Question about Globe Electric Globe Indoor/Outdoor Lights Timer Kit, 2-Pack #82428201
I cant get 2 out door lights wired together to turn on with one swith
  • Walter Whitaker
    Walter Whitaker May 11, 2010
    Need more information
  • benleves
    benleves May 11, 2010
    can you tell me if its for your car
I have 16ULD/3A electric timer can u sand me manual  dsauto07@gmail.com
Posted on Jan 16, 2009
How can i tell if my door switch on my whirlpool washer machine is working? my machine does nothing when i turn it on.
I cant say for sure the right color of the wires but one is a ground and its attached to the body leave that one alone, jump the 2 other wires on the door witch harnest together to bypass the door switch and see if it runs
Oct 05, 2014 | Whirlpool Washing Machines
I have a 1997 jeep grand cherokee laredo 4.0 that will not start, it wont even crank at all!! This jeep is becoming a real pain in the ****. It has been driven every day and has driven normal like always...
Okay, headlights are nice and bright and battery is still fully charged, if theres no dash lights and doesnt start and you have replaced the ignition swith, this switch is the elctrical switch not the key part correct, then the onlt other thing i can think off that ive run into on these wranglers is a wiring harness that supplies power to ignition system, this wiring comes throught the firewall into cab at the center area of the dash there it has a connector that connects it together, the wires heat up and melt in the connector this is a main power wire in this harness that melts, this harness contains about 4 to 7 wires,hold the key in the crank postion and start moving wire harnesses around under the dash, you will need to look closely ther are not that many harness under that dash, it will be in the center and toward driverside. hope this helps.
Sep 13, 2010 | 1997 Jeep Wrangler
The windows will not work and the interior light wont shut off
as far as the lights not turning off you may have a bad door swith, which i think is in the latch asm,they go bad alot, the windows i would start by checking the wiring going into the driver door,common place for wires to break,you will see a rubber boot that holds the wires its located in bettween the door hinges,
May 14, 2010 | 2004 Jeep Grand Cherokee
I have a 1993 buick lesabre. The security light is flashing and will not start. I checked the fuse it was ok. I tried our other key and still wouldn't start.
there may be a broken wire from the ignition swith going down the steering column,theres two sensors at the begining opening of switch, sometimes they get stuck and dont pop back out, in turn it doesnt touch the chip on the key and cant read it,take a look with a light use a small pic and push lightly on them and see if the y push in and pop out, if they do then replace ignition swith,theres a way to bypass,use an omh meter and measure resistance of key chip, then buy a resistor with the same value,and connenet to wires from switch under the dash,cut wires and put conecting the two going to switch with resistor connecting them together,heres a diagram,193b32f.jpg
May 06, 2010 | 1993 Buick LeSabre
The door to my washer will not lock to wash, It will turn on but goes th edoor will not lock
you need to replace this swithch or by pass it to get to this you with a flat blade screew driver between the lid and front at the gap push in from the left and right side about 2"in the lid will pop up the blake box is your swith remove wires cut stripe and twist together add a wire nut or black tap remeber turn off power
Feb 14, 2010 | Frigidaire Washing Machines
MACHINE WON'T PUMP WATER OUT, STARTS WASH CYCLE THE WASHER GETS TO POINT WHERE IT SHOULD PUMP WATER THEN JUST STOPS. TRIED TO MOVE IT ONTO DIFFERENT SETTING TO PUMP OUT AND WOULD NOT WORK.
SOUND LIKE THE LID SWITH
YOU CAN BYPASS UNDER THE CONSOL 2 PLUG 1 IS POWER THE 2ND IS YOUR LID SWITH SPLICE WIRES LEAVE THE GREEN WIRE PLUG BACK TOGETHER
Jan 31, 2010 | Washing Machines
1996 Blazer dome light stays on
Could be a shorted switch leaving it on, but more likely one of the door switches is not working.
Start by closing all doors securely, then open each door, locate the door switch, and press it all of the way down. Does light go out? Try each door separately, with all other doors (and rear hatch) closed.
Oct 21, 2009 | 1996 Chevrolet Blazer
Wiring Door jamb switch
I'm going to guide you on how to create what is known as a "switch leg".
1- run a 12-2 w/ground wire to the light fixture from new switch.
2- connect black wire "hot wire" to the shiny bronze tinted terminal on switch.
3- connect the white wire " neutral " to the silver connection on switch.
4- connect the naked copper wire " ground " to the ground terminal on switch
5- Disconnect the two white wires in the junction box from each other.
6- Connect the ground to ground in j-box
7- Connect the black to one of the whites in j-box
8- connect the white to the other white in j-box
9- wire nut and tape all connections
Oh and be sure that you turn off the breaker before you start. Hope this helps. Good luck.
Jun 15, 2009 | Gardner Bender #GSW-SK Door Switch
Installing cd players
YOU HAVE THE ILLUMINATION WIRE HOOKED INTO THE RADIO
Oct 02, 2008 | 1999 Chevrolet Tahoe
Wiring on a chamberlain 7200 opener
You'll need to go to : http://www.managemyhome.com/mmh/common/Home.action?sid=MMHMxSearsx00020
Go to the middle of the page 'Search Product Manuals'.
Type in your model #, xxx-xxxxxx of the garage door open.
It should give you the correct wiring diagram your looking for.
Feb 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Globe Electric Globe Indoor/Outdoor Lights Timer Kit, 2-Pack #82428201 Logo
300 people viewed this question
Top Globe Electric Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Globe Electric Hardware and Accessory Expert? Answer questions, earn points and help others
