Whirlpool 7244E lint problems with drum removal
The above machine is leaving lint on clothes. I have stripped it down and the plastic drum outer is filthy and looking at the user manual I assume the 'Magic Clean" lint filter is blocked up. Nothing is stuck in the impeller or hoses. My attempted solution will be to take out the metal drum and give it a good clean out. Agitator is out and top & sides are off. There is a large circular looks like a locking ring which I can't budge. I have even made up a tool to try and undo it. The machine is 9 yrs old. Is there some trick to get the drum out or is the locking ring just frozen on requiring a heap of CRC? Please Help.
  • Stuart Coles Dec 05, 2008
    Solved,
    I made up a locking ring tool, applied CRC to locking ring and kept on tapping (hard). It is a normal thread - counter clockwise.
    The problem with lint was that the lint remover comb was full. We live near the beach and sand had started to block the comb and then lint backed up and created a mushy lint mess.
  • 51 Answers
SOURCE: Lint Filter in Whirlpool Agitator washing Machine
Hi Viral, The lint filter is in the door. It should just lift out. Or cut & paste this link for instruction manual for your machines. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203406876.pdf Regards
Posted on Aug 22, 2007
Buffalo12980
  • 625 Answers
SOURCE: Maytag Washer: How to Remove Tub
Under the agitator is a flat nut with notches in it. this nut requires a spanner wrench that will fit into the notches. You can use a large channel lock plier. rotate the nut counter-clockwise. under the nut will be a seal. remove the nut and the seal and pull up on the inner tub. to replace you'll need to replace the seal. if the nut isn't too chopped up, use this to refasten the tub.
Posted on Sep 06, 2007
aborcass
  • 2651 Answers
SOURCE: Whirlpool Duet: gray plastic agitator poece inside drum broke off
here's the part number for the replacement 8182233, thinking it may come as a 3 pack , if they're not broken no need to replace. but the new one will simply slide in and with a click forward lock into place. they also come shipped with a screw to secure. in order to install screw you'll need to remove the top of the washer(3 screws across the back of the top assy and slides back and off. then you'll see the top of the tub area, a small black hose will run from the white box to the left to directly top of the tub assy. remove ethe hose from the tub and spin the inner drum to the correct position, they screw hole will line up through the opening, re-secure the hose to the tub and your in!
Posted on Nov 13, 2008
SOURCE: whirlpool washing machine agitator removal
my whirlpool washing machine's agitator bottom is working but the top is not. How can I fix this myself?
Thank you,
Ann
Posted on Feb 01, 2009
TechBrian
  • 15 Answers
SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Posted on Mar 10, 2009
Bosch maxx 6 display
there is something caught inside between the outer drum and wash drum those plastic strips are the inside of the drum being damaged probably caused by something being left in the pockets of clothes
May 05, 2014 | Washing Machines
There sems to be something scraping and catching between the outer and inner drum,how do i access this area to check the problem out?aquarius wml520
remove agitator on centre shaft there is a nut that has to bee removed if spin tub wobbles that may be the problem
Jun 16, 2011 | Washing Machines
My ge dryer is hanging clothes around the drum and leaving them black. mostly wash cloths at a corner. it has a squeak like a cricket.
Hello darrellandru, the problem is most likely going to be the drum slides. On the top drum bering, there are four plastic strips, the drum sits on these strips and those strips are what the drum rides on. You may also have problems with the drum gasgket (the felt that is on the bottom plastic drum bering).
Sep 23, 2010 | GE Profile DPSR473EW Dryer
Black lint on white clothes after wash. have cleaned filter. is a front loader.
Check both the apron, located in front of the drum for lint residue, as well as the drum itself for sharp points (gouges) which may have snagged clothes and collected the lint to the inner side of the drum. Also try running a full cycle with no load to clear any lint which may remain in the outer (non visible) drum.
Mar 05, 2010 | Washing Machines
We have a Whirlpool top loading washing machine that leaves the clothes covered with lint after each load. Delicate clothes that have elastic bands are covered with pieces of lint on the bands that are...
Your service man is right, the lint is filtered through the filter plugs on the bottom of the tub, and backflushed out during the spin cycle. This does not do a great job of filtering out the lint that came out of the clothes. So why is there so much lint? Three reasons: 1. Clothes being beaten against the agitator, tub, each other. The Whirlpool washer has a pretty decent way of agitating the clothes without too much damage, as long as there is plenty of water for the clothes to move through. As long as you make sure your load size and water level are correct, this shouldn't cause a lot of lint. I always have a larger water level than the load size calls for. 2. Lower quality material in the clothes. We definitely see this a lot, especially in the cheaper towels, rugs, sweaters, ect. Some of these have such cheaply made fibers, that they put out a lot of lint. 3. Laundry soaps. Most soaps are very caustic detergents and eat the fibers right out of the linens. There are some brands of washers that still use a type of metal in them that this soap eats right up, so in a few years the machine is junk. All of the washer manufacturers went to plastic outer tubs, as the soap was literally eating holes in the outer tubs in 2 to 3 years on some brands. This is one of the reasons we have so much of the micro lint that is so fine, it goes right through your dryer lint filter and causes lint build up in the venting itself. Years ago, at our shop in Hawaii, we tested naturopathic soaps for 12 years before we settled on the Melaleuca brand for our laundry soaps. Ph neutral, cleans the clothes better than any brand we have tested before or since, does not leave the sludge in the outer tub that most brands do, does not leave a hard aggregate in the tubs like some other brands do, is cheap and does not cause the allergys, athsma, skin rashes, ect. that most of the caustic brands are doing. We have used it for over 10 years now and see very little lint in our Whirlpool washer. Look it up online, join it, and buy the soap directly from the company. It sounds like you have done everything else correctly to the washer, that you could have. I am impressed, most people could not have done what you did. Hope this helps. Good Luck, Appliance Specialists
Jan 22, 2010 | Washing Machines
Whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
IR-2570CI
This error indicates that the patch image read sensor is dirty. You can locate the patch sensor by removing the drum unit from the front of the machine. The patch sensor is located in the machine, directly above the drum unit, halfway intothe machine. If you look into the machine and up you will see a white plastic unit running along the top about halfway point between the front and back of the machine. The patch sensor is inset into that unit and is black plastic. Clean with a lint free cloth several times - as it is hard to see the actual sensor, feel along the strip with your fingers until you can feel the indent where the sensor is - concentrate your cleaning around that area. Now replace the drum and turn the machine back on (I hope you turned it off first).
Removing the drum is easy but hard to explain. In fact, if you get the front cover off, you've done the hardest part. There are some hidden screws, one above the front cover to the left - as if you are looking down on the machine, there may be a small circular plastic cover hidding access to this screw. Remove it and unscrew. If you have an internal finisher, you will have to remove the circular covers above and below the front of it to push your driver through to the hole you need. Sounds complicated but once you've done it you'll see that it's easy when you know where the holes are. There is then another screw at the top, near to right that you access through the panel above - just look around and above the front cover to find the screws. Good luck
Aug 19, 2009 | Canon IMAGERUNNER 2230 Copier
During the final spin cycle, water is leaking inside the machine
You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
Make sure there is no congealed soap in the Air Bell as it is called
Jul 05, 2009 | Fisher and Paykel WA37T26G Top Load Washer
The ring that goes aroung to drum (i think it is plastic) is all chewed up and decaying is it a easy fix for homeowners or should we get someone to fix it
theres arubber "boot" connecting the tub to the outer wall of the unit. if your seeing "bone colored" plastic rubbing off and onto the soft rubber boot assy, that sounds like the outer tub itself somehow wearing down, , that snot an easy repace ment at all, you would need to replace the entire outer fornt tub.
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
639 people viewed this question
Top Washing Machines Experts
