MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
  • 340 Answers
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
1. New hardware has been recently installed.
2. Error or confliction with settings in CMOS.
3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS.
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Posted on Dec 05, 2008
  • Teis Thomsen
    Teis Thomsen Dec 05, 2008
    When less than a quarter feel the need to vote for the effort some of us at FixYou offer, I think to myself, ”is it worth it”.
    They get help, and do not care to thank you; “thank you” do not cost a dime, so why????
    /Teis
  • Teis Thomsen
    Teis Thomsen Dec 15, 2008
    Hi, back again,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if it´s Fixed, then vote “FixYa” to close this case,
    Thank you
    /Teis
    Problem Solver:
  • 5 Answers
I have a same problem with my v2000 and solutions didn't work for me. i also replaced the CMOS battery but still getting same error
Posted on Dec 10, 2009
When i switch on my compaq presario V2000 laptop it beeps three times and then freezes giving me the option to press f1 or f10 but when i press f1 or f10 it still doesn't work and is still frozen
Hi....
Actually beep sound indicates hardware error or BIOS error.
Don't press F10 while starting.
Let your laptop to start wait for 10min....
If it will not starts..........
Press F1(BIOS Settings for some pc F2 is Bois Setting)
If it will load BIOS.......... then your BIOS is OK
Then you need to change hard disk...
If not you need to change BIOS hardware(IF you i will tell you the way restore BIOS but it's very difficult task.It needs a trained person.)
Thank you have a nice day............
Feb 06, 2011 | HP Compaq Presario V2000 Notebook
HP Pavilion ze2308wm won't boot up
Have you tried an external keyboard, either PS2 or USB depending on what ports are available?
Mar 14, 2010 | HP Pavilion ze2000 Notebook
Compaq V2000 "Press <F1> to resume, <F10> to Setup
re install the operating system.insert the recovery disk and follow the instructions.
Feb 20, 2010 | HP Compaq Presario V2000 Notebook
My Compaq V2000 beeps twice & freezes
It sounds like the RAM is either not compatable or is bad. Put the old RAM back in and try again. Also the V2000 and HP DV2000 is in recall for mother board problems.
Nov 12, 2009 | HP Compaq Presario V2000 Notebook
hi roman razumo,
these are common infos you can see on beep codes.
if you have AMI, your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard. (more info on this click here)
for physical troubleshooting tips for laptop issues, please click this link.
http://www.laptoprepair101.com/
hope this helps.
regards,
voodoo
Apr 12, 2009 | Computers & Internet
Won't boot
Glad to help.. Let me research this a little further.
Joe
Oct 19, 2008 | HP Compaq Presario V2000 Notebook
When i turn the laptop on it won't go pass the f1 to resume f10 to restart
Computer BIOS information and help If the computer does not pass the POST, you will receive a combination of beeps indicating ... CH000301, Prompt to press F1/F2 each time computer boots.
Linux and UNIX cut command help Lines with no field delimiters will be passed through intact .
Good Luck please dont for get to Vote/Thank You.
Dec 20, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
1,375 people viewed this question
David Payne
David Payne
