Question about Sharp Televison & Video
Sharp TV 20V-U53 no picture and audio
No audio and picture but when i disconnect the yoke it has an audio.
4 Suggested Answers
gopakumarg43
  • 75417 Answers
SOURCE: i have sharp tv lost password how to unlock ?
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience. Unlock procedure to many popular brand TVs are given.
Posted on Aug 10, 2014
  • 3 Answers
See this Link
they offer a Password reset sequence
http://www.tvblanket.com/how-to-unlock-your-tv-parental-control-password/
Posted on Feb 12, 2015
Hi, i have sharp color Tv model 14R2, serial NO R311578476. i forgot the password.What should i do now
Posted on Oct 07, 2015
How can i repair my sharp tv, when i connect the yoke it blowout the regulator output,
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search for posts named "My service table today"
May 04, 2015 | Sharp Televison & Video
What is the number of the audio output of sharp 20V-L80M? the IC number is erased.. thanks
Circuit diagram is given.
Oct 12, 2014 | Televison & Video
Fading brightness of sharp 20v-l70m
pls. try adjusting screen control.
Jul 04, 2013 | Sharp 25R-S100 25" TV
My sharp tv model 20V-J100M,,when i turn on green light present but in a few second comes to standby
ba coil around picture tube called as "yoke" is problem sum in ur tv... when copper coils become rusty or cut such problem will come in sharp tv's...
Feb 12, 2011 | Sharp Televison & Video
Horizontal driver too hot, no eht, power suply is ok.
Hello
If horizontal output transistor gets over heated, the either LOT or Deflection Yoke may have some short in it. You just pull out the picture tube base card from the picture tube neck, and place it somwhere. so that it never gets in contact with any other circuit parts of the TV. Pull out the deflection yoke plugin and put the tv ON, and see whether it overheats now or not. If it overheats no also, LOT is defective, and should be replaced with a same type and number. If it does't overheat now. put the unpluged yoke connection, and switch it ON. If it gets overheats, there is some short in between the horizontal winding section inside the deflection yoke. Caution:- Never place the picture tube base board connected to it, while deflection yoke is disconnected. OK.
Dec 06, 2010 | Televison & Video
My sharp t.v 20v-j70m lost power when turn on from red one standby when remoted the yellow will turn off on the screen whats the matter with this?
yung sharp na tv ko 20v-j70m isa no picture but have sound umiinit nang konti yung ic x2933ce ok posibilidad ba po na sira ito
Jul 04, 2010 | Televison & Video
Sharp tv codes for all for one remotes
I need 4 digit code to a sharp TV. and Hitachi VCR,with a oneforall remote - Big Easy brand
Nov 08, 2009 | Sharp Televison & Video
Picture converges to the center -- "funnel" like
1) Solder any / all bad connections
2)troubleshoot,locate and replace any bad parts in pincushion
circuit....start with pin amp output.......
3)No problem found ?.........could be bad yoke.................T.
Dec 21, 2007 | Sharp 27J-S100 TV
Slanting Picture
The yoke has probably come loose and tilted.. From the rear of the set looking on the back of the crt you'll find a copper wire wound magnet called the yoke. It terminates on the neck of the yoke with a clamp. With the set off slightly loosen the clamp and turn the yoke assembly in the opposite direction - key word here is slightly - and apply power to check the alignment.
Keep doing this until you achieve the alignment you want. And always remember to unplug the set between attempts.
Nov 05, 2007 | Sharp 32SC26B 32" TV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
