Question about Acer Aspire 3624WXCi Notebook
Bootup failure Hi, I accidently stepped onto my power supply transformer and burnt something inside it. Acquired another unit but could not get past choosing O/S start-up section. Keeps on asking to insert to re-install a copy of a file \system32\ntoskrnl.exe My CD ROM had not been working for a while, I sometimes use friends external units as needed. The computer was given to me as a giveaway from a friend. I was searching for the factory reset code, I remember the friend showing it to me before he left. I cannot remember what it is but do recall it short and supposed to be easily remembered. I want to remove the other incomplete window xp pro that he told me about that he failed to complete installtion due to power failure at the time. What do you make of this, hope I'm explaining this clearly.
  • aniwenpago Dec 05, 2008
    Thanks Dipu007,
    Refering to "missing or corrupt ntoskrnl.exe file" above,
    The CDROM is not working and I tried to use an external unit, but seems not to be able to communicate with it. I tried to enter the BIOS to change boot-up sequence but found it asking for a password. Like I said, the unit was an handout and I could not be sure if it still got a factory set password (if theres any) or there had been any entry of password to this section. Just the same would it be possible to reset the password in this sector?
    Problem Solver:
  • 10 Answers
Just a few days ago, I lost my windows vista admin passwords. I solved the trouble with the help of windows password reset tool. It not only support XP/Vista/2000/NT, but also compatible with windows 7, I tested it on my computer installed with Windows 7 and remove the local user and admin accounts password successfully. It's worth trying. You can download it from:
Posted on Dec 16, 2011
  • 407 Answers
Chack your smps ..........or ram ...
it ok then restart and xp sp2 load.
Posted on Dec 05, 2008
  • 2,110 Answers
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution:Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
What could be the cause of the receiver act like it's not plugged in? No lights or anything.
Is the outlet live? Does something else plugged into the same outlet work?
Does the receiver have a master power switch on the back that may have been switched off by accident.
Some - not all receivers have user replaceable fuses. If you do not see a fuse holder on the receiver near where the power cord attaches then you may need to open the chassis to see if there are replaceable fuses on the power supply board inside. Follow where the power cord connects to the chassis. It will lead to a board with a transformer that changes high voltage to the low voltage that the receiver needs to operate.
IF there are user replaceable fuses inside they will be on the power supply board.
PLEASE make sure that the unit is unplugged and has been for some time as the transformers sometimes stores residual voltage that will harm you. Don't do this unless you know what you are doing inside the unit. I recommend novices just take it to the repair center.
Also - IF you replace with the wrong fuse type and rating you can cause further damage to your unit.
Good luck and be careful.
May 26, 2014 | Sherwood RD-6108 Receiver
No power on light
That's interesting.. After researching that model I can tell you that it has an intergrated internal power supply(transformer) which does contain a fuse. It is located where your power cord plugs into, inside the unit, start with that. Was it plugged into a surge protector? When you had the power failure the second time was there a fluctuation of power, ie your lights in your house flickering on or off or increasing, decreasing in brightness? This will help me determine if it's something else. Also be sure to check your power cord, look for any kinks, breaks, chips in insulation. Anyway Good Luck
Sep 29, 2007 | Sony VPL CS4 Multimedia Projector
Power Supply Issues: Your Troubleshooting Guide
If the power supply shuts off unexpectedly or doesn't turn on at all, try the following steps:
  1. Check that the power supply is connected to a grounded, 3 conductor socket.
  2. Check to see if the outlet has power, by plugging another device that works in another outlet.
  3. Check the power supply cord to ensure it's not damaged.
  4. Place the power supply (transformer) at least 3.6 meters / 11.8 feet from the pool and at least 12 cm / 4 Inch above the surface (fig.1). The transformer will supply low voltage to the cleaner
  5. Uncoil the cable (fig.2)
  6. Place the unit in the water. Turn the unit side to side in the water to allow air to escape from the body and then let the cleaner sink to the bottom of the pool (fig.3). Allow wheels to soak for 15 minutes before using Mirra for the first time of the season.
  7. Then, spread the cable over the surface of the pool as evenly as possible (fig.1).
  8. Plug the cable into the power supply. Make sure the key on the plug corresponds exactly with the key slot on the socket of the power supply (fig. 4a)
  9. Plug the power supply into a grounded outlet. (fig. 4b)
  10. Press the CLEAN button and the light will glow indicating that the system is "ON." The pool cleaner should start the cleaning cycle (fig. 5). Turn the power supply on and off a few times, leaving 45 seconds in between each action, if the pool doesn't start cleaning.
  11. If problem still continues, please contact customer service or your local repair center for further assistance.
Information acquired from iRobot Support
on Sep 17, 2013 | iRobot Mirra 530
Power supply humming
I think you have a 110 volt machine on which you are using a step down transformer. If so it seems that the voltage from the transformer is high or the current factor requirement is also insufficient . which can produce the hum or heat. Make sure the voltage is steady or else you will need to use a stabilizer or a proper power supply that is actually catering to the requirement of the machine. You have not mentioned the power factor of the machine and i suspect that the power supply used externally is insufficient.
Sep 27, 2013 | Siemens Washing Machines
My compaq presario sr1650nx shuts down and reboots on its on. what is causing this
- First run a full scan of the whole system with an updated anti-virus.
- Restart after completion and observe.If it still continues to reboot:-
- Your operating system needs repair some files are damaged.
- Remove the hard drive and enslave[connect as a secondary drive] onto another well operating
- Power on the computer.
- Accept run unnix option.
- The disk will be repaired automatically.
- Remove and re-connect to your machine.
Sep 15, 2011 | HP Compaq Presario SR1650NX...
I got logitech speakers X-230 M/N: S-0123A that need ac110-120v- 60 Hz from USA and by mistake plugged it into ac 220 v that is standard in new delhi. there was a spark and smoke from the woofer unit, and...
You have damaged the power supply unit and this would have caused some failures on the power supply and sometimes on the drivers.
So first of all please check the power supply unit, alternatively the DC power required can be supplied by incorporating a new power supply with the same rating but working on 220volt.
repairing the 110 volt supply is no good as you will need again a step down to work , so I suggest this change.
Feb 25, 2011 | Office Equipment & Supplies
My Bosch double oven timer is not working. No clock, notimer, but the oven is working fine.
Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
Sep 19, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
Monitor goes black on bootup,when switched off then on again p image is seen for a second or two then goes black again
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 15, 2010 | AOC 917Sw 19" LCD Monitor
Pioneer DVR-320-S is dead.
Well if it is dead and the transformer is getting power then next step is the processor.  Which if it is dead, then I am sure all the internal components are as well.  My recommendation is have a professional give you and estimate and buy a UPS unit that will regulate the power to you important expensive units such as this.
Jan 06, 2009 | Pioneer DVR-320S DVD Recorder
110 Volts plugged in 220
More than likely just the power supply would be damaged, it should blow before the rest of the unit gets damaged. Maybe even just the fuse inside where the power lead connects is blown.
Mar 08, 2008 | Harman Kardon AVR 135 Receiver
Acer Aspire 3624WXCi Notebook Logo
266 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
