We have a HP pavilion dv2000. When turned on the screen became static (snow) and went black. Now when turned on no screen comes up and the wireless light won't show and the caps lock lite won't light up. There's no sound. The DVD door will open when button is pushed. We tried to hook it up to an external monitor but no luck there. Any ideas?
  • 3 more comments
  • shaleelee29 Dec 05, 2008
    There isnt any beep. .theres pretty much no response from fan, monitor, screen or the caps lock and wireless lights.
    i love how this site works =)
    ive tried plugging it into different outlets, even taking out the battery and putting it back in. still, its the same. . power lights turn on, cd drive runs, then turns off, but no response from the screen, fan or sound coming from the machine.
    no power shortages or outages.
    is there a chance with this brand of labtop, there is some kind of protection or something on it so that if the fan malfunctions, the harddrive and computer will not turn on?
    or is there potential that my problem is caused by a harddrive malfunction?
  • Dan
    Dan May 11, 2010
    Sorry, I missed that part about it being a laptop.
    "is there a chance with this brand of laptop, there is some kind of
    hard drive and computer will not turn on?"
    - I'm not sure of that ... If the fan doesn't run the processor will heat up super fast then it will overheat and burnout.
    You are getting power, but no hard drive lights?
    Could either be processor or hard drive failure.
    But, I would try to boot to a cd before I replace anything else. if you can boot to a cd , then then problem is your hard drive.
    Try a windows install CD if you have one.
  • Dan
    Dan May 11, 2010
    Have you had any recent power surges / outages or lightning storms?
    If your monitor goes out, typically you will not get snow, it will just go black. If your monitor is working btu the pc is not, then you typically get a no video message.
    I would try unplugging everything and using a different outlet, plug the monitor into the wall and see if that turns on, if it does, then that should be fine and the issue is your pc (which sounds like the case since no fan or lights are coming on.
    Plug in you rpc and turn it on - be sure to note any sounds or lights. At minimum you should here the fan. if that doens't come on you will have to start troubling shooting each peice of equipment.
    Let me know how this goes and we'll go from there.
  • kondwani mbewe May 11, 2010
    do u get any beeps?
    Problem Solver:
  • 12 Answers
You need a new mother board, good luck, u will need it.
Posted on Jan 06, 2009
  • 3 Answers
It's a bad hard drive. If u have any bootable cds, dvds, floppys....try booting to one and if you can.....bad hard drive. I had the same problem with an HP laptop.
Posted on Dec 07, 2008
    Sergeant:
    Novelist:
  • 192 Answers
Hi there. I have to agree with fidoliedo and Binary Bob. Just to comment on resetting the BIOS by removing the battery (as in solution 4). The battery being reffered to is the CMOS battery, which is located on the motherboard. On most laptops, to get to it, you will need to take them apart, and even then, some can be a real pain to get out. I would not recommend this unless you know what you're doing.
  • Timothy Farley Dec 07, 2008
    Also it very much sounds like the FSB. Had the exact same problem with my Acer. It's to do with the memory slots and the motherboard/system board. Just thought you'd like to know.
    Scholar:
  • 162 Answers
System board. Inverter sounds like it's working fine because you can open the CD door and so forth, but since the system won't power up, your board is out.
Posted on Dec 06, 2008
    Scholar:
  • 91 Answers
Remove the battery and connect your ac adaptor. Wiil it power on?
If not you may have to replace the ac adaptor or possibly the system board.
If it powers on, Try to get into the system BIOS. Press <F10> at power on. Can you get into the BIOS?
If you get into the BIOS verify that the Boot order is as follows:
Boot Order—Set the boot order for:
❐ USB Floppy
❐ ATAPI CD/DVD ROM Drive
❐ Hard drive
❐ USB Diskette on Key
❐ USB Hard drive
❐ Network adapter
If not there is a chance that you may need to replace the system board. Tray this and let me know what happens. Thank you, Binary Bob
  • 60 Answers
 hi I have you tried resetting the bios by removing the battery, there could be many things to look, from buying new item and changing them which could cost as much as buying a new machine or a refurbish of the same type then you have spares part in the future
    Problem Solver:
  • 14 Answers
It cub b a problem wit ur processor try changin tha processor and c wat happens
sam tyms its tha ram but wen its ram it gives a beep
Posted on Dec 05, 2008
My HP Pavilion dv2000 turns on, but screen is black
If the laptop appears to boot up but the LCD screen is black, then the problem is a back-light fault caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 14, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hi, i have an HP Pavilion dv2000 & it had recent motherboard problems, so I had it repaired in the HP Service Center. They replaced the motherboard & so far, everything was okay until yesterday....
Yes, the GPU is faulty. either replace the systemboard or reflow the GPU. Second option is cheaper and you can do it yourself. There's a link for a diy guide to fix that issue.
does your screen look like this?
http://bootmylaptop.com/hp-pavilion-dv2000-with-display-issue/
Jan 30, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a HP Pavillion dv2000 that just went black on me. Power light is still on but the screen is black and not responding. please help.
Hi!
Most common cause for this happening is the inverter or backlight for your LCD screen has become faulty. It's quite a common problem & unfortunately the only way to fix it (if its outside of warranty) is to replace the LCD with an LCD kit which can be ordered through HP or sometimes through eBay.
Obviously if it's still within it's warranty perioud, contact HP Customer Support for a replacement/repair.
Hope this helps
Nov 21, 2009 | HP Pavilion dv2000t Notebook
The screen on my hp pavillon dv2000 went totally black. Tried an external monitor, but nothing... still a black screen ! Help please
There are VGA port issue in the Motherboard .Pls repair it by vendor or connect any PCI gGAPHICS CARD FOR THE SAME.
Nov 18, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
HP Pavilion dv2000 would not start up, black screen
try to re install first the software or program then observe if the same problem,, check the lcd inverter...
Jun 07, 2009 | HP Pavillion ZV6000 Notebook
HP Pavilion dv2000 Screen Flicker
Please replace the screen for optimal performance.
Do rate this.
Feb 25, 2009 | HP Pavilion dv6000z Notebook
Hp pavilion dv2000 no lcd dispaly
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Sep 24, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
HP Pavilion DV2000
first replace the inverter to correct the lighting problem ok. then move to the other problem both can be recovered from
so ebay dv2000 lcd inverter buy it get a screw driver link me bakerandre2000@yahoo.com
Apr 14, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
