Question about Canon PIXMA MX310 All-In-One Printer
Canon MX310 just set up - phone rings like incoming fax
I have just set upCanon MX310.Prints and faxes fine but when phone rings its like a fax incoming and intermitent ring.Very fuzzy noise on line when calling and dial tone
  • joarivas Dec 17, 2008
    Every time that I receive a call to my home , my fax detects a incoming fax. Even though is working properly because I can send faxes, and work with the rest of functions. It's the second machine with the same problem, It's this by default?
  • Anonymous Jan 07, 2009
    I have the same problem. Connections are fine; the Canon just never realizes that someone’s picked up the phone, and keeps trying to mate with a fax machine on the other end.
    Master:
  • 479 Answers
Check out the connection some where loose or also check out connecting the external phone line to the printer and whether the same problem occurs or not.
Posted on Dec 10, 2008
I am getting rid of my dedicated fax line and am adding it to my land line. I am told when I have a fax coming in I will hear a double ring which mean my fax line is ringing. How do I set my fax to...
There are two ways to configure a fax machine to answer the phone line. The first way is by pushing the "auto answer" key on the keyboard of the fax itself. When this key is used, the fax machine answers all calls that come in after a certain number of rings. The other way is to manually press the fax button when an incoming call is happening. You can set the number of rings for your machine to pick up by using the keys on the fax machine under the menu feature and then scroll using the up and down arrow keys until you see fax set up and then number of rings.
I have heard about the option that your speaking of, where they give you a separate phone number for your customers to fax when you own a business line but I don't know how the fax machine itself would be able to distinguish between the normal ring of a regular call and the double ring of the merged fax line call. I was told that when I set that up for my friends business recently, that the machine would auto recognize the double ring without any programming and to use the auto answer feature for all calls. He has not had any faxes yet (its a new business) so I can't say for sure if it works or not? I can say that none of his regular calls have been picked up by the fax so far though.
Nov 10, 2010 | Canon PIXMA MX310 All-In-One Printer
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
Stopped receiving faxes ten days ago. Can still send faxes. Senders say it just rings and rings. Calling the fax by phone confirms many rings, then fax belltones. What do you think is the problem?
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Jan 28, 2010 | Canon PIXMA MX310 All-In-One Printer
Low ink message with incoming fax, no fax but printing works fine
Unplug the machine for 3 minutes and plug it back in. sometimes this will reset everything. good luck
Feb 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Turn off fax ringer - turn on phone ringer Laserclass 2060P
Hi
You can set it for manual mode.
Or set it for fax only but set the incomming ring count to more than 8 times that will give you time to answer a call before it go to fax.
Jan 05, 2009 | Canon LaserClass 2060P Plain Paper Fax
MX310 fax problem
We have the telephone and printer/fax on the same line and, when the printer is turned on, the fax rings when receiving a phone call. The incoming phone line is connected to the "telephone" modular jack.
Jun 06, 2008 | Canon PIXMA MX310 All-In-One Printer
Pixma mx 310 fax auto
enter rx settings and select teleline as fax priority.
Mar 30, 2008 | Canon FAX-JX200
Canon mx310 fax noise
This seems to be a problem more with cable digital phone lines.  I have the same issue... driving me nuts.  I will keep looking for a solution and post again if I find something.
Jan 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
164 people viewed this question
old marine
old marine
