Question about Dishwashers
Just fitted a new circuit control board for my indesit di62, the test cicle started and ran until finished. I heard two beebs to tell me cicle had finished but when I looked at the program selector the second and third lights were flashing. Had a chat on the forum and it mentions about draining off a flood tray but not sure how this is done so looking to confirm that this is the error message and how to correct it. thanks Dave.
    Champion:
  • 249 Answers
Leave outlet hose flat down ground level
Posted on Dec 06, 2008
Treadmill SLT-02 flashs E1 and wont go. Everything else has been checked out and has a new belt and otherwise in good working order. How do I fix it
Please test the motor with the thermic switch inside of motor, for open or close, and repair. 2) Test the main motor with BATTERYR motor cicle 12Vdc, and see if the motor is running.
3) If everything is o.k the Controller motor board is faulty. replace LED Blink Patterns on the Control Board Treadmill
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 21, 2017 | Exercise & Fitness
Indesit iwc61651 washer starts up and begins wash then trips electrics 5 mins in it will spin and drain completely but won't finish a wash will a new top board and panel correct this issue?
It sounds like there is a short circuit on the heater or within the heater circuit. Remove the wires from the heater and using a test meter place one lead on one of the terminals (not the earth terminal) and the other lead on the heater case, this should give you a reading if there is a short circuit in the element itself.
Mar 29, 2017 | Indesit Washing Machines
I have a toshiba estudio 3530C. I just replaced the finisher and am now getting a C580 error code. Can you tell me how to remove that so I can use the machine?
Communication error between IPC board and
finisher.
(1) Confirm the setting of 08 Code 1912.
(2) Check if the specified finisher is attached.
(3) Check if the harness connecting the IPC board and the finisher controller PC board is
disconnected or open circuited.
(4) Check if the conductor pattern on the IPC board is short circuited or open circuited.
(5) Check if the conductor pattern on the finisher controller PC board is short circuited or open
circuited.
(6) Replace the IPC board.
(7) Replace the finisher controller PC board.
Mar 28, 2017 | Toshiba Office Equipment & Supplies
Hello sir i have scooter mobility pride 3 wheel i but new battery than 1 day after i wash scooter the scooter not drive gave beeb 7 time than stop now a lot beeb if you can please tell me what to do
hi, well that's a 70amp rhino controller, beeb seven normally amounts to a throttle pot (wig wag ) fault... i suggest you make sure there are no water around the connector plugs going into the controller , please remove one battery lead before proceeding..I do offer free controller testing and have swap out units if required for as little as £40...
Regards
Rob
Jan 31, 2016 | Pride Health & Beauty
All of the lights on my Indesit WIL123S washing machine are flashing. All the repair people that I ring tell me I need to replace the circuit board but I believe the capacitor is broken because the x-mark...
how would you tell if what capacitor is faulty on the board I would rather seek out a college who is perhaps more used to testing such items as the AC mains is lethal and I would not want to give you any reason to injure your self please be careful eric
Dec 23, 2017 | Indesit W 123 Front Load Washer
Fault code A10 on indesit dishwasher, how do I fix it?
A10 fault indicates heater open circuit fault. Problem either heating element, or control board. Test element for correct continuity and resistence, if OK, replace controller
Aug 07, 2009 | Indesit Dishwashers
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Nov 18, 2008 | Indesit W 123 Front Load Washer
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit W1A111 starts cycle when selector set to "off"
many indesits have a memory on board, set the timer to off position, turn on the mains press start let the machine finish what it is doing, and it will reset normally, turn off at mains for a few minutes can also do the trick, it sounds like one of the option buttons was pressed and you didn't let the timer finish its course,
Aug 29, 2007 | Indesit W 123 Front Load Washer
Dishwashers Logo
148 people viewed this question
Top Dishwashers Experts
