Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Someone gave me a wd external hard drive. Computer says device is ready for use. Drive is found in device manager but no letter is assigned. All it shows is wd external usb device.
    Genius:
  • 1,605 Answers
Since it an external device. dependent on the BIOS, some machine will assign a drive letter and some will not, either way, if the machine detect the device. you can use it as is.
Posted on Dec 05, 2008
The WD my passport is not recognized by the computer .. It was wroking fine couple of weeks ago and am pretty sure it didn't fall or something.. its not recognized and not showing on my computer .. please...
Assign a drive letter for the External drive.
  • Right Click on My Computer
  • Scroll to Manage
  • Select Disk Management
  • Locate the External drive in the lower bottom Right corner, Right Click, Select Assign Drive Letter. Ok/Close
Open up My Computer, and you should see your External drive with your new drive letter assigned to it.
Dec 31, 2010 | Western Digital My Passport Essential...
My new WD 320 GB external drive won't detect in my pc and laptop? pls help....
Hello there,
Please try to plug it into another USB port. There is a chance that your port could be faulty. If its not with the port, try to assign the drive letter if you are using windows. You have to right click on the My Computer icon, select Manage. Once on Computer Management, select Disk Management. Locate your WD drive and right click again. Finally, click on the Assign Drive Letter and follow the wizard.
Dec 26, 2010 | Western Digital Elements powered by WD 320...
I bought 2 WD external hard drives and I am having the same problem with both of them. I can't see them on my computer. When I plug the drives, they show the drivers loading and a message stating the...
This usually means, that the system cannot assign a drive letter to it.
You have to find Disk Management under Administrative Tools.
In Windows XP you right-click My Computer, choose Manage, management console opens, and Disk Management is available in the tree on the left somewhere near the end.
You should plug in one of the HDDs - a new drive should appear there on the right, when you click the "Refresh" icon. Right click on this drive and select "Assign/change drive letter", and choose a drive letter, preferrably more towards the end of the alphabet (like W for example). When you are done the drive should appear on the list with the letter W, and you should be able to use it.
Do the same with the other drive, assigning a different letter (like V for example).
Oct 24, 2009 | Western Digital My Book Essential Edition...
Western Digital External HDD not appearing in My Computer
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Assuming OS is Win 2000/XP/Vista
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Jun 20, 2009 | Western Digital Passport 320GB External...
I've been using my WD external for a while with no issues. Yesterday turned it on and it isn't recognised by any of my computers, is there anyway of fixing this without losing data?
If your PC will recognize the drive and give it a drive letter, you can run chkdsk (Check Disk) from the Run prompt to verify that the drive does not have damaged sectors. many times chkdsk will fix minor errors allowing you to access the drive again.
Click Start, Run CMD, enter, then type: X: (X being the drive letter of the Seagate) then type chkdsk /r and hit enter. If it completes 100% try accessing the drive again.
If you cannot acquire a drive Letter when you plug in the WD External try going to Disk Management and assigning a drive letter.
Click Start, then Right click on My Computer and click Manage, then click Disk Management. See if your WD drive shows up in the list. If it does, right click on the larger box on the right and see if it will allow you to assign a drive letter.
Another option you may have is taking the hard drive out of the WD External enclosure and either connecting it as a secondary drive in a desktop PC, or installing it into another external enclsure USB device, and try again to access the drive.
If none of these options work, your last option is to contract a Disk Recovery Service to acquire your data. They are usually very expensive.
Jun 15, 2009 | Computers & Internet
My laptop does not recognize WD3200ME
If your laptop will give your WD a drive letter, you can run chkdsk (Check Disk) from the Run prompt to verify that the drive does not have damaged sectors. many times chkdsk will fix minor errors allowing you to access the drive again.
If you cannot acquire a drive Letter when you plug in the WD drive, try going to Disk Management and assigning a drive letter.
Another option you may have is taking the hard drive out of the WD enclosure and either connecting it as a secondary drive in a desktop PC, or installing it into another external enclsure USB device, and try again to access the drive.
Jun 14, 2009 | Western Digital Elements powered by WD 320...
No drive letter
When remove the drive do this steps properly first when you want remove the drive remove safley than remive it
Jul 13, 2008 | Western Digital My Book Essential Edition...
Not showing my external hard drive
I HAVE SOLVED THE PROBLEM! or at least this works for my my book 1tb external hard drive. when i initially connect it i get the 'new device detected' pop up thing, but then it doesn't show on my computer. However, I have found that keeping the device pllugged into the computer but removing then replacing the power source from the device causes it to show up. That's all I did, unplug the power cord on the back and replace it. The computer says 'new hardware detected' and 'found my book mass storage device,' then it appears on my my computer tab. Hope this works with you as well!
Dec 04, 2007 | Western Digital My Book Essential Edition...
External Drive not recognized
Have you tried in Disk Management Right-Clicking on the drive and selecting 'Change Drive Letter and Paths...' ? That is the normal way to change or add a drive letter to any drive, internally or externally attached (other than by network connection)?
Dec 03, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
114 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
