Canon IR 2318 Copying Problem
My Printer prints a Big Black Line in all paper . I don't know how to solve the problem I need your help regarding to my issue ! Thanks
    New Friend:
My Canon copier IR 2318 has a problem. When it prints, comes out a dirty paper with texts just easy to be rubbed by a finger and disappear! No any error code shown, so what can I do to fix this.
Posted on Apr 14, 2014
SOURCE:
tareq857
  • 7 Answers
SOURCE: i am receiving an error of canon ir 1210- rec.
no canon ir 1210 never falt signal
Your lower cassate paper senson is open or sensor liver is broken you quary it and solve it
My cell phone is 01819879575
Posted on Mar 16, 2009
redzventures
  • 149 Answers
SOURCE: I have an IR-3300 Model xerox machine. It was
The two problems may not be related. Adding toner should not under most circumstances cause copies to become light, unless the toner you are using is of a poor quality - I hope it is a Canon cartridge or quality generic. It sounds as though your fixing film or drum unit may need replacing, or perhaps you need to perform a install procedure. As the 'install - toner - start' option is free, try it first:
First press the head key and then the number '2' and '8' keys at the same time then press the head key again. This will take you into service mode - select 'copier' then 'install' then 'toner' then 'start'. This will run throught a cycle that takes a little while, I think about 599 seconds (sorry for been so accurate but unhelpful but that's what I remember from the display - never converted into minutes but you're welcome to).
But if you are having blurry or even dirty or light copies it may be the fixing film. When the copies are printed, immediately check if you can rub off the toner at all by rubbing the print with your fingers - if so this indicates that the fixing unit is not hot enough or there is not enough pressure - check that the fuser is in properly and that the jam release lever is not engaged.
Lastly, it could be your drum unit that is faulty or worn. Totest this you will need to try and stop the machine in the middle of printing before it reaches the fuser - open the front cover and latch down the transport bed with the green handle - remove the paper gently so as not to disturb the ink in any way and observe the image quality - if it is displaying the exact same symptoms then it is not your fuser and is probably the drum unit or dodgy toner - most likely the drum. However, if the image is fine, then it most definetely is your fuser film (and or perhaps the cleaning roller that cleans the film).
Good luck
Posted on Jul 31, 2009
FixinFax
  • 3085 Answers
SOURCE: canon ir 2016 is displaying
there is a black switch knocked out of it's holder.
Posted on Feb 14, 2010
canontech
  • 1219 Answers
SOURCE: i would like to Reset/Retrieve Password for Copier
If you know the password, then under user mode, i think system sett., must be option for department id management where you can change passwords.
If you dont have pass, you can do clear all under service mode ( * 2 8 * ) if canon changed service mode, like on some series, you can try MENU and #.
Hope that helped
Posted on Jun 29, 2010
Testimonial: "THANKS A LOT THAT WAS SWEET IT WORK THE MAGIC GOD BLESS"
SOURCE: CANON IR C6800 ERROR CODE E000078-0001
error code E000005-0000
Posted on Aug 26, 2010
Firmware for canon ir 2318
This is only available to Canon support dealers.
I can supply you with this firmware & the SST for £20
May 22, 2015 | Canon Office Equipment & Supplies
Copying & Printing dirty text
change the used ink, also adjust the contrast for low level..
Apr 15, 2014 | Office Equipment & Supplies
My printer ir 2022i has a problem that when copying some documents, image is printed in different position from the original placed. I place a document in the copying board in A4R position and choose the...
The only thing I can suggest is to run a printer calibration. This will be in the set up menu. If there is not an option for this in the menu reinstall the software. At the end it should ask you to print a test page at which time it will align itself. You know, first I would check the print menu on yor printer to make sure you did no set it to A4 as the default.
Jan 07, 2013 | Canon iR 2022 Printer
Service manual Canon ir 2318
Hello friend, I have downloaded a Good canon iR2318 service manual from below link:
Canon iR 2318 2320 2420 2422 service manual:
http://goo.gl/dBXTt0
Good luck on repairs.
Aug 03, 2012 | Canon imageRUNNER 6000 Copier
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
Landscape copying
check the adjuster in paper tray then close the paper tray.
at pc go to properties select the landscape & print.
Jan 25, 2011 | Canon iR 2016i Black and White Copier
When i print out a paper, there is a black line through the print out.
I am assuming your black line is printed (not smudged ink)...
If your printer is also scanner/copier, try copying a page (rather than printing from computer).
If it scans & prints ok, it could be communication/driver problem. Try reloading the drivers and see if it improves. If the black line is there when copying as well, there's probably not much you can do about it.
hope this helps
LC
www.inkbank.com.au
Nov 10, 2010 | Brother Office Equipment & Supplies
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Apr 12, 2008 | Canon Pixma MP800 All-In-One InkJet...
Open Questions:
1,188 people viewed this question
k24674
Marvin
Marvin
