Question about Crown CM-311 AE Microphone
I want to know what brand of microphone to buy
I have a Crown CM-311A headset. However it's a little uncomfortable. There is another microphone out there that looks almost exactly the same except it doesn't have the adjusment tool that's located by the ear like the CM does. I've seen it worn by singers like Britney Spears and Janet Jackson. What type of microphone is it and where can I get one?
It is the same mic. The singer's sound technicians just removed the mic from the crown headset and put it on a headset custom made to the singers head. This way it holds up more to the dancing and it is less complicated to put on.
Posted on Dec 26, 2008
Which brand sells the best headphones?
There are many headphones selling brand but the best two that know are Plantronics & Jabra. These both brands supplying the all kind headphones, headsets and many more at the best price. Now its up to you that which one you pink off, every headphone/headset has its own features, price, and quality. Every time I wnat to buy headsets/headphones I visit these websites Telegiants and HeadsetZone to buy from. You can buy all kinds of headsets/headphones of these brands at there. Visit them to place your order.
Wireless and Corded Headsets Bluetooth Headphones Telephones
Jul 19, 2017 | The Audio Players & Recorders
How do I rewire my crown cm311a mic from mic to belt pack?
It looks like a mini XLR connection at the belt pack end, so that's easy. The cable goes to a connector block which looks like it is held together with two screws. Again, that should be fairly straightforward.
The other side of the block is the cable that goes up to the head set and boom mic. This looks a little trickier for a novice just because the mic capsule is small; the cable runs through a narrow diameter tube, and the cable routing involves heatshrink.
At a guess I'd say that the foam windshield will come off. There'll be a grub screw holding the collar in place.
Personally, I'd use a meter on continuity setting, upen up the XLR and connectors block, and test the two signal lines (pins 2 and 3 in the XLR) for a break. Fingers crossed it is in that section. Then replace that cable.
If it is in the boom arm section, and you feel confident dealing with threading the cable and using heat shrink then have a go. If not, take it to a Tech to avoid the risk of wrecking a great mic.
Sep 04, 2014 | Crown CM-311A Professional Microphone
Why no headset with microphones?
Return it for a refund. They are a terrible compnay and have bad customer support. Just send them back and buy another brand.
Aug 30, 2014 | Car Audio & Video
Where is the microphone? I know where the microphone plug is but I can not find the physical microphone
Most computers/PC's do not come with a microphone. You have to buy a stand alone mic or headset with mic and then plug it into the microphone jack on the front or back of your comptuer.
Oct 18, 2013 | Dell Dimension 8400 PC Desktop
I'm useing the SLX1/SLX4 cordless combo with a Crown headworn mic (CM 311/E SH). Sometimes the sound cuts off ! I'm based in NYC. where can I go for repair? Thanks
If the problem is with the Shure wireless, you'll need to send it back to Shure (www.shure.com/service). If the problem is with the Crown headset, you'll need to send that back to Crown.
Oct 28, 2010 | Shure SLX1 Body-Pack Transmitter for...
What kind of outlet do i plug my cm-p35 microphone into?
The cm-p35 is a low-impedance (low-Z) dynamic microphone. It can plug into a mixer or microphone preamp that has XLR input connectors, typically found on professional audio equipment.
If you want to attach it to a computer, you'll need to buy an audio interface for it, either a pro-grade sound card with XLR inputs, or a USB-to-XLR adaptor, like this one at ZZounds.com
Jan 10, 2010 | Coby CM-P35 Consumer Microphone
It's not really a problem but a question on a microphone I would like to buy. I have a CM-311A headset but it's uncomfortable. There's another microphone out there that is similar to it except there is not...
There are numerous headset mics. Most feed into a bodypack the singer wears, which can be wired or wireless. It has the batteries required for phantom power, etc.  See what kind of a plug is on your existing mic. Probably a mini-xlr. You should be able to use any mnini-xlr mic with your rig. Go to your music store with your old mic and ask to see and try on other models. If the plugs are the same, the mics should be inter-changeable.
Dec 05, 2008 | Crown CM-311 AE Microphone
Wiring diagram
http://www.performanceaudio.com/media/pdf/54/3429_b.pdf
That should shed some light...might have to through solder on to the circuit board should be relatively easy!
Sep 13, 2008 | Crown CM-311A Professional Microphone
I have a logitech headset with microphone
I would suggest purchasing a new one.
Headsets are very "cheap" these days....
Any kind of saliva, spill or humidity renders them useless...
~~Jasta~~
Mar 30, 2008 | Radio Communications
201 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
