Cheap Emprex LCD HDTV 3202 powers up but takes hours to re show picture
  • 29 Answers
There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/781/emprex-hd-3202-power-supply-board-repair-service-no-power-shutdown-etc
Posted on Feb 03, 2014
  • 1,684 Answers
Slow picture display is a common symptom of a failing power supply board. Here is an repair guide article that shows what parts need to be replaced to rebuild the power supply board.
http://www.ccl-la.com/blog/index.php/solving-emprex-hd-3202-power-problems/
I hope this helps.
Posted on Jul 08, 2012
    Genius:
  • 2,920 Answers
There are 4 capaciters that are in each corner of the tv inside. if any of them are popped up then they need replaced
Posted on Dec 06, 2008
No power on my Element FLX 3202
The fact that the light isn't on is a sign that you lost Standby Power. Most likely you have a fault with the power supply board.
Jan 03, 2013 | Element Electronics FLX-3211B 32 in. LCD...
The power button does NOT work manually or via the remote!!! what should i do?
I think your TV needs servicing, most likely the power button isn't your problem. You could be dealing with a power supply or a main board problem.
Sep 01, 2012 | Digital Lifestyle FA1B32Z 32 in. LCD...
Tom202cabb capacitor location
I will be soon fixing my TV once I receive the cap. I can hopefully take photo and give you a copy of my notes. My emprex hd-3202 uses the same power supply board as you mentnion above. Email me if you havent complete the job yet.
Aug 20, 2012 | Digital Lifestyle FA1B32Z 32 in. LCD...
Wont stay on
Those units use the TOM202CABB power supply board that are know to have issues. Here is a link that shows what needs to be replaced on the power supply board to repair it.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 10, 2012 | Polaroid FLM-323B Television
Digital lifestyles tv wont turn on
Sounds like a bad power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/777/starmen-tom202cabb-power-supply-board-repair-service-no-power-shutdown-etc
Nov 21, 2011 | Digital Lifestyle FA1B32Z 32 in. LCD...
Poloraid hdtv 36 inch model FLM 3201 PICTURE
FAULTY POWER SUPPLY OR INVERTER PANEL ON BACK OF SCREEN
AVERAGE REPAIR COST £60 TO £80+
Aug 25, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
My lcd digital lifestyle tv is blinking like a strobe light.
Your back-lighting is failing. This is part of the LCD panel and can not be repaired without replacing it. Due to the cost of the panel, best advise would be to replace the TV. Sorry for the bad news... you should check into your warranty status.
Jun 28, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
Emprex monitor lm 1905 - blacks out after a
If this has an internal power supply (no external brick) then you probably have failure of the capacitors inside. The problems exhibited by these failures are usually summed up as "works for a short while and quits" or "will not come on". Yours is probably similar to some Gateway monitors that I have repaired, The parts required for the repair should be under $10.00 and should take under an hour. Now you need to find a shop that can and will do the work unless you have soldering skills.
Dec 05, 2009 | Emprex Computers & Internet
Emprex model wt323 no picture but have audio
Hi, I'm no expert but I've read alot of these posts. Also I do have that model too. Mine is totally dead, the p/s board.
Anyway get a flashlight and shine it directly on the screen with the tv on. Do you see a picture at all? Then the flourescent bulb is off. Could be the bulb, ballast or something like that. If no pic, maybe the inverter or something, now I'm just guessing.
I'll do some research for you. contact me at ray157@comcast.net
Apr 15, 2009 | Televison & Video
Emprex HD 3202 control panel not operating
My first thought then is that the main board may have capacitor damage that will affect the boards ability to "understand" the control signals, if you can I would have the tv looked at at a service center for damaged boards and components, might be an easy fix but might not be (new boards), The lcd panel is good that can net you several hundred dollars at a min.
peope break them all the time and a simple change out is worth several hundred dollars, vs a new tv
Apr 09, 2009 | Televison & Video
Televison & Video Logo
299 people viewed this question
Top Televison & Video Experts
