #4 Reconnect power a& test operation. Good Luck! : ) : ) : )#5 843-849-9037 Ask about warranty or Technical support.
technicalsupport@prospectelectronics.com
Feb 01, 2012 | JBL Mbb319 SiriusReady AmFm Receiver
Does a de/db9 to dvi-d female adapter even exist? Is there a combination of adapters I might be able to use? I need an adapter with one female de/db9 to connect to my computer whose other end is a...
Looks like it does exist...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380342442870&hlp=false
Are you sure its a DB9 and not an hd15?
Jun 11, 2011 | Televison & Video
Wiring diagram from db9 to rj-11 to open cash drawer
This IBM page seems to have the information needed to wire a DB9 to RJ11 for a cash drawer:
http://www-01.ibm.com/support/docview.wss?uid=pos1R1003522
Jan 12, 2010 | Adapters.com RJ11 / RJ12 (6 Conductor) -...
My adapter DB9 FEMALE TO DB25 FEMALE doesnt allow me to see my Printer
Are you tring to run a parallel printer from a serial port? If so then it will not work at all. You would need a serial to prallel adaptor that also has the software drivers needed to convert the signal.
Jun 13, 2009 | Parallel 25 Foot DB9 Female to DB25 Male...
I have an MSI motherborad model MS-7366 and I need to plug a DB9 male to 10 pin header pc blanking plate I just need to make sure I am pluging it in the right place
LOOK AT THE ROWS ON PINS ON THE PLUG IN CABLE ,THAT THE MALE END. AND THE LABTOP HAS THE FEMALE END AND IF FOTH LOOK THE SAME THAN PLUG IT IN, BUT THE MALE END MAY NOT HAVE ALL THE PIN LIKE IN THE FEMALE PLUG LOOK LIKE THAT OKAY
MAKE SURE ALL THE PINS ARE STRAGHT
CANDYMANGANDY
Jan 28, 2009 | Intel Motherboard
Rj45 male to db9 male cable for ups
If you have a BackUPS CS, you are probably either using it with the USB cable that is supplied or with the 940-0128A supplied by APC, which permits running the UPS in dumb mode. By building your own cable, you can now run the BackUPS CS models (and perhaps also the ES models) using smart signalling and have all the same information that is available as running it in USB mode.
The jack in the UPS may be easily use a 8 pin RJ45 connector. It is easy to construct the cable by cutting off one end of a standard RJ45-8 ethernet cable and wiring the other end (three wires) into a standard DB9F female serial port connector.
PC Signal PC pin UPS Pin UPS signal RxD 2 2 TxD TxD 3 8 RxD GND 5 7 Ground FG Shield 4 Frame Ground Though these UPSes are USB UPSes, APC supplies a serial cable (typically with a green DB9 F connector) that has 940-0128A stamped into one side of the plastic serial port connector.
Here is suggested scheme of original 940-0128A cable
APC Part# - 940-0128A computer --------- Inside the Connector--------- UPS DB9-F | | RJ45 pin - signal | | Pin - Color | | 4 DSR ->|---+ | | | diode resistor | 6 DTR ->|---+---->|----///---o kill power | 8 Orange | | 1 DCD <-|----+ | | | | 2 RxD <-|----+----------------+--o low battery| 3 Brown | | | 7 RTS ->|----------+--///--+ | | | | | +--///--+ | | | | 8 RI <-|----+----------------+--o on battery | 2 Black | | | 9 CTS <-|----+ | | signal | 5 GND --|-----------------------o ground | 7 Red | | 3 TxD | | | chassis | Chassis/GND |-----------------------o ground | 4 Black | | | Not connected | 1, 5, 6, 9, 10 --------------------------------------
Sep 30, 2008 | Digi (76000200)
What is the right rs232 cable to connect a Denon 3808CI reciever and a Phillips RFX9600 serial extender
OK LOOKING AT THE SPECS FOR THE EXTENDER YOU DO NOT NEED TO WORRY ABOUT THE SERIAL CONNECTIONS, WHEN USING THE SERIAL CONNECTIONS YOU NEED RS232 CODE STRINGS TO CONTROL THE DENON OR ANYOTHER DEVICE THROUGH THIS EXTENDER USING THE RS232 CONNECTIONS.
IT LOOKS LIKE YOU CONNECT AN I/R EMITTER FROM AN MINI JACK I/R CONTROL PORT ON THE BACK AND THE OTHER END TO THE I/R WINDOW ON THE DENON
Feb 27, 2008 | Denon AVR 3808Ci Receiver
Computers & Internet Logo
912 people viewed this question
Top Parallel Computers & Internet Experts
David Payne
David Payne
Are you a Parallel Computer and Internet Expert? Answer questions, earn points and help others
