Question about Asko T700 Electric Commercial Dryer
ASKO t700 dryer thumping sound
Each time out T700 dryer drum rotates, there's a fairly lound thump. It's definitely a drum issue, as I can watch the drum & it thumps exactly the same time each rotation. If we need a new belt, is that something a DYI'er could do? Any other suggestions would be appreciated.
  • 4 more comments
  • worker1 Dec 30, 2007
    I have the same problem. Is there help on how to replace the rollers?
    Exactly the same problem. Anyone know about changing the rollers?
  • Anonymous Mar 31, 2008
    I have the same problem with a constant thumping on my T700. I have read the possible fixes. I will look into these and post my findings.
  • Anonymous Oct 04, 2008
    My thumping started off fairly quiet but regular (sort of like a unbalanced washing machine on spin cycle). But today, after two loads of drying, the thump was VERY pronounced and loud.
  • Anonymous Mar 18, 2014
    dryer heats but wont dry and now makes lound slapping thumping noice
  • Anonymous Apr 01, 2014
    how many drum roller on asko t761 dryer
  • 175 Answers
Usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Posted on Mar 25, 2007
The drum sits on two rollers, one of them might have broken like it happened to me. just replace it.
Posted on Jun 19, 2007
SOURCE:
The drum stopped turning on our Asko t700 dryer even though the dryer motor works fine so it runs and blows air but will not turn. Both of the fuses seem fine and as I say the motor and everything else is...
the belt is broken, here is a thread:
http://applianceguru.com/forum2/2043.html
here is a manual:
http://www.ajmadison.com/ajmadison/itemdocs/English-T711-721-731-761-781_UCG.pdf
Hope it helps Tim
Apr 25, 2011 | Asko T700 Electric Commercial Dryer
I have an ASKO T700 dryer. When I turn it on, it makes a high pitched squeak. If it's on for longer than a minute, I can smell a burning smell. Any suggestions?
you got a roller or belt idler not turning and burning the drum belt. you have to take the dryer apart and find the problem. if you need to lubricate a roller or idler use mineral oil or roller oil, do not use wd-40 or 3 in one.
Feb 12, 2011 | Asko T700 Electric Commercial Dryer
When operating dryer makes LOUD thumping noise. Is this fixable?
this sounds like rotator wheel(s) are broken. It is some what an easy fix. The drum dyer needs to rotate those wheels. Usually you need two.
Jan 05, 2011 | Asko T741 Dryers
I have a asko t700 it goes on drum turns but no heat when set at high or low heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Asko T700 Electric Commercial Dryer
Our Asko dryer (T720) has begun to make a heavy thumping noise, even if empty. (Sounds like a single wet & heavy object is in dryer)
Usually the drum rollers wear on that model making a thumping noise. The asko is a tough machine to work on. You may need a technician to service it.
Aug 01, 2008 | Asko Dryers
Aslo T700 Dryer Heats but won't dry.
TRY DISCONNECTING THE EXHAUST FROM THE BACK OF THE DRYER AND RUN ONE LOAD THROUGH IT. IF IT DRIES O.K., THEN YOU HAVE A RESTRICTION IN THE DUCT WORK.
Apr 07, 2008 | Asko T700 Electric Commercial Dryer
Asko T700 loose belt, access from front?
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Jan 12, 2008 | Asko T700 Electric Commercial Dryer
Replacement part for Asko Dryer T700
Call Asko and order it there. Cant imagine that it is a expencive part. I only have the Norwegian partnumber.
Dec 24, 2007 | Asko T700 Electric Commercial Dryer
Asko T700 dryer
Seems like you need new drum rollers. If one(or both) is bad, the drum will rub in the plastic.
Dec 10, 2007 | Asko T700 Electric Commercial Dryer
Asko T700 Electric Commercial Dryer Logo
1,048 people viewed this question
Top Asko Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
jimorris77
Are you an Asko Dryer Expert? Answer questions, earn points and help others
