Question about Jabra BT150 Wireless Headset
How do you control the volume on a fuse bluetooth?
Device worked the first few times I used it, then lost volume and would not increase past first dot.
Please be sure to double check that the volume for BLUETOOTH on the device (phone, tablet, etc.) is also turned up. Please note that the volume buttons on the speaker may not always control the bluetooth volume via the device.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Jan 29, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Apparently the volume of my plantronics 925 bluetooth is very low. is there a way to adjust that volume? Thank you.
Yes, there is a way to adjust the volume on your Discovery 925 headset. See page iv to locate volume control button and page 8 for the instructions in this link for the Plantronics Discovery 925 User's Guide.
Good luck from Headsets Direct!
Jul 01, 2011 | Plantronics Discovery 925 Bluetooth...
How do I control the volume on my Plantronics 220? Is the rocker switch on the side the volume?
There are two ways you can control volume on the headset. One is through the volume controls on the cell phone and second, through the volume switch located on the side of the headsets. There are five levels of volume on the headset.
Good Luck from Headsets Direct!
Jun 23, 2011 | Plantronics Explorer 220 Bluetooth Headset...
The volume is extremely low when I make a call. It didn't used to be like this. Pressing the up volume button helps, a little bit, but barely.
just remember the bluetooth has a seprate volume control to your mobile make sure the volume is turned all the way up on your mobile too
best of luck
please take the time to rate this advice
merry christmas
Dec 07, 2010 | Motorola Mobility H710 Bluetooth Headset
Volume control problems with motorola bluetooth stereo headset. Sometime volume switch won't respond to lower the volume and at other times, the headset beeps and then volume decreases on its own.
may the problems also lies with the connection between handset and stereo. may it has lost its service. try getting another one. good luck!
Oct 14, 2009 | Radio Communications
Cant turn up the volume
Volume control, if not on the bluetooth device, can be adjusted on the cell phone depending on which cell phone it is. Try to look under bluetooth devices and if your headset is recognized you can be able to adjust volume. Otherwise.. check the manual :)
Hope you'll figure it out
Regards
Jun 05, 2009 | Motorola Mobility H3 Bluetooth Headset,...
Need to know how to adjust volume on bluetooth
by pressig the volume button up and down
on the handset press the volume buttons
any thing else idont know
Mar 25, 2009 | Motorola Mobility H350 Wireless Headset
Audio on h700c
Check to see if you have not muted the headset or the phone.
Nov 05, 2008 | Motorola Mobility Bluetooth...
Jabra BT150 Wireless Headset Logo
100 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
