Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Fridge repeatedly tries to start running but gives up.
The lights work, but nothing is running and the temperature setting displays don't light up. However, every couple minutes it sounds like the fridge starts to run and the displays light up along with it, but after a few seconds the fridge quits.
Any ideas? Thanks!
    Scholar:
  • 62 Answers
You haven't supplied a complete model number, however, most models with an electronic control is contolled by a main computer board. The board controls all the functions. it could be defective.
Posted on Dec 06, 2008
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
REFRIGERATOR HAS STOPPED WORKING , NOTHING RUNS, NO LIGHTS NOTHING
If everything is dead the first thing you have to establish is that the unit is receiving electrical power. It is far fetched for every component to go bad at the same time!!!!!!
Jun 25, 2015 | LG LSC27910ST Side by Side Refrigerator,...
My fridge freezer defrosted overnight indicator lights are on showing temperature settings and also red light but it is not freezing
When the aggregate does not start while the mains is on.please check the thermostat or the aggregate.
I hope you could save the food, because its a serious problem and needs a speedy repair.
Jan 18, 2015 | Refrigerators
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
How do you reset the display temperature
follow this steps and fix it. God bless you
    • 1
      Press the "Fridge" button on the refrigerator's front panel.
    • 2
      Press the "Fridge" button until there are more lights visible on the panel next to "Fridge" to set cooler temperatures.
    • 3
      Press the "Fridge" button until there are fewer lights visible on the panel next to "Fridge" to set warmer temperatures.
Read more: http://www.ehow.com/how_7696789_reset-temperature-samsung-refrigerator.html#ixzz2Ze3Som8U
Jul 21, 2013 | Samsung RS2630SH Side by Side Refrigerator
I have a side by side frigidaire model PHS68EJSB0 and the display panel that shows the freeser and refrigerator temperature is not working and is not lighting up . also there is a beep every few seco
Sounds like a repair tech needs to diagnose the control board for a replacement. Make sure the temperatures inside are not increasing so you don't lose food items.
Sep 04, 2012 | Frigidaire Professional Series PHS68EJSB...
I dont now how to set temperature for samsung rsh1nhmh . All the light in the house vent off and the plugs . Now on the frige screen is only a flashing light. Nothing else
The refrigerator temperature can be set between 7?C (46°F) and 1?C (34°F) to suit your particular needs. Press the Fridge button repeatedly until the desired temperature is shown in the temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the Fridge button to set your desired temperature. After a few seconds, the Fridge will begin tracking towards the newly set temperature. This will be reflected in the digital display.
http://safemanuals.com/314159.php?k=2f8f21dfdc6e62cb4825d07d38bad88d&ID=471000&q=SAMSUNG%20RSH1NHMH
Nov 18, 2010 | Samsung Refrigerators
Motor runs for a few seconds than cuts out. No cooling
The startup capacitor is weak and that makes the overload switch kick in. You can get a 1/4 hp to 1/3 hp 3 in 1 hard start relay to fix that from graingers, or 1stsourceparts. EZ instructions.
Mar 10, 2010 | Refrigerators
Fridge lights flashing on and off, and inadequate cooling
could be a few things. sounds like the compressor is going. put a thermometer in it and play with the temperature settings.might have a short somewhere.
May 24, 2009 | Victory URD-27-SBS Stainless Steel
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
