Question about HP Hewlett Packard LaserJet 2605dn Printer
I seem to have lost my manual for my 2605 Printer
What I want to do is to set the printer to print only the selection, not all of the page or document.
I do not remember how I set that option, so I could do with simply an idea of how to set the printer to do that.  From web sites, I need only the important text and I do not wish to have the page all messed up other stuf, art work and such.  All I care about is the text.
Thank you for your help. Jim
  • 4,472 Answers
Your best bet is to just copy and paste the text into a word document. You can get the manual for your printer by following this link and selecting your Operating System.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140731&taskId=135&prodTypeId=18972&prodSeriesId=1140727&lang=en&cc=us&submit=Go%20%BB
Please take a moment to rate my solution fixya.
Thanks,
Lee
Posted on Dec 05, 2008
When I print a one page document, tray 1 prints on multiple papers at a time. 1 page prints on 5 pages.
If you don't have a manual, you can find one here
My guess is either on the printer or the driver. Skimming the manual, it doesn't seem that you can set the default number of pages printed per sent print job on the printer, but that is something I would look into. This is a nice office printer, perhaps the printer is set to print multiple copies of everything it is sent. You could determine if it is the printer or driver/computer by printing to it from another computer.
If it is the computer, go into the control panel and select the properties for this printer. In there, check if the number of copies is improperly set to 5. This would happen for every print job sent from this system.
Does it print 5 copies of documents sent from different programs (i.e. Web Page, Word, Excel)? Quite possibly, one time you set it to print 5 copies and that application retained that as default. In that application, rather than clicking "print" click "printer setup" and look through the settings to see if it is requesting multiple copies.
I am 95% sure one of these three solutions will solve your problem.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
I lost my Manuel and when I try to print something
Here is a download page for your manual:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=331&modelid=8046
as for the settings........
Go to0 the start menu, select "printers and devices"
select your printer, select printer preferences,
and change the setting from the menus.
There ya go!..........Please remember to RATE ME. Thank You.
Mar 08, 2010 | Canon BubbleJet i550 InkJet Printer
Color printed pages are too light.
  • Troubleshooting Setup and Install If your device is not recognized:
    • Verify that your cable is USB 2.0 high-speed compliant.
    • Ensure that your cable is connected correctly. Remove the USB cable, look at the end of the cable, and then match it to the pattern on the USB port. Make sure that it is not upside down. Insert one end of the USB cable completely into the USB port on the HP device and the other end into the back of the computer.
    • Check that the peripheral is turned on. Peripherals will not be recognized if the power is off.
    • Ensure that your USB cable is no more than 15 feet or 5 meters in length.
    • Check that the USB port is enabled. Some computers ship with disabled USB ports.
III. INSTALLATION INSTRUCTIONS When operating in a Windows environment, the CD-ROM setup or installation software detects the version of the operating system that you are running. The software is installed in the language that you have selected. For example, if you are running an English version of Windows and have the language preference set to Spanish, the installation utility will install the Spanish version of the printing software for the appropriate Windows version. INSTALLATION OPTIONS Two methods are available for installing printer drivers and software components for the printer.
  • Full (Recommended) . Installs everything that your device needs to work plus HP Solution Center:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL6 driver
    • HP Toolbox FX . Allows you to change some printer settings and contains documentation and self-help tools.
    • Screen Fonts . Printer-matching TrueType fonts help ensure WYSIWYG printing.
    • HP Color LaserJet 2605 series printer documentation. A list of documentation, which includes information about product operation, troubleshooting, warranty and specifications, supplies, and support.
    • HP Solution Center . Use HP Solution Center to gain access to product-specific software and on-screen help. By using HP Solution Center, you can access the HP Shopping Web site and update your HP software. If you have the HP Color LaserJet 2605dtn, you can also transfer images from a photo memory card. To start HP Solution Center, click Start, Programs, choose the HP program group, and then click HP Solution Center.
    • HP Photosmart Transfer . Software for transferring images from photo memory cards to your computer (HP Color LaserJet 2605dtn only).
    • HP Product Assistant . This software detects problems that occur with your HP products and can offer solutions to help you resolve those problems.
    • HP Software Tour . Use this for an overview of the software features.
    • HP Software Update . Use this software to check for software updates for your HP products.
  • Minimum . Installs everything that your device needs to work. The following is a list of available components:
    • HP Color LaserJet 2605 PCL 6 driver or HP Color LaserJet 2605dn_dtn PCL 6 driver.
INSTALLING SOFTWARE ON WINDOWS 2000 and XP Printing system installation from CD-ROM, Internet download
  1. Close all programs.
  2. Insert the CD-ROM.
  3. If the HP printing system installer program has not started after 30 seconds, complete steps 4 through 7.
  4. From the Start menu on the taskbar, select Run.
  5. Browse to the root directory for the CD-ROM drive.
  6. Select the SETUP.EXE file, click Open, and then click OK.
  7. Click Install.
  8. Follow the onscreen instructions.
USB Installation for Windows 98 Second Edition, Windows Me and Windows Server 2003 (Plug and Play Install)
  1. Turn on the printer and computer.
  2. Verify that the printer displays “Ready.�?
  3. Attach the USB cable to the printer and computer.
  4. When the Add New Hardware Wizard appears, click Next to install the USB Printing Support.
  5. In the following dialog, select option Search for the best driver for your device, and click Next.
  6. Make sure the HP Color LaserJet 2605 series CD-ROM is in the CD_ROM drive, select Specify a location, browse to your CD_ROM drive, and select the Drivers folder, then either Win98_Me( for Windows 98 and Windows Me) or Win2000_XP (for Windows Server 2003). For example, CD ROM drive:\Drivers\Operating System\Language. Choose OK, and then click Next.
  7. For Windows 98 SE, in the USB Printing Support dialog, you should see the path and file name. Click Next. For Windows Me and 2003 Server, this step may not apply.
  8. Once the files are copied, click Finish.
  9. Steps 4-9 will repeat to install the printer driver. File names will change. At step 9, you have the option to rename the printer. Click Finish. After files have installed, click Finish to close the dialog.
Network Installation for Windows 98 Second Edition, Windows Me, and Windows Server 2003
  1. Download HP's Install Network Printer Wizard.
  2. Run Install Network Printer Wizard and follow the on-screen instructions.
INSTALLING SOFTWARE ON MACINTOSH OS 10.2.X, 10.3X, and 10.4.X USB installation instructions
  1. Insert the CD-ROM.
  2. Run the installation utility.
  3. After the software installation is complete, attach the USB cable to the printer and the computer and then restart the computer.
  4. After the computer has restarted, open the Print Center or Printer Setup Utility to see if the printer name appears in the Printer List.
  5. If the printer name displays in the Printer List, the setup is complete. If the printer name does not display in the Printer List, go to the next step.
  6. Click the Add button, and then select USB from the drop-down list. 7. Select HP Color LaserJet 2605 and then click Add. The printer name displays in the Printer List. Setup is complete.
Jan 27, 2010 | HP LaserJet 2605DTN Color Printer
How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Oct 09, 2009 | HP LaserJet 2605DTN Color Printer
My printer is printing colour red faintly, the toners are new and genuine. it also takes some times before it starts printing.
Sherry, in all probability it is the "scanner assembly" HP can fix this for $279 in the US using HP Express exchange 1 day ship, this was the result of their active chat. I am having the same problem and am going to dismantle the printer myself to see if I can't clean the scanner mirror myself. If you search the following words on google you will find some info, fading red tones laser jet 2605, one of the first results is a page on the HP site specifically on laserjet printers. I wish I had a quick fix that would help; however, a new cartridge won't help!
Feb 09, 2009 | HP Laserjet 2605 Printer
I 560--photo printing on 4"x6" paper
You should be able to do this in print preferences. Open up your general printer box by clicking on Print. Select print preferences then page setup then select page size and a list of sizes will appear just select 4x6 and then paper type, press print and you have done it.
You might be able to get a manual from the Canon website or 'google' for the one you want.
Please remember to rate this solution.
Nov 05, 2008 | Canon BubbleJet i560 InkJet Printer
Printing incorrect HP color laserjet 2605
Possible causes
Bad Print Drive
Remanufactured Toner Cartridges
Print a Demo page from the Printer Control Panel. You do this by pressing
Menu
Computer Information
and then select the Demo Page and press the Green Key to select that choice
Oct 09, 2008 | HP Color LaserJet 2600n Printer
Can't color balance 2605
well, the density is actually a combination of two aspects. The original document settings, especially in color transforms. Usually, the software will have a transform specific for the printer. In my experiences, trying to tweak the printer for each print job, can cause extreme frustration. Check the software manual for settings for your printer, and perhaps you'll get closer to this solution.
Got backup?
Feb 07, 2008 | HP Color LaserJet 2600n Printer
HP Hewlett Packard LaserJet 2605dn Printer Logo
141 people viewed this question
Ben Johnson
